Updated on 2025-02-25 GMT+08:00
Advanced Anti-DDoS (AAD)
The Service Control Policies (SCPs) in the Organizations service can use these authorization elements to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permission boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
  • The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in a policy.
  • The Resource Type column indicates whether the action supports resource-level permissions.
    • You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions and you must specify all resources ("*") in your SCP policy statements.
    • If this column includes a resource type, you must specify a URN for the Resource element in your identity policy statements.
    • Required resources are marked with asterisks (*) in the table.
    For details about the resource types defined by AAD, see Resources.
  • The Condition Key column includes keys that you can specify in the Condition element of a SCP policy statement.
    • If the Resource Type column has values for an action, the condition key only takes effect only for the listed resource types.
    • If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
    • If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
    For details about the condition keys defined by AAD, see Conditions.
The following table lists the actions that you can define in SCP statements for AAD.
Table 1 Actions supported by AAD
Action
Access Level
Resource Type (*: Required)
Condition Key
aad:alarmConfig:create
Create alarm settings.
write
alarmConfig *
aad:alarmConfig:put
Modify alarm settings.
write
alarmConfig *
aad:alarmConfig:get
Query alarm settings.
read
alarmConfig *
aad:alarmConfig:delete
Delete alarm settings.
write
alarmConfig *
aad:certificate:delete
Delete certificates.
write
certificate *
aad:certificate:list
Query certificates.
list
certificate *
aad:certificate:set
Modify domain name certificates.
write
certificate *
domain *
g:EnterpriseProjectId
aad:dashboard:delete
Delete report log configurations.
write
aad:dashboard:get
Obtain report data and log configurations.
read
aad:dashboard:set
Modify report log configurations.
write
aad:domain:create
Add protected domain names.
write
domain *
aad:domain:delete
Delete protected domain names.
write
domain *
aad:domain:get
Query domain name details.
read
domain *
aad:domain:list
Query the domain name list.
list
domain *
aad:domain:put
Modify domain protection attributes.
write
domain *
aad:forwardingRule:create
Add forwarding rules.
write
forwardingRule *
aad:forwardingRule:delete
Delete forwarding rules.
write
forwardingRule *
aad:forwardingRule:get
Query forwarding rules.
read
forwardingRule *
aad:forwardingRule:list
Export forwarding rules.
list
forwardingRule *
aad:forwardingRule:put
Modify the back-to-source IP address permissions in the forwarding rule.
write
forwardingRule *
aad:instance:create
Create an instance.
write
instance *
aad:instance:get
Query instance attributes.
read
instance *
aad:instance:list
Query the DB instance list.
list
instance *
aad:instance:put
Modify instance attributes.
write
instance *
aad:policy:create
Add protection rules.
write
policy *
aad:policy:delete
Delete protection rules.
write
policy *
aad:policy:get
Query protection rule details.
read
policy *
aad:policy:list
Query protection rules.
list
policy *
aad:policy:put
Modify protection rules.
write
policy *
aad:quotas:get
Query protection specifications.
read
aad:whiteBlackIpRule:create
Add IP addresses to the blacklist or whitelist.
write
whiteBlackIpRule *
aad:whiteBlackIpRule:delete
Delete IP addresses from the blacklist or whitelist.
write
whiteBlackIpRule *
aad:whiteBlackIpRule:list
Query the protection blacklist and whitelist.
list
whiteBlackIpRule *
aad:protectedIp:put
Modify the labels of protected objects.
write
aad:protectedIp:list
Query the protected object list.
list
aad:package:put
Modify the protection package.
write
package *
aad:package:list
Query the protected IP address list.
list
package *
aad:block:put
Unblock IP addresses.
write
aad:block:list
Query the blocked IP address list.
list
aad:block:get
Query blocking and unblocking information.
read
write
alarmConfig *
aad:alarmConfig:put
write
alarmConfig *
aad:alarmConfig:get
read
alarmConfig *
write
alarmConfig *
Delete a certificate.
write
certificate *
Query certificates.
list
certificate *
aad:certificate:set
Modify the certificate for a domain name.
write
certificate *
domain *
write
aad:dashboard:get
read
aad:dashboard:set
write
aad:domain:create
write
domain *
aad:domain:delete
write
domain *
aad:domain:get
read
domain *
aad:domain:list
list
domain *
aad:domain:put
write
domain *
write
forwardingRule *
write
forwardingRule *
read
forwardingRule *
list
forwardingRule *
write
forwardingRule *
aad:instance:create
Create an instance.
write
instance *
aad:instance:get
read
instance *
aad:instance:list
list
instance *
aad:instance:put
write
instance *
aad:policy:create
write
policy *
aad:policy:delete
write
policy *
aad:policy:get
read
policy *
aad:policy:list
list
policy *
aad:policy:put
write
policy *
aad:quotas:get
read
write
whiteBlackIpRule *
write
whiteBlackIpRule *
list
whiteBlackIpRule *
aad:protectedIp:put
write
list
aad:package:put
write
package *
aad:package:list
list
package *
aad:block:put
Grant permission to unblock IP addresses.
write
aad:block:list
list
aad:block:get
read
Each API of AAD usually supports one or more actions. Table 2 lists the supported actions and dependencies.
