Using Lifecycle Rules to Delete or Transition Objects
This section describes how to periodically transition objects between storage classes or delete objects through lifecycle rules.
Because multi-AZ redundancy is not supported for Archive and Deep Archive storage, you cannot transition objects in a multi-AZ bucket to Archive or Deep Archive through lifecycle rules.
Transitioning Objects Using Lifecycle Rules
As shown in Figure 1, OBS allows you to use lifecycle rules to transition objects as follows:
- From Standard to Infrequent Access, Archive, or Deep Archive
- From Infrequent Access to Archive or Deep Archive
- From Archive to Deep Archive
When a lifecycle rule is applied, OBS transitions objects based on the versioning state of your bucket.
Each object in an unversioned bucket has only one version. You can use lifecycle rules to transition such objects.
| Action Type | Effect of Action | Timer Start Time |
| Transitioning between storage classes | The object is transitioned to the target storage class. | Time when an object is uploaded |
If versioning is not enabled for a bucket, there are no historical versions in the bucket. Therefore, the NoncurrentVersionTransition field is invalid.
You can use lifecycle rules to transition the current and historical versions of objects in a versioning-enabled bucket.
| Transitioning the current version |
| Time when the current version is uploaded |
| Transitioning a historical version |
| Time when the current version becomes a historical version |
You can use lifecycle rules to transition the current and historical versions of objects in a versioning-suspended bucket.
Deleting Objects Using Lifecycle Rules
OBS uses lifecycle rules to delete objects based on the versioning state of your bucket.
If versioning is not enabled for a bucket, each object has only one version. You can use lifecycle rules to delete objects and fragments from this bucket.
| Deleting an object | The object is permanently deleted and cannot be restored. |
| Deleting fragments | The fragments are permanently deleted and cannot be restored. |
If versioning is not enabled for a bucket, the bucket does not have historical versions or delete markers. Therefore, the NoncurrentVersionExpiration and ExpiredObjectDeleteMarker fields are invalid.
You can use lifecycle rules to delete the current version, historical versions, expired delete markers, and fragments of objects from a versioning-enabled bucket.
| Deleting the current version of an object |
| Deleting a historical version of an object | The historical version is deleted and cannot be restored. |
| Deleting an expired delete marker | The expired delete marker is deleted. After all historical versions of an object are deleted, the current delete marker version will be deleted to improve the List performance. |
You can use lifecycle rules to delete the current version, historical versions, expired delete markers, and fragments of objects from a versioning-suspended bucket.
| Deleting an expired delete marker | The expired delete marker of the object is deleted. After all historical versions of an object are deleted, the current delete marker version will be deleted to improve the List performance. |
Overlapping Lifecycle Rules
OBS allows you to configure multiple lifecycle rules for a single bucket. Multiple lifecycle rules may overlap. For example:
- If a rule has no prefix specified, this rule overlaps with any other rules.
- If two rules have the same prefix, they overlap.
- If the prefix of a rule is the substring of another rule's prefix, the rules overlap.
If a rule to be created overlaps with an existing one, the rule must meet the following requirements or it will fail to be created:
- The prefix and the tag cannot be the same as those of the existing rule at the same time.
- The rule uses either Days or Date.
- The actions on an object take place in the following order: Transition to Infrequent Access > Transition to Archive > Transition to Deep Archive > Delete the object upon expiration.
- Overlapping rules cannot be configured with the same action. For example, you cannot have two rules that both delete objects or two rules that both transition objects to Infrequent Access, Archive, or Deep Archive.
- If there is an overlapping rule, the settings for deleting expired versions, fragments, and expired delete markers cannot be configured at the same time. Otherwise, there will be conflicts. For example:
Precautions
- Encrypted objects remain encrypted when their storage class is transitioned.
- Minimum storage duration
The minimum storage duration is the minimum billable storage duration. This means that objects will be billed for the minimum storage duration even if they are not stored for that long. For example, if an object is transitioned to Archive after being stored in Infrequent Access for 20 days, it will be billed for the storage of 30 days (the minimum storage duration for Infrequent Access).
Item
Standard
Infrequent Access
Archive
Deep Archive
N/A
30 days
90 days
180 days
Related Operations
How Do I Check Whether an Object Version Has a Delete Marker?
- In the navigation pane of OBS Console, choose Buckets.
- In the bucket list of OBS Console, click the desired bucket to go to the Objects page.
- Enable Historical Version to check whether the versions of the object have a delete marker.
You can also use the API for listing objects in a bucket or the following SDKs to check whether an object version has a delete marker:
