Virtual Private Cloud (VPC)
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permission to that member account or OU. Instead, the SCPs determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by VPC, see Resources.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about the condition keys defined by VPC, see Conditions.
The following table lists the actions that you can define in SCP statements for VPC.
Action |
Description |
Access Level |
Resource Type (*: Required) |
Condition Key |
vpc:vpcs:create |
Grants permission to create a VPC. |
write |
vpc * |
vpc:vpcs:get |
Grants permission to query VPC details. |
read |
vpc * |
vpc:vpcs:list |
Grants permission to query VPCs. |
list |
vpc * |
g:EnterpriseProjectId |
vpc:vpcs:update |
Grants permission to modify a VPC. |
write |
vpc * |
vpc:vpcs:delete |
Grants permission to delete a VPC. |
write |
vpc * |
vpc:subnets:create |
Grants permission to create a subnet. |
write |
subnet * |
vpc * |
vpc:subnets:get |
Grants permission to query subnet details. |
read |
subnet * |
vpc:subnets:list |
Grants permission to query subnets. |
list |
subnet * |
vpc:subnets:update |
Grants permission to modify a subnet. |
write |
subnet * |
vpc:subnets:delete |
Grants permission to delete a subnet. |
write |
subnet * |
vpc:quotas:list |
Grants permission to query quotas. |
list |
vpc:privateIps:create |
Grants permission to assign a private IP address. |
write |
privateIp * |
subnet * |
vpc:privateIps:get |
Grants permission to query the details of a private IP address. |
read |
privateIp * |
vpc:privateIps:list |
Grants permission to query private IP addresses. |
list |
privateIp * |
vpc:privateIps:delete |
Grants permission to release a private IP address. |
write |
privateIp * |
vpc:securityGroups:create |
Grants permission to create a security group. |
write |
securityGroup * |
vpc:securityGroups:get |
Grants permission to query the details of a security group. |
read |
securityGroup * |
vpc:securityGroups:list |
Grants permission to query security groups. |
list |
securityGroup * |
vpc:securityGroups:update |
Grants permission to modify a security group. |
write |
securityGroup * |
vpc:securityGroups:delete |
Grants permission to delete a security group. |
write |
securityGroup * |
vpc:securityGroupRules:create |
Grants permission to create a security group rule. |
write |
securityGroupRule * |
securityGroup * |
vpc:securityGroupRules:get |
Grants permission to query the details of a security group rule. |
read |
vpc:securityGroupRules:list |
Grants permission to query security group rules. |
list |
vpc:securityGroupRules:update |
Grants permission to modify a security group rule. |
write |
vpc:securityGroupRules:delete |
Grants permission to delete a security group rule. |
write |
vpc:ports:create |
Grants permission to create a port. |
write |
port * |
subnet * |
vpc:ports:get |
Grants permission to query port details. |
read |
port * |
vpc:ports:list |
Grants permission to query ports. |
list |
port * |
vpc:ports:update |
Grants permission to modify a port. |
write |
port * |
vpc:ports:delete |
Grants permission to delete a port. |
write |
port * |
vpc:peerings:create |
Grants permission to create a VPC peering connection. |
write |
peering * |
vpc * |
vpc:peerings:get |
Grants permission to query the details of a VPC peering connection. |
read |
peering * |
vpc:peerings:list |
Grants permission to query VPC peering connections. |
list |
peering * |
vpc:peerings:accept |
Grants permission to accept a VPC peering connection. |
write |
peering * |
vpc:peerings:reject |
Grants permission to reject a VPC peering connection. |
write |
peering * |
vpc:peerings:update |
Grants permission to modify a VPC peering connection. |
write |
peering * |
vpc:peerings:delete |
Grants permission to delete a VPC peering connection. |
write |
peering * |
vpc:routeTables:create |
Grants permission to create a route table. |
write |
routeTable * |
vpc * |
vpc:routeTables:get |
Grants permission to query route table details. |
read |
routeTable * |
vpc:routeTables:list |