Table 2 Actions and dependencies supported by AAD APIs
API
Action
Dependency
POST /v1/{project_id}/cad/alart/config
POST /v1/cnad/alarm-config
aad:alarmConfig:put
DELETE /v1/cnad/alarm-config
GET /v1/{project_id}/cad/alart/list
aad:alarmConfig:get
GET /v1/cnad/alarm-config
aad:alarmConfig:get
DELETE /v1/aad/certificate/del
GET /v1/{project_id}/cad/domains/certificatelist
GET /v1/aad/certificate-details
POST /v1/{project_id}/cad/domains/certificate
aad:certificate:set
POST /v1/aad/configs/lts/delete
GET /v1/{project_id}/cad/ddosinfo/events_type
aad:dashboard:get
GET /v1/aad/configs/lts_region
aad:dashboard:get
aad:dashboard:get
GET /v1/{project_id}/waf/event/timeline
aad:dashboard:get
GET /v1/{project_id}/waf/event/request/peak
aad:dashboard:get
GET /v1/{project_id}/waf/event/attack/type
aad:dashboard:get
GET /v1/{project_id}/waf/event/attack/source/num
aad:dashboard:get
aad:dashboard:get
GET /v1/{project_id}/cad/instances/flow_pps
aad:dashboard:get
GET /v1/{project_id}/cad/instances/flow_bps
aad:dashboard:get
GET /v1/{project_id}/cad/instances/events
aad:dashboard:get
GET /v1/{project_id}/cad/ddosinfo/peak
aad:dashboard:get
aad:dashboard:set
POST /v1/{project_id}/aad/domains
aad:domain:create
POST /v1/{project_id}/cad/domains/del
aad:domain:delete
GET /v1/{project_id}/aad/domains/{domain_id}/service-config
aad:domain:get
GET /v1/{project_id}/cad/domains/ports
aad:domain:list
GET /v1/{project_id}/cad/domains/name
aad:domain:get
GET /v1/{project_id}/cad/domains/line/{enterprise_project_id}
aad:domain:list
GET /v1/{project_id}/cad/domains/instances
aad:domain:get
GET /v1/{project_id}/cad/domains/brief
aad:domain:get
GET /v1/{project_id}/aad/domains/waf-list
aad:domain:list
aad:domain:list
POST /v1/{project_id}/aad/domains/{domain_id}/service-config
aad:domain:put
POST /v1/{project_id}/cad/domains/switch
aad:domain:put
POST /v1/{project_id}/cad/domains/cnameDispatchSwitch
aad:domain:put
POST /v1/{project_id}/cad/domains/cname/switch
aad:domain:put
POST /v1/{project_id}/cad/instances/protocol_rule
POST /v1/{project_id}/cad/instances/protocol_rule/import
DELETE /v1/{project_id}/cad/instances/protocol_rule/{rule_id}
POST /v1/{project_id}/cad/instances/protocol_rule/batchdel
GET /v1/{project_id}/cad/instances/rules
GET /v1/{project_id}/cad/instances/protocol_rule/export
PUT /v1/{project_id}/cad/instances/protocol_rule/{rule_id}
POST /v1/{project_id}/cad/instances/cad_open
aad:instance:create
GET /v1/{project_id}/cad/products
aad:instance:create
GET /v1/{project_id}/{resource_type}/{resource_id}/tags
aad:instance:get
GET /v1/{project_id}/cad/upgradeproducts/{instance_id}
aad:instance:get
GET /v1/{project_id}/cad/instances/detail/{instance_id}
aad:instance:get
GET /v1/{project_id}/aad/instances/brief-list
aad:instance:list
GET /v1/{project_id}/cad/sourceip
aad:instance:list
aad:instance:list
POST /v1/{project_id}/{resource_type}/{resource_id}/tags/action
aad:instance:put
POST /v1/{project_id}/cad/instances/cad_spec_upgrade
aad:instance:put
PUT /v1/{project_id}/cad/instances/{instance_id}/name
aad:instance:put
PUT /v1/{project_id}/cad/instances/{instance_id}/elastic/{ip_id}
aad:instance:put
POST /v1/{project_id}/aad/policies/waf/cc
aad:policy:create
POST /v1/cnad/policies
aad:policy:create
DELETE /v1/{project_id}/aad/policies/waf/cc/{rule_id}
aad:policy:delete
DELETE /v1/cnad/policies/{policy_id}
aad:policy:delete
GET /v1/{project_id}/cad/flowblock
aad:policy:get
GET /v1/cnad/policies/{policy_id}
aad:policy:get
GET /v1/{project_id}/aad/policies/waf/cc
aad:policy:list
aad:policy:list
PUT /v1/{project_id}/aad/policies/waf/cc/{rule_id}
aad:policy:put
POST /v1/{project_id}/cad/flowblock/udp
aad:policy:put
POST /v1/{project_id}/cad/flowblock/foreign
aad:policy:put
POST /v1/cnad/policies/{policy_id}/ip-list/add
aad:policy:put
POST /v1/cnad/policies/{policy_id}/bind
aad:policy:put
POST /v1/cnad/policies/{policy_id}/ip-list/delete
aad:policy:put
