- What's New
- Function Overview
- Product Bulletin
Billing
- Billing Overview
- Billing Modes
- Billing Items
- Billing Examples
- Billing Mode Changes
- Renewing Subscriptions
- Bills
- Arrears
- Billing Termination
- Cost Management
Billing FAQ
- Why Do I Get Additional Charges or Arrears After Purchasing a Package?
- Why Can I Still Call the Service and Incur Arrears When My Account Balance Is Zero?
- Why Do I Get Additional Charges or Arrears After Unsubscribing from an OCR Service?
- Can I Refund a Package After I Buy It?
- How Is Billing Handled When a Package Is Used Up? And How Can I Check the Remaining Quota and Receive Alerts for My Package?
- How Does a Member Account Use a Package Purchased by an Enterprise Master Account?
- What Is Fee Deduction Order for Multiple Packages?
- What are Grace Period and Retention Period?
- What Is Considered Valid Billing for OCR?
- Can Different API Packages Be Shared?
- Can OCR Be Charged by Project?
- Getting Started
- User Guide
- SDK Reference
- API Reference
- Subscription
Token-based Authentication
- What Are the Username, Domain Name, and Project Name in the Token Message Body?
- Why Is the Error Message "The account is locked." Displayed?
- Why Is the Error Message "The username or password is wrong." Displayed?
- Why Does the Token Retrieval Process Return a 401 Status Code?
- Why Does the Token Fail to Be Obtained When I Use Postman to Call an ORC API?
- Why Don't I Have Programming Access Permissions?
- Why Does the Header Overflow When I Use Postman to Call an OCR API?
API
- How Do I View the API Usage?
- Why Is the Actual Number of API Calls Inconsistent with the Record Displayed on the Management Console?
- Does OCR Support Batch Processing?
- Can the OCR Results Be Converted into Word, TXT, or PDF Files?
- How Do I Obtain the Base64 Code of an Image?
- What Is the Number of Concurrent OCR API Calls?
- How Do I Use OCR APIs?
- Can the Region Where OCR Is Called Be Different from the Region Where OBS Resources Are Located?
- Can the Input Data of OCR Be Stored Locally?
- How Do I Improve the Recognition Speed?
- How Do I Convert a PDF to an Image?
- Can OCR Read Images from Non-Huawei Cloud Storage?
SDK
- Do OCR SDKs Need to Be Purchased?
- Do OCR SDKs Need Maven to Manage Dependency Packages?
- How Do I Change the Response Type in Returned Results?
- How Can I Fix an SSL Configuration Error?
- How Can I Fix a "connect timed out" Error?
- Why Does the Project ID Fail to Be Obtained?
- What Should I Do if I Forget My AK and SK?
Error Code
- Why Do I Fail to Call an OCR API?
- How Do I Handle the Error APIG.0301?
- How Do I Handle the Error APIG.0201?
- How Do I Handle the Error APIG.0101?
- How Do I Handle the Error APIG.0106?
- How Do I Handle the Error APIG.0308?
- How Do I Handle the Error ModelArts.0212?
- How Do I Handle the Error ModelArts.4603 or ModelArts.4704?
- How Do I Handle the Error ModelArts.4204?
- Permissions
- Data Security and Privacy
- Regions and AZs
- General Consulting
- Videos
- Glossary
- More Documents
Show all
Performing Online Debugging
API Explorer, the online debugging tool provides API retrieval, debugging, and code example generation. Additionally, you can build, debug, and run code in CloudIDE.
This section uses Passport OCR as an example to walk you through how you can use API Explorer to debug an API.
- You have registered a Huawei ID, enabled Huawei Cloud services, and completed real-name authentication. Your account cannot be in arrears, frozen, or deregistered.
- You have subscribed to General Text OCR by referring to Subscribing to an OCR Service.
- Log in to API Explorer.
After the login, the X-Auth-Token and project_id parameters are automatically set.
- Enter the data of the image to be detected.
The input data can be an image or a URL.
- Click Debug to obtain the recognition results.
Figure 1 Recognition results
