- Billing
- Getting Started
User Guide
- Before You Start
- Buying an Instance
- Instance Management
Enterprise Administrator Guide
- Logging In to the OneAccess Administrator Portal
- User Management
Resources
- Overview
Applications
- Adding an Application
- Enabling, Disabling, or Deleting an Application
- General Information
- Authentication Integration
- Synchronization Integration
- Login Configuration
- Access Control
- Object Models
- Authorization Management
- API Permission Management
- Application Permission Management
- Security Settings
- Audit Logs
- APIs
- Authentication
- Security
- Audit
- Settings
- Common User Guide
- Key Operations Recorded by CTS
Best Practices
- OneAccess Best Practices
- Identity Source Integration
Application Integration
Logging In to the Huawei Cloud Through User Portal
- Introduction
- Logging In to Single Huawei Cloud Account via OneAccess Without Password (SAML - Virtual User SSO)
- Logging In to Multiple Huawei Cloud Accounts via OneAccess Without Password (SAML - Virtual User SSO)
- Logging In to Single Huawei Cloud Account via OneAccess Without Password (SAML - IAM User SSO)
- Logging In to Multiple Huawei Cloud Accounts via OneAccess Without Password (SAML - IAM User SSO)
- Logging In to Huawei Cloud via OneAccess Without Password (OIDC)
- SSO Access to Applications Through SAML
- SSO Access to Applications Through OAuth 2.0
- SSO Access to Applications Through OIDC
- SSO Access to Applications Through CAS
- SSO Access to Applications Through Plug-in Autocompletion
- Data Synchronization
- Authentication Provider Integration
- Authorizing IAM Users to Access a OneAccess Instance Administrator Portal
- API Usage
- Configuring MFA for User Login
- Developer Guide
API Reference
- Before You Start
- API Overview
OneAccess APIs
Management APIs
- Calling APIs
- Access Credentials
User Management
- Creating a User
- Modifying a User
- Deleting a User
- Enabling a User
- Disabling a User
- Changing a User Password
- Verifying and Modifying the Original User Password
- Querying User Details by User ID
- Querying User Details by Username
- Querying the User List
- Authorizing an Application Account
- Querying All Authorized Application Accounts of a User
- Organization Management
- Application Organization Management
- Application Account Management
- Application Role Management
- User APIs
- Application Integration APIs
Management APIs
- Appendix
- FAQs
Managing User Groups
User groups facilitate user management and authorization. You can create, modify, and delete user groups, and add users to them. For details about user group-based authorization, see Configuring Authorization Policies for Application Accounts.
Adding a User Group
- Log in to the administrator portal.
- On the top navigation bar, choose Users > Organizations and Users.
- On the Organizations and Users page, click the User Groups tab.
- Click Create User Group.
- In the Create User Group dialog box, select an organization, enter the user group name and description, and select an application scenario.
- Click OK.
Viewing User Group Details
In the user group list, click a user group to view its members, applications, and audit logs. For details about how to view and operate a dynamic user group, see Managing Dynamic User Groups.
- Manage members: You can view information about users in a user group, such as the username, mobile number, and email address.
- On the Members tab page of the user group details page, click Add Member in the upper right corner of the user group list and select the users to be added to the user group. For details, see Adding Users to a User Group.
- On the Members tab page of the user group details page, click Delete in the Operation column to delete a user from the user group. For details, see Deleting a User Group.
- Applications that the user group has been authorized to access, including the logo and application name.
If you click Delete in the Operation column of the row that contains an application, the user group will be automatically deleted from the account authorization policy of the application. Then, member addition and deletion for the user group will be automatically synced to the application.
- Audit Logs
Administrators' operations on the user group, such as group creation and member addition. You can filter data by time, administrator username, or name.
Modifying User Group Information
- In the user group list, click Modify to the right of the user group.
- In the Modify User Group dialog box, modify the name and description of the user group. The organization to which the user group belongs cannot be changed.
- Confirm the configuration.
Add members of different organizations to a user group for easy management and authorization. For details about user group-based authorization, see Configuring Authorization Policies for Application Accounts.
- In the user group list, click Add Member in the Operation column.
- On the Add Member page, select the top organization, select users under the organization, and click OK.
In the user group list, click Delete in the row that contains the target user group and click OK. Deleting a user group will not delete the users, but will affect their application permissions. For details about user-based authorization, see Configuring Authorization Policies for Application Accounts.