Grants permission to query route tables. |
list |
routeTable * |
vpc:routeTables:update |
Grants permission to modify a route table. |
write |
routeTable * |
vpc:routeTables:associate |
Grants permission to associate a route table. |
write |
routeTable * |
subnet * |
vpc:routeTables:delete |
Grants permission to delete a route table. |
write |
routeTable * |
vpc:flowLogs:create |
Grants permission to create a VPC flow log. |
write |
flowLog * |
port |
vpc:PortId |
subnet |
vpc |
vpc:flowLogs:get |
Grants permission to query VPC flow logs or their details. |
read |
flowLog * |
vpc:FlowLogId |
vpc:flowLogs:list |
Grants permission to query VPC flow logs. |
read |
flowLog * |
vpc:flowLogs:update |
Grants permission to modify a VPC flow log. |
write |
flowLog * |
vpc:FlowLogId |
vpc:flowLogs:delete |
Grants permission to delete a VPC flow log. |
write |
flowLog * |
vpc:FlowLogId |
vpc:addressGroups:create |
Grants permission to create an IP address group. |
write |
addressGroup * |
vpc:addressGroups:get |
Grants permission to query the details of an IP address group. |
read |
addressGroup * |
vpc:addressGroups:list |
Grants permission to query IP address groups. |
list |
addressGroup * |
vpc:addressGroups:update |
Grants permission to modify an IP address group. |
write |
addressGroup * |
vpc:addressGroups:delete |
Grants permission to delete an IP address group. |
write |
addressGroup * |
vpc:firewalls:create |
Grants permission to create a network ACL. |
write |
firewall * |
vpc:firewalls:get |
Grants permission to query the details of a network ACL. |
read |
firewall * |
vpc:firewalls:list |
Grants permission to query network ACLs. |
list |
firewall * |
vpc:firewalls:update |
Grants permission to modify a network ACL. |
write |
firewall * |
subnet |
vpc:firewalls:delete |
Grants permission to delete a network ACL. |
write |
firewall * |
vpc:vpcs:createTags |
Grants permission to add tags to a VPC. |
tagging |
vpc * |
vpc:vpcs:listTags |
Grants permission to query VPC tags. |
read |
vpc * |
vpc:vpcs:deleteTags |
Grants permission to delete tags from a VPC. |
tagging |
vpc * |
g:TagKeys |
vpc:subnets:createTags |
Grants permission to add tags to a subnet. |
tagging |
subnet * |
vpc:subnets:listTags |
Grants permission to query subnet tags. |
read |
subnet * |
vpc:subnets:deleteTags |
Grants permission to delete tags from a subnet. |
tagging |
subnet * |
g:TagKeys |
vpc:subNetworkInterfaces:create |
Grants permission to create supplementary network interfaces. |
write |
subNetworkInterface * |
subnet * |
vpc:subNetworkInterfaces:get |
Grants permission to query the details of a supplementary network interface. |
read |
vpc:subNetworkInterfaces:list |
Grants permission to query supplementary network interfaces. |
list |
vpc:subNetworkInterfaces:update |
Grants permission to modify a supplementary network interface. |
write |
vpc:subNetworkInterfaces:delete |
Grants permission to delete a supplementary network interface. |
write |
vpc:networks:create |
Grants permission to create a network. |
write |
network * |
vpc:networks:get |
Grants permission to query network details. |
read |
network * |
vpc:networks:list |
Grants permission to query networks. |
list |
network * |
vpc:networks:update |
Grants permission to update a network. |
write |
network * |
vpc:networks:delete |
Grants permission to delete a network. |
write |
addressGroup * |
Each API of VPC usually supports one or more actions. Table 2 lists the supported actions and dependencies.
API |
Action |
Dependencies |
POST /v1/{project_id}/vpcs |
vpc:vpcs:create |
GET /v1/{project_id}/vpcs/{vpc_id} |
vpc:vpcs:get |
GET /v1/{project_id}/vpcs |
vpc:vpcs:list |
PUT /v1/{project_id}/vpcs/{vpc_id} |
vpc:vpcs:update |
DELETE /v1/{project_id}/vpcs/{vpc_id} |
vpc:vpcs:delete |
POST /v1/{project_id}/subnets |
GET /v1/{project_id}/subnets/{subnet_id} |
vpc:subnets:get |
GET /v1/{project_id}/subnets |
vpc:subnets:list |
PUT /v1/{project_id}/vpcs/{vpc_id}/subnets/{subnet_id} |
DELETE /v1/{project_id}/vpcs/{vpc_id}/subnets/{subnet_id} |
