On this page
Bare Metal Server (BMS)
Updated on 2025-02-25 GMT+08:00
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to an entity. They only set the permissions boundary for the entity. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
  • The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
  • The Resource Type column indicates whether the action supports resource-level permissions.
    • You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
    • If this column includes a resource type, you must specify the URN in the Resource element of your statements.
    • Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
    For details about the resource types defined by BMS, see Resources.
  • The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
    • If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
    • If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
    • If the Condition Key column of an action is empty (-), the action does not support any condition keys.
    For details about the condition keys defined by BMS, see Conditions.
The following table lists the actions that you can define in SCP statements for BMS.
Table 1 Actions supported by BMS
Action
Access Level
Resource Type (*: required)
Condition Key
bms:servers:updateBaremetalServer
Grants permission to modify BMSs.
write
instance*
  • g:EnterpriseProjectId
  • g:ResourceTag/<tag-key>
bms:servers:showBaremetalServerInterfaceAttachments
Grants permission to query BMS NICs.
read
instance*
bms:servers:resetServerPwd
Grants permission to reset a BMS password with a few clicks.
write
instance*
bms:servers:showResetPasswordFlag
Grants permission to check whether BMS passwords can be reset with a few clicks.
read
instance*
bms:servers:showWindowsBaremetalServerPwd
Grants permission to obtain Windows BMS passwords.
read
instance*
bms:servers:deletePassword
Grants permission to delete Windows BMS passwords.
write
instance*
bms:servers:showBaremetalServerVolumeInfo
Grants permission to query EVS disks attached to a BMS.
read
instance*
bms:servers:create
Grants permission to create BMSs.
write
  • g:TagKeys
  • g:RequestTag/<tag-key>
  • eip:AssociatePublicIp
  • bms:Flavorld
  • bms:VpcId
  • bms:SubnetId
  • bms:KmsKeyId
  • evs:Encrypted
  • bms:ImageId
  • bms:SSHKeyPairName
  • bms:AvailabilityZone
  • bms:VolumeType
Grants permission to query details about a BMS.
read
instance*
bms:servers:attachVolume
Grants permission to attach EVS disks to a BMS.
write
instance*
  • bms:KmsKeyId
  • evs:Encrypted
  • bms:VolumeType
  • bms:VolumeId
bms:servers:detachVolume
Grants permission to detach EVS disks from a BMS.
write
instance*
bms:servers:updateMetadata
Grants permission to update BMS metadata.
write
instance*
bms:servers:reInstallOS
Grants permission to reinstall a BMS OS.
write
instance*
  • bms:KmsKeyId
  • evs:Encrypted
bms:servers:showBaremetalServerTags
Grants permission to query BMS tags.
read
instance*
bms:servers:start
Grants permission to start BMSs in a batch.
write
instance*
bms:servers:reboot
Grants permission to restart BMSs in a batch.
write
instance*
bms:servers:stop
Grants permission to stop BMSs in a batch.
write
instance*
bms:servers:list
Grants permission to query BMS details.
list
bms:serverFlavors:get
Grants permission to query flavor details and extended flavor information.
list
bms:serverQuotas:get
Grants permission to query tenant quotas.
read
bms:servers:batchCreateBaremetalServerTags
Grants permission to add tags in a batch.
write
instance*
  • g:TagKeys
bms:servers:batchDeleteBaremetalServerTags
Grants permission to delete tags in a batch.
write
instance*
  • g:TagKeys
bms:servers:addNics
Grants permission to bind NICs to a BMS.
write
instance*
  • bms:SubnetId
bms:server:deleteNics
Grants permission to unbind NICs from a BMS.
write
instance*
bms:servers:serialConsole
Grants permission to obtain an address for remotely logging in to a BMS.
read
instance*
bms:server:updateInterface
Grants permission to modify BMS NICs.
write
instance*
Each API of BMS usually supports one or more actions. Table 2 lists the supported actions and dependencies.
