Post-Processing the Recognition Results
Extracting Specific Fields and Importing Them to an Excel File
In this example, the API of ID Card OCR is called, the required fields are extracted from the obtained JSON results, and the fields are filled in an Excel file.
- Prerequisites
- You have subscribed to Passport OCR by referring to Subscribing to an OCR Service.
- You have installed the OCR Python SDK by referring to Calling an OCR API Locally and have installed dependency packages by running the pip install xlsxwriter command.
- You have obtained the AK and SK by accessing the Access Keys page. On this page, you can create an access key or use an existing one. The AK and SK are contained in the credentials.csv file.
- Sample code
# -*- coding: utf-8 -*- import base64 import xlsxwriter from huaweicloudsdkcore.auth.credentials import BasicCredentials from huaweicloudsdkocr.v1.region.ocr_region import OcrRegion from huaweicloudsdkcore.exceptions import exceptions from huaweicloudsdkocr.v1 import * from huaweicloudsdkcore.http.http_config import HttpConfig def recognize_id_card_request(): try: request = RecognizeIdCardRequest() request.body = IdCardRequestBody( image=image_base64 ) response = client.recognize_id_card(request) return response except exceptions.ClientRequestException as e: print(e.status_code) print(e.request_id) print(e.error_code) print(e.error_msg) def get_credential(): return BasicCredentials(ak, sk) def get_client(): config = HttpConfig.get_default_config() config.ignore_ssl_verification = True return OcrClient.new_builder(OcrClient) \ .with_credentials(credentials) \ .with_region(OcrRegion.CN_NORTH_4) \ .with_http_config(config) \ .build() def image_to_base64(imagepath): """ Convert a local image into Base64 code. """ with open(imagepath, "rb") as bin_data: image_data = bin_data.read() base64_data = base64.b64encode(image_data).decode("utf-8") return base64_data def response_to_execl(save_file, data): """ :param save_file: File name :param data: result data """ # Process the result data returned after the API is called. keys_list = list(data["result"].keys()) values_list = list(data["result"].values()) options = {'in_memory': True} with xlsxwriter.Workbook(save_file, options) as workbook: worksheet = workbook.add_worksheet() worksheet.set_column('A1:A20', 23) worksheet.set_column('B1:B20', 100) worksheet.write_column('A1', keys_list) worksheet.write_column('B1', values_list) workbook.close() if __name__ == '__main__': # Enter the AK and SK. ak = "Enter the AK." sk = "Enter the SK." # Init Auth Info credentials = get_credential() # Create OcrClient client = get_client() image_base64 = image_to_base64 (r"Image path, for example, D:\local\test.png") # request id card service response = recognize_id_card_request().to_dict() # Store the data in the Excel file. response_to_execl(r"Excel file path, for example, D:\local\test.xlsx", response)
Extracting Text from a PDF File
In this example, a PDF file is converted into images and the Web Image OCR API is called to obtain the recognition result.
- Prerequisites
- You have installed the OCR Python SDK by referring to Calling an OCR API Locally and have installed dependency packages by running the pip install fitz and pip install PyMuPDF==1.18.0 commands.
- Sample code
# -*- coding: utf-8 -*- import os import base64 import fitz import io from PIL import Image from glob import glob from huaweicloudsdkcore.auth.credentials import BasicCredentials from huaweicloudsdkocr.v1.region.ocr_region import OcrRegion from huaweicloudsdkcore.exceptions import exceptions from huaweicloudsdkocr.v1 import * from huaweicloudsdkcore.http.http_config import HttpConfig class CovertPdfToJpg: def __init__(self, file_path, save_root): self.file_path = file_path self.save_root = save_root @staticmethod def open_pdf(file): return fitz.open(file) @staticmethod def get_trans(doc, page, min_side=0, max_side=0, rotate=0.0): """ Create a scale object. """ region = doc[page].rect scale = 1 if max_side > min_side > 0: scale = min_side / min(region.width, region.height) if max(region.width, region.height) * scale > max_side: scale = max_side / max(region.width, region.height) trans = fitz.Matrix(scale, scale).preRotate(rotate) return trans def page2pix(self, doc, page, trans): """ Parse the current page as image data based on given parameters.""" return doc[page].getPixmap(matrix=trans, alpha=False) def pdf_to_jpg(self, width=1024, height=1400): """ Convert PDF images to JPG images.""" doc = self.open_pdf(self.file_path) save_dir = os.path.join(self.save_root) if not os.path.exists(save_dir): os.makedirs(save_dir) print("document", len(doc), doc.pageCount) for i in range(len(doc)): trans = self.get_trans(doc, i, width, height, rotate=0) try: pdf = self.page2pix(doc, i, trans) except: continue image = pdf.getPNGData() image = Image.open(io.BytesIO(image)) print(os.path.join( save_dir, os.path.basename(self.file_path).replace('.pdf', '') + '_' + str(i + 1) + '.jpg')) image.save( os.path.join(save_dir, os.path.basename(self.file_path).replace('.pdf', '') + '_' + str(i + 1) + '.jpg')) return def recognize_general_text_request(): try: request = RecognizeGeneralTextRequest() request.body = GeneralTextRequestBody( image=image_base64 ) response = client.recognize_general_text(request) print(response) except exceptions.ClientRequestException as e: print(e.status_code) print(e.request_id) print(e.error_code) print(e.error_msg) def get_credential(): return BasicCredentials(ak, sk) def get_client(): config = HttpConfig.get_default_config() config.ignore_ssl_verification = True return OcrClient.new_builder(OcrClient) \ .with_credentials(credentials) \ .with_region(OcrRegion.CN_NORTH_4) \ .with_http_config(config) \ .build() def url_to_base64(imagepath): with open(imagepath, "rb") as bin_data: image_data = bin_data.read() base64_data = base64.b64encode(image_data).decode("utf-8") return base64_data if __name__ == '__main__': # Enter the AK and SK. ak = "Enter the AK." sk = "Enter the SK." # Init Auth Info credentials = get_credential() # Create OcrClient client = get_client() df_path = r"Local PDF file path, for example, D:\local\test.pdf" save_path = r"Path of the converted image, for example, D:\local" covert_pdf_to_jpg = CovertPdfToJpg(df_path, save_path) covert_pdf_to_jpg.pdf_to_jpg() jpgs = glob(os.path.join(save_path, "*.jpg")) for jpg in jpgs: image_base64 = url_to_base64(jpg) recognize_general_text_request()
If the error message "AttributeError: 'Document' object has no attribute 'pageCount'" is displayed, uninstall the PyMuPDF dependency package and install version 1.18.0 instead.