GET /v1/{project_id}/quotas |
vpc:quotas:list |
POST /v1/{project_id}/privateips |
GET /v1/{project_id}/privateips/{privateip_id} |
GET /v1/{project_id}/subnets/{subnet_id}/privateips |
DELETE /v1/{project_id}/privateips/{privateip_id} |
POST /v1/{project_id}/security-groups |
GET /v1/{project_id}/security-groups/{security_group_id} |
GET /v1/{project_id}/security-groups |
DELETE /v1/{project_id}/security-groups/{security_group_id} |
POST /v1/{project_id}/security-group-rules |
GET /v1/{project_id}/security-group-rules/{security_group_rule_id} |
GET /v1/{project_id}/security-group-rules |
DELETE /v1/{project_id}/security-group-rules/{security_group_rule_id} |
POST /v1/{project_id}/ports |
vpc:ports:create |
GET /v1/{project_id}/ports/{port_id} |
vpc:ports:get |
GET /v1/{project_id}/ports |
vpc:ports:list |
PUT /v1/{project_id}/ports/{port_id} |
vpc:ports:update |
DELETE /v1/{project_id}/ports/{port_id} |
vpc:ports:delete |
POST /v2.0/vpc/peerings |
PUT /v2.0/vpc/peerings/{peering_id}/accept |
PUT /v2.0/vpc/peerings/{peering_id}/reject |
GET /v2.0/vpc/peerings/{peering_id} |
vpc:peerings:get |
GET /v2.0/vpc/peerings |
vpc:peerings:list |
PUT /v2.0/vpc/peerings/{peering_id} |
DELETE /v2.0/vpc/peerings/{peering_id} |
POST /v1/{project_id}/routetables |
GET /v1/{project_id}/routetables/{routetable_id} |
GET /v1/{project_id}/routetables |
PUT /v1/{project_id}/routetables/{routetable_id} |
POST /v1/{project_id}/routetables/{routetable_id}/action |
POST 01 /v1/{project_id}/routetables/{routetable_id}/action |
DELETE /v1/{project_id}/routetables/{routetable_id} |
POST /v1/{project_id}/fl/flow_logs |
GET /v1/{project_id}/fl/flow_logs/{flowlog_id} |
vpc:flowLogs:get |
GET /v1/{project_id}/fl/flow_logs |
vpc:flowLogs:list |
PUT /v1/{project_id}/fl/flow_logs/{flowlog_id} |
DELETE /v1/{project_id}/fl/flow_logs/{flowlog_id} |
PUT /v3/{project_id}/vpc/vpcs/{vpc_id}/add-extend-cidr |
vpc:vpcs:update |
PUT /v3/{project_id}/vpc/vpcs/{vpc_id}/remove-extend-cidr |
vpc:vpcs:update |
PUT /v3/{project_id}/vpc/security-groups/{security_group_id} |
POST /v3/{project_id}/vpc/address-groups |
GET /v3/{project_id}/vpc/address-groups/{address_group_id} |
GET /v3/{project_id}/vpc/address-groups |
PUT /v3/{project_id}/vpc/address-groups/{address_group_id} |
DELETE /v3/{project_id}/vpc/address-groups/{address_group_id} |
DELETE /v3/{project_id}/vpc/address-groups/{address_group_id}/force |
POST /v2.0/{project_id}/vpcs/{vpc_id}/tags/action |
POST 01 /v2.0/{project_id}/vpcs/{vpc_id}/tags/action |
POST /v2.0/{project_id}/vpcs/{vpc_id}/tags |
POST /v2.0/{project_id}/vpcs/resource_instances/action |
vpc:vpcs:listTags |
GET /v2.0/{project_id}/vpcs/tags |
vpc:vpcs:listTags |
GET /v2.0/{project_id}/vpcs/{vpc_id}/tags |
vpc:vpcs:listTags |
DELETE /v2.0/{project_id}/vpcs/{vpc_id}/tags/{key} |
POST 01 /v2.0/{project_id}/subnets/{subnet_id}/tags/action |
POST /v2.0/{project_id}/subnets/{subnet_id}/tags/action |
POST /v2.0/{project_id}/subnets/{subnet_id}/tags |
POST /v2.0/{project_id}/subnets/resource_instances/action |
GET /v2.0/{project_id}/subnets/tags |
GET /v2.0/{project_id}/subnets/{subnet_id}/tags |
DELETE /v2.0/{project_id}/subnets/{subnet_id}/tags/{key} |
POST /v3/{project_id}/vpc/sub-network-interfaces |
POST /v3/{project_id}/vpc/sub-network-interfaces/batch-create |
GET /v3/{project_id}/vpc/sub-network-interfaces/{sub_network_interface_id} |
GET /v3/{project_id}/vpc/sub-network-interfaces |
GET /v3/{project_id}/vpc/sub-network-interfaces/count |
PUT /v3/{project_id}/vpc/sub-network-interfaces/migrate |
PUT /v3/{project_id}/vpc/sub-network-interfaces/{sub_network_interface_id} |
DELETE /v3/{project_id}/vpc/sub-network-interfaces/{sub_network_interface_id} |
Resources
A resource type indicates the resources that an SCP is applied. If you specify a resource type for any action in Table 3, a resource URN must be specified in the SCP policy statements using that action, and the SCP policy applies only to the resource. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP policy applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for VPC.
