- User Guide
- Best Practices
- FAQs
Show all
Viewing Intelligence Details
This section describes how to view the details about an imported intelligence file, including the file name, intelligence type, file format, and upload time.
You have imported a threat intelligence file. For details about how to import threat intelligence, see Importing a Threat Intelligence File.
- Click
in the upper left corner of the management console and select a region or project.
- Click
in the navigation pane on the left and choose Security & Compliance > Managed Threat Detection.
Figure 1 Home page of MTD - Choose Settings > Threat Intelligence in the left navigation pane.
- View details about an imported intelligence file. Table 1 describes the detailed information about an intelligence file.
Table 1 Intelligence file information Parameter
File Name
Name of an intelligence file
Intelligence Type
Content type of the intelligence file, which can be IP and domain name.
Format
Format of an intelligence file. Currently, only plaintext files are supported. For details, see How Do I Edit and Upload a Plaintext File to OBS?
Uploaded
Time when an information file is uploaded
