Lifecycle Configuration Examples
If you use APIs or SDKs, refer to the XML example.
Specifying a Rule with a Single Filter Condition
Example 1: Applying a lifecycle rule to all objects in a bucket
To apply the rule to all objects in the bucket, leave the prefix blank. Objects will be transitioned to the Archive storage class 100 days after creation.
XML:
1 2 3 4 5 6 7 8 9 10 11 |
<LifecycleConfiguration> <Rule> <ID>sample-rule</ID> <Prefix></Prefix> <Status>Enabled</Status> <Transition> <Days>100</Days> <StorageClass>COLD</StorageClass> </Transition> </Rule> </LifecycleConfiguration> |
Example 2: Specifying a filter by object name prefix
The following lifecycle rule specifies prefix texta/ as the filter. It applies to objects with the texta/ prefix, such as texta/file1.txt and texta/file2.txt.
This rule specifies two actions: transitioning objects to the Infrequent Access storage class 90 days after creation and deleting objects 120 days after creation.
XML:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 |
<LifecycleConfiguration> <Rule> <ID>sample-rule</ID> <Status>Enabled</Status> <Prefix>texta/</Prefix> <Transition> <Days>90</Days> <StorageClass>WARM</StorageClass> </Transition> <Expiration> <Days>120</Days> </Expiration> </Rule> </LifecycleConfiguration> |
Example 3: Specifying a filter by object name prefix and deleting the specified objects that was last modified before the specified date
This rule specifies one action: deleting objects that were last modified before May 30, 2024.
XML:
1 2 3 4 5 6 7 8 9 10 |
<LifecycleConfiguration> <Rule> <ID>sample-rule</ID> <Status>Enabled</Status> <Prefix>texta/</Prefix> <Expiration> <Date>2024-05-30T00:00:00.000Z</Date> </Expiration> </Rule> </LifecycleConfiguration> |
Example 4: Specifying a filter by object name prefix and transitioning the specified objects that was last modified before the specified date
This rule specifies one action: transitioning objects that were last modified before May 30, 2024 to the Archive storage class.
XML:
<LifecycleConfiguration> <Rule> <ID>sample-rule</ID> <Status>Enabled</Status> <Prefix>texta/</Prefix> <Transition> <Date>2024-05-30T00:00:00.000Z</Date> <StorageClass>COLD</StorageClass> </Transition> </Rule> </LifecycleConfiguration> |
Specifying a Rule with Multiple Filter Conditions
To use multiple filters in a single rule, you must wrap the filters in an And element.
Example 1: Specifying a rule with multiple filter conditions
- The following rule deletes objects with the texta/ prefix and with tags key1/value1 and key2/value2 120 days after their creation.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
<LifecycleConfiguration> <Rule> <ID>sample-rule</ID> <Filter> <And> <Prefix>texta/</Prefix> <Tag> <Key>key1</Key> <Value>value1</Value> </Tag> <Tag> <Key>key2</Key> <Value>value2</Value> </Tag> </And> </Filter> <Status>Enabled</Status> <Expiration> <Days>120</Days> </Expiration> </Rule> </LifecycleConfiguration>
Specifying Multiple Rules
If you want objects to have different lifecycle actions, you can specify multiple rules. The following lifecycle configuration has two rules:
- Rule 1 applies to objects with the texta/ prefix. It directs OBS to transition objects to the Archive storage class 120 days after creation and to delete them 360 days after creation.
- Rule 2 applies to objects with the textb/ prefix. It directs OBS to transition objects to the Infrequent Access storage class 90 days after creation and to delete them 120 days after creation.
XML:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 |
<LifecycleConfiguration> <Rule> <ID>sample-rule1</ID> <Prefix>texta/</Prefix> <Status>Enabled</Status> <Transition> <Days>120</Days> <StorageClass>COLD</StorageClass> </Transition> <Expiration> <Days>360</Days> </Expiration> </Rule> <Rule> <ID>sample-rule2</ID> <Prefix>textb/</Prefix> <Status>Enabled</Status> <Transition> <Days>90</Days> <StorageClass>WARM</StorageClass> </Transition> <Expiration> <Days>120</Days> </Expiration> </Rule> </LifecycleConfiguration> |
Specifying Multiple Rules with Overlapping Filter Conditions
Example 1: Overlapping prefixes (no conflict)
- Rules: Rule 1 specifies an empty filter (indicating all objects in the bucket). It lets OBS delete all objects 120 days after creation. Rule 2 specifies the typea/ prefix (indicating objects with the typea/ prefix). It lets OBS transition objects to the Archive storage class 90 days after creation.
- Result: There are no conflicting lifecycle actions. Objects with the typea/ prefix are transitioned to the Archive storage class 90 days after creation and then deleted 120 days after creation.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 |
<LifecycleConfiguration> <Rule> <ID>sample-rule1</ID> <Prefix></Prefix> <Status>Enabled</Status> <Expiration> <Days>120</Days> </Expiration> </Rule> <Rule> <ID>sample-rule2</ID> <Prefix>typea/</Prefix> <Status>Enabled</Status> <Transition> <Days>90</Days> <StorageClass>COLD</StorageClass> </Transition> </Rule> </LifecycleConfiguration> |
Example 2: Conflicting prefixes and tags (no conflict)
- Rules: Rule 1 specifies the ab prefix and a tag (key1/value1). It lets OBS delete objects 120 days after creation. Rule 2 specifies the abc prefix and two tags (key1/value1 and key2/value2). It lets OBS transition objects to the Archive storage class 90 days after creation.