Resource Type |
URN |
vpc |
vpc:<region>:<account-id>:vpc:<vpc-id> |
subnet |
vpc:<region>:<account-id>:subnet:<subnet-id> |
privateIp |
vpc:<region>:<account-id>:privateIp:<private-ip-id> |
securityGroup |
vpc:<region>:<account-id>:securityGroup:<security-group-id> |
securityGroupRule |
vpc:<region>:<account-id>:securityGroupRule:<security-group-rule-id> |
port |
vpc:<region>:<account-id>:port:<port-id> |
peering |
vpc:<region>:<account-id>:peering:<peering-id> |
routeTable |
vpc:<region>:<account-id>:routeTable:<route-table-id> |
flowLog |
vpc:<region>:<account-id>:flowLog:<flow-log-id> |
addressGroup |
vpc:<region>:<account-id>:addressGroup:<address-group-id> |
firewall |
vpc:<region>:<account-id>:firewall:<firewall-id> |
publicip |
vpc:<region>:<account-id>:publicip:<publicip-id> |
bandwidth |
vpc:<region>:<account-id>:bandwidth:<bandwidth-id> |
network |
vpc:<region>:<account-id>:network:<network-id> |
Conditions
A Condition element lets you specify conditions for when an SCP is in effect. It contains condition keys and operators.
- The condition key that you specify can be a global condition key or a service-specific condition key.
- Global condition keys (with the g: prefix) apply to all actions. Cloud services do not need to provide user identity information. Instead, the system automatically obtains such information and authenticates users. For details, see Global Condition Keys.
- Service-specific condition keys (with the abbreviation of a service name plus a colon as the prefix, for example, vpc:) apply only to operations on VPC. For details, see Table 4.
- The number of values associated with a condition key in the request context of an API call makes the condition key single-valued or multivalued. Single-valued condition keys have at most one value in the request context of an API call. Multivalued condition keys can have multiple values in the request context of an API call. For example, a request can originate from at most one VPC endpoint, so g:SourceVpce is a single-valued condition key. You can tag resources and include multiple tag key-value pairs in a request, so g:TagKeys is a multivalued condition key.
- A condition operator, condition key, and a condition value together constitute a complete condition statement. An SCP can be applied only when its request conditions are met. For supported condition operators, see Condition operators.
The following table lists the condition keys that you can define in SCPs for VPC. You can include these condition keys to specify conditions for when your SCP is in effect.
Service-specific Condition Key |
Type |
Single-valued/Multivalued |
Description |
vpc:VpcId |
string |
Multivalued |
Filters accesses by VPC ID. |
vpc:SubnetId |
string |
Multivalued |
Filters accesses by subnet ID. |
vpc:SecurityGroupId |
string |
Multivalued |
Filters accesses by security group ID. |
vpc:PeeringId |
string |
Multivalued |
Filters accesses by peering connection ID. |
vpc:AccepterVpcId |
string |
Multivalued |
Filters accesses by the ID of the VPC owned by the specified recipient. |
vpc:AccepterVpcOrgPath |
string |
Multivalued |
Filters accesses by the organization path of the specified recipient of the VPC peering connection. |
vpc:AccepterVpcOwner |
string |
Multivalued |
Filters accesses by the account ID of the specified recipient of the VPC peering connection. |
vpc:RequesterVpcOrgPath |
string |
Multivalued |
Filters accesses by the organization path of the specified requester of the VPC peering connection. |
vpc:RequesterVpcOwner |
string |
Multivalued |
Filters accesses by the account ID of the specified requester of the VPC peering connection. |
vpc:RequesterVpcId |
string |
Multivalued |
Filters accesses by the ID of the VPC owned by the specified requester. |
vpc:RouteTableId |
string |
Multivalued |
Filters accesses by route table ID. |
vpc:FlowLogId |
string |
Multivalued |
Filters accesses by flow log ID. |
vpc:AddressGroupId |
string |
Multivalued |
Filters accesses by IP address group ID. |
vpc:FirewallId |
string |
Multivalued |
Filters accesses by network ACL ID. |
vpc:PrivateIpId |
string |
Multivalued |
Filters accesses by private IP address ID. |
vpc:PortId |
string |
Multivalued |
Filters accesses by port ID. |
vpc:FirewallRuleDirection |
string |
Multivalued |
Filters accesses by network ACL rule. The value can be ingress or egress. |
vpc:FirewallRuleProtocol |
string |
Multivalued |
Filters accesses by network ACL protocol. The value can be TCP, UDP, ICMP, ICMPv6, or Any. |
vpc:FirewallRuleAction |
string |
Multivalued |
Filters accesses by network ACL policy. The value can be Allow or Deny. |
vpc:FirewallRuleSourcePort |
numeric |
Multivalued |
Filters accesses by source port specified in the network ACL rule. |
vpc:FirewallRuleDestinationPort |
numeric |
Multivalued |
Filters accesses by destination port specified in the network ACL rule. |
vpc:FirewallOperationType |
string |
Multivalued |
Filters accesses by network ACL operation type. The value can be updateAcl, associateSubnet, disassociateSubnet, insertRule, updateRule, or removeRule. |