Table 2 Actions and dependencies supported by BMS APIs
API
Action
Dependencies
PUT /v1/{project_id}/baremetalservers/{server_id}
GET /v1/{project_id}/baremetalservers/{server_id}/os-interface
PUT /v1/{project_id}/baremetalservers/{server_id}/os-reset-password
GET /v1/{project_id}/baremetalservers/{server_id}/os-resetpwd-flag
GET /v1/{project_id}/baremetalservers/{server_id}/os-server-password
DELETE /v1/{project_id}/baremetalservers/{server_id}/os-server-password
GET /v1/{project_id}/baremetalservers/{server_id}/os-volume_attachments
POST /v1/{project_id}/baremetalservers
bms:servers:create
eip:publicIps:create
eip:publicIps:associateInstance
iam:agencies:pass
eip:bandwidths:insertPublicIps
POST /v1/{project_id}/baremetalservers/{server_id}/attachvolume
evs:volumes:use
DELETE /v1/{project_id}/baremetalservers/{server_id}/detachvolume/{attachment_id}
POST /v1/{project_id}/baremetalservers/{server_id}/metadata
POST /v1/{project_id}/baremetalservers/{server_id}/reinstallos
GET /v1/{project_id}/baremetalservers/{server_id}/tags
POST /v1/{project_id}/baremetalservers/action
bms:servers:start
bms:servers:reboot
bms:servers:stop
GET /v1/{project_id}/baremetalservers/detail
bms:servers:list
GET /v1/{project_id}/baremetalservers/flavors
GET /v1/{project_id}/baremetalservers/limits
POST /v1/{project_id}/baremetalservers/{server_id}/tags/action
POST /v1/{project_id}/baremetalservers/{server_id}/nics
bms:servers:addNics
POST /v1/{project_id}/baremetalservers/{server_id}/nics/delete
POST /v1/{project_id}/baremetalservers/{server_id}/remote_console
PUT /v1/{project_id}/baremetalservers/{server_id}/os-interface/{port_id}
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for BMS.
Table 3 Resource types supported by BMS
Resource Type
URN
instance
bms:<region>:<account-id>:instance:<server-id>
  • <region> indicates the region where a user is authorized to perform operations.
  • <account-id> indicates the ID of an authorized user account. Obtain an account ID as instructed in API Credentials.
  • <server-id>: indicates the ID of the BMS on which operations will be performed.
Conditions
A Condition element lets you specify conditions for when an SCP is in effect. It contains condition keys and operators.
  • The condition key that you specify can be a global or service-specific condition key.
    • Global condition keys (with the g: prefix) apply to all actions. Cloud services do not need to provide user identity information. Instead, IAM automatically obtains such information and authenticates users. For details, see Global Condition Keys.
    • Service-specific condition keys (with the abbreviation of a service name plus a colon as the prefix, for example, bms:) apply only to operations of the BMS service. For details, see Table 4.
    • The number of values associated with a condition key in the request context of an API call makes the condition key single-valued or multivalued. Single-valued condition keys have at most one value in the request context of an API call. Multivalued condition keys can have multiple values in the request context of an API call. For example, a request can originate from at most one VPC endpoint, so g:SourceVpce is a single-valued condition key. You can tag resources and include multiple tag key-value pairs in a request, so g:TagKeys is a multivalued condition key.
  • A condition operator, condition key, and a condition value together constitute a complete condition statement. An SCP can be applied only when its request conditions are met. For supported condition operators, see Condition operators.
The following table lists the condition keys that you can define in SCPs for BMS. You can include these condition keys to specify conditions for when your SCP is in effect.
Table 4 Service-specific condition keys supported by BMS
Service-specific Condition Key
Type
Single-valued/Multivalued
bms:KmsKeyId
string
Multivalued
Filters access based on the KMS key ID specified in the request parameter.
bms:Flavorld
string
Multivalued
Filters access based on the flavor ID specified in the request parameter.
bms:VpcId
string
Multivalued
Filters access based on the VPC ID specified in the request parameter.
bms:SubnetId
string
Multivalued
Filters access based on the subnet ID specified in the request parameter.
bms:ImageId
string
Single-valued
Filters access based on the image ID specified in the request parameter.
bms:SSHKeyPairName
string
Single-valued
Filters access based on the key name specified in the request parameter.
string
Single-valued
Filters access based on the availability zone specified in the request parameter.
bms:VolumeType
string
Multivalued
Filters access based on the EVS disk type specified in the request parameter.
bms:VolumeId
string
Single-valued
Filters access based on the volume ID specified in the request parameter.