- Result: There are no conflicting lifecycle actions. Objects with the abc prefix and with tags key1/value1 and key2/value2 are transitioned to the Archive storage class 90 days after creation and then deleted 120 days after creation.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39
<LifecycleConfiguration> <Rule> <ID>sample-rule1</ID> <Filter> <And> <Prefix>ab</Prefix> <Tag> <Key>key1</Key> <Value>value1</Value> </Tag> </And> </Filter> <Status>Enabled</Status> <Expiration> <Days>120</Days> </Expiration> </Rule> <Rule> <ID>sample-rule2</ID> <Filter> <And> <Prefix>abc</Prefix> <Tag> <Key>key1</Key> <Value>value1</Value> </Tag> <Tag> <Key>key2</Key> <Value>value2</Value> </Tag> </And> </Filter> <Status>Enabled</Status> <Transition> <Days>90</Days> <StorageClass>COLD</StorageClass> </Transition> </Rule> </LifecycleConfiguration>
Example 3: Overlapping prefixes resulting in conflicting lifecycle actions
- Rules: Rule 1 specifies an empty filter (indicating all objects in the bucket). It lets OBS delete all objects 90 days after creation. Rule 2 specifies the typea/ prefix (indicating objects with the typea/ prefix). It lets OBS transition objects to the Archive storage class 120 days after creation.
- Result: The lifecycle actions conflict. Such configuration is not allowed.
<LifecycleConfiguration> <Rule> <ID>sample-rule1</ID> <Prefix></Prefix> <Status>Enabled</Status> <Expiration> <Days>90</Days> </Expiration> </Rule> <Rule> <ID>sample-rule2</ID> <Prefix>typea/</Prefix> <Status>Enabled</Status> <Transition> <Days>120</Days> <StorageClass>COLD</StorageClass> </Transition> </Rule> </LifecycleConfiguration>
Example 4: Overlapping prefixes and tags resulting in conflicting lifecycle actions
- Rules: Rule 1 specifies the abc prefix and a tag (key1/value1). It lets OBS delete objects 90 days after creation. Rule 2 specifies the ab prefix and two tags (key1/value1 and key2/value2). It lets OBS transition objects to the Archive storage class 120 days after creation.
<LifecycleConfiguration> <Rule> <ID>sample-rule1</ID> <Filter> <And> <Prefix>abc</Prefix> <Tag> <Key>key1</Key> <Value>value1</Value> </Tag> </And> </Filter> <Status>Enabled</Status> <Expiration> <Days>90</Days> </Expiration> </Rule> <Rule> <ID>sample-rule2</ID> <Filter> <And> <Prefix>ab</Prefix> <Tag> <Key>key1</Key> <Value>value1</Value> </Tag> <Tag> <Key>key2</Key> <Value>value2</Value> </Tag> </And> </Filter> <Status>Enabled</Status> <Transition> <Days>120</Days> <StorageClass>COLD</StorageClass> </Transition> </Rule> </LifecycleConfiguration>
Deleting Fragments
The following lifecycle rule specifies prefix texta/ as the filter. It applies to objects with the texta/ prefix, such as texta/file1.txt and texta/file2.txt. This rule lets OBS delete object fragments 10 days after generation.
</LifecycleConfiguration> <Rule> <ID>sample-rule</ID> <Prefix>texta/</Prefix> <Status>Enabled</Status> <AbortIncompleteMultipartUpload> <DaysAfterInitiation>10</DaysAfterInitiation> </AbortIncompleteMultipartUpload> </Rule> </LifecycleConfiguration> |
Specifying a Lifecycle Rule for a Versioning-Enabled/Suspended Bucket
Example 1: Periodically transitioning and deleting historical object versions
The following lifecycle rule specifies prefix prefix1/ as the filter. It applies to objects with the prefix1/ prefix, such as prefix1/file1.txt and prefix1/file2.txt.
This rule specifies two lifecycle actions: transitioning historical object versions to the Archive storage class 20 days after generation and deleting them 30 days after generation.
<LifecycleConfiguration> <Rule> <ID>sample-rule</ID> <Prefix>prefix1/</Prefix> <Status>Enabled</Status> <NoncurrentVersionTransition> <NoncurrentDays>20</NoncurrentDays> <StorageClass>COLD</StorageClass> </NoncurrentVersionTransition> <NoncurrentVersionExpiration> <NoncurrentDays>30</NoncurrentDays> </NoncurrentVersionExpiration> </Rule> </LifecycleConfiguration> |
Example 2: Removing expired delete markers
If all versions of an object with the prefix1/ prefix have been deleted and only one expired delete marker remains, this rule lets OBS remove this expired delete marker.
</LifecycleConfiguration> <Rule> <ID>sample-rule</ID> <Prefix>prefix1/</Prefix> <Status>Enabled</Status> <Expiration> <ExpiredObjectDeleteMarker>true</ExpiredObjectDeleteMarker> </Expiration> </Rule> </LifecycleConfiguration> |
Disabling a Lifecycle Rule
The following configuration disables a lifecycle rule. This rule applies to objects with the texta/ prefix and transitions objects to the Archive storage class 100 days after creation.
XML:
<LifecycleConfiguration> <Rule> <ID>sample-rule</ID> <Status>Disabled</Status> <Prefix>texta/</Prefix> <Transition> <Days>100</Days> <StorageClass>COLD</StorageClass> </Transition> </Rule> </LifecycleConfiguration> |
