Updated on 2025-05-29 GMT+08:00
General Information
  1. Log in to the administrator portal.
  2. On the top navigation bar, choose Resources > Applications.
  3. Click an application to go to the information page.
  4. Click the logo or name to access the general information page. On this page, view the following information:
    • Authentication Credentials
      • ClientId: API authentication ID is automatically generated after application registration.
      • ClientSecret: API authentication secret is obtained by clicking Enable after application registration. If the access secret is lost, click Reset to get a new one.
    • Application
      You can click Modify to modify the application logo and name, and then click Save.
    • Integration
      • Authentication Integration: You cannot change the protocol for integrating the application with OneAccess for identity authentication once specified.
      • Synchronization Integration: You cannot change the method of synchronizing data between the application and OneAccess once specified.
    • Other
      Click Modify to modify the application display mode (automatic, fixed and not display) on the homepage of the user portal.
      • Automatic: The application is displayed only for users who have access to the application.
      • Fixed: The application is displayed for all users.
      • Not display: The application is not displayed for any users.
    • Delete an application
      Click Delete Application, and enter the application's name in the displayed box. Click OK to delete it.
