Updated on 2025-09-15 GMT+08:00
Deleting Fragments
Fragments are the incomplete data in buckets. When data is uploaded to OBS using a multipart upload, there will be fragments generated if the multipart upload fails because of the following and other possible causes:
  • Frequent disconnections from the OBS server due to poor network conditions
  • Manual upload interruptions
  • Device failures
  • Sudden power outages
Fragments generated from upload failures are stored in OBS. You can manually delete the fragments by following the instructions provided in this section. You can also resume the interrupted or failed multipart upload to remove the fragments.
  • If there are fragments left in your bucket, your attempt to delete the bucket will fail. In such case, delete all of the fragments first.
  • The storage of fragments is billable. If expenditures are stilled generated even if there are no objects in your bucket, check whether there are fragments in it and delete them (if any).
Billing
You will be billed for storing fragments in OBS.
Ways to Delete Fragments
You can use OBS Console, APIs, SDKs, OBS Browser+, or obsutil to delete fragments.
Related Operations
OBS allows you to manage tasks. If a multipart upload fails or is interrupted, you can resume it with the following tools. Once the upload is completed, fragments will disappear.
Table 1 Tools for deleting fragments
Tool
Operation Guide
OBS Browser+
On OBS Browser+, run the upload task that generates the fragments. Once it completes, fragments are cleared.
For details, see Managing Failed Tasks and Managing Suspended Tasks.
obsutil
With obsutil, you can resume a failed upload based on its task ID recorded in the result list. After the upload is completed, the fragments will disappear.
For details, see Resuming a Failed Upload.
OBS SDKs
OBS SDKs provide resumable upload by recording the upload progress. You can read the recorded progress and resume an interrupted or failed multipart upload.
For details, see the section about resumable upload in the SDK Reference.
