Help Center/
OneAccess/
User Guide/
Enterprise Administrator Guide/
Resources/
Applications/
Login Configuration
Updated on 2024-12-30 GMT+08:00
Login Configuration
OneAccess allows you to configure an independent sign-in authentication mode for each app, including official accounts, website and mobile apps.
Web Applications
- Configure the login authentication mode for enterprise users to access applications through browsers on PCs. Before enabling authentication, you need to add an authentication provider. For details, see Authentication Provider Integration.
- Only one of password, AD, and LDAP authentication can be enabled at a time.
- The configuration ID and mounting URL are automatically generated by the system. You can access the mounting URL to log in to the application through a browser. The URL can be edited.
Mobile Applications
- Configure the login authentication mode for enterprise users to access applications from mobile devices. Before enabling authentication, you need to add an authentication provider. For details, see Authentication Provider Integration.
- The configuration ID and mounting URL are automatically generated by the system. You can access the mounting URL to log in to the app on the mobile device. The URL can be edited.
Official Accounts
- Configure password-free login for enterprise apps through WeChat official accounts. Before configuration, you need to add an authentication provider of WeChat official accounts.
- On the page for configuration, click Add Official Account, and then select an authentication provider. After the configuration is added, the system automatically generates the configuration ID and mounted URL. Click View URL to view the URL, and click Delete to delete the URL.
Parent topic: Applications