POST /v1/cnad/policies/{policy_id}/unbind
aad:policy:put
PUT /v1/cnad/policies/{policy_id}
aad:policy:put
GET /v1/{project_id}/aad/quotas/domain-port
aad:quotas:get
GET /v1/{project_id}/scc/waf/quota
aad:quotas:get
GET /v1/{project_id}/cad/quotas
aad:quotas:get
GET /v1/{project_id}/cad/ip/quotas
aad:quotas:get
GET /v1/{project_id}/cad/bwlist/quota
aad:quotas:get
GET /v1/{project_id}/aad/user-configs
aad:quotas:get
POST /v1/{project_id}/cad/bwlist
POST /v1/{project_id}/cad/bwlist/delete
PUT /v1/cnad/protected-ips/tags
aad:protectedIp:put
GET /v1/cnad/protected-ips
POST /v1/cnad/packages/{package_id}/protected-ips
aad:package:put
PUT /v1/cnad/packages/{package_id}/name
aad:package:put
GET /v1/cnad/packages
aad:package:list
GET /v1/cnad/packages/{package_id}/unbound-protected-ips
aad:package:list
POST /v1/unblockservice/{domain_id}/unblock
aad:block:put
GET /v1/unblockservice/{domain_id}/block-list
aad:block:list
GET /v1/unblockservice/{domain_id}/unblock-quota-statistics
aad:block:get
GET /v1/unblockservice/{domain_id}/block-statistics
aad:block:get
GET /v1/unblockservice/{domain_id}/unblock-record
aad:block:get
GET /v1/{project_id}/cad/instances/{instance_id}/elastic_count/{ip_id}
aad:instance:get
GET /v1/{project_id}/cad/instances/{data_center}/elastic/{line}/{ip_id}
aad:instance:get
GET /v1/aad/remain-vip-number
aad:quotas:get
GET /v1/aad/instance/connection-num
aad:dashboard:get
PUT /v1/{project_id}/cad/instances/{instance_id}/pp-switch
aad:instance:put
GET /v1/aad-service/ces/{domain_id}/dims-info
aad:instance:list
GET /v1/aad-service/ces/v2/{domain_id}/instances
aad:instance:list
GET /v1/{project_id}/cad/instances/security-statistics
aad:instance:list
GET /v1/aad/domain/instances/rules
aad:domain:list
POST /v1/aad/policy/modify
aad:policy:put
POST /v1/aad/geoip
aad:policy:put
GET /v1/aad/geoip
aad:policy:get
DELETE /v1/aad/geoip/{ruleId}
aad:policy:delete
PUT /v1/aad/geoip/{ruleId}
aad:policy:put
POST /v1/aad/whiteip
aad:policy:put
GET /v1/aad/whiteip
aad:policy:get
DELETE /v1/aad/whiteip
aad:policy:delete
POST /v1/aad/custom
aad:policy:put
GET /v1/aad/custom
aad:policy:get
PUT /v1/aad/custom/{ruleId}
aad:policy:put
DELETE /v1/aad/custom/{ruleId}
aad:policy:delete
GET /v1/aad/policy/details
aad:policy:get
POST /v1/aad/cc/intelligent/modify
aad:policy:put
GET /v1/aad/geoip/map
aad:policy:get
GET /v1/aad/instances/{instance_id}/{ip}/ddos-statistics
aad:dashboard:get
GET /v1/aad/protected-domains/{domain_id}
aad:domain:get
aad:domain:list
PUT /v1/aad/protected-domains/{domain_id}
aad:domain:put
POST /v1/aad/instances/{instance_id}/{ip}/rules/batch-create
POST /v1/aad/instances/{instance_id}/{ip}/rules/batch-delete
GET /v1/aad/instances/{instance_id}/{ip}/rules
PUT /v1/aad/instances/{instance_id}/{ip}/rules/{rule_id}
aad:instance:list
Resources
A resource type indicates the resources that an SCP policy applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP policy statements using that action, and the policy applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the policy applies to all resources. You can also set condition keys in a policy to define resource types.
The following table lists the resource types that you can define in SCP policy statements for AAD.
Table 3 Resource types supported by AAD
Resource Type
URN
forwardingRule
aad::<account-id>:forwardingRule:<forwarding-rule-id>
package
aad::<account-id>:package:<package-id>
policy
aad::<account-id>:policy:<policy-id>
alarmConfig
aad::<account-id>:alarmConfig:<alarm-config-id>
domain
aad::<account-id>:domain:<domain-id>
certificate
aad::<account-id>:certificate:<certificate-id>
instance
aad::<account-id>:instance:<instance-id>
whiteBlackIpRule
aad::<account-id>:whiteBlackIpRule:<white-black-ip-rule-id>
Conditions
AAD does not support service-specific condition keys in SCP policies.
AAD can use global condition keys applicable to all services. For details, see Global Condition Keys.
