Help Center/ Migration Center/ User Guide/ Application Migration Projects/ Migration Workflows/ Creating a Batch File Storage Migration Workflow
Updated on 2026-05-22 GMT+08:00
This section describes how to create a workflow from a template to efficiently migrate file systems in batches.
Warnings
When you create a workflow, there are three options for Overwrite Existing: Never, Always, and If older or different size. If you choose Never, restarting a migration after an interruption or pause may lead to incomplete data migration, even though the task may appear successful. This could impact data integrity, so use the Never option with caution.
A batch file storage migration plan has been created for the source file systems to be migrated.
  1. Sign in to the MgC console. In the navigation pane, under Project, select your application migration project from the drop-down list.
  2. In the navigation pane, choose Workflows.
  3. Click Create Workflow in the upper right corner of the page.
  4. In the Batch File Storage Migration card, click Preview Steps to view the stages and steps predefined in the template and the detailed description of each stage and step. Automated steps are handled by the system. Click Configure Workflow in the lower right corner.
  5. In the Basic Information area, enter a name and description for the workflow.
  6. In the Migration Plan area, select the created migration plan. Then you should view the overview of the migration plan. Click View Details to view more information about the plan.
  7. In the Migration Cluster area, select the cluster used for the migration. The cluster specified in the migration plan is preselected by default, but you can select another one if needed. The modification is applied to the current workflow but not to the migration plan.
  8. Configure migration settings based on Table 1.
    Table 1 Migration settings
    Sub-Parameter
    Concurrent Subtasks
    User-defined. There cannot be more than 10 concurrent subtasks for each online migration node. For example, if there are 2 online migration nodes, there can be up to 20 subtasks.
    Overwrite Existing
    Never
    Files existing at the target will never be overwritten.
    WARNING:
    • If you choose Never for the initial migration, the attributes of involved parent folders at the source will not be migrated to the target. As a result, the folder attributes may be incomplete at the target. This could impact data integrity, so use the Never option with caution for the initial migration.
    • If you choose Never, restarting a migration after an interruption or pause may lead to incomplete data migration, even though the task may appear successful. This could impact data integrity, so use the Never option with caution.
    Always
    Files existing at the target will always be overwritten.
    • The system replaces existing target files if they are older than or differ in size from their source counterparts. Files with matching modification times and sizes remain unchanged and are skipped during migration.
    • The system verifies folders after their content is migrated. Folders that already exist at the target are overwritten if they have different last modification times, sizes, or permissions from the paired folders at the source.
      The same overwriting policy is applied to empty folders as files.
    Migrate Metadata
    Determine whether to migrate metadata.
    • If you select this option, object metadata will be migrated.
    • If you do not select this option, only the Content-Type and Content-Encoding metadata will be migrated.
  9. (Optional) Configure advanced options based on Table 2.
    Table 2 Advanced options
    Sync Incremental Before Cutover
    • If you select Yes, an incremental migration step will be automatically added after the migration verification step in the migration phase.
    • If you select No, the service cutover phase starts after the migration verification step in the migration phase is complete.
    Filter Source Data
    Use exclude patterns, include patterns, and time ranges to filter files to be migrated. For details about the filters, see Source Data Filters.
    Send SMN Notifications
    Determine whether to use SMN to get notifications about migration results.
    • If you do not select this option, no SMN messages will be sent after the migration is complete.
    • If you select this option, after the migration is complete, SMN messages will be sent to the subscribers of the selected topic. You can select the language and trigger conditions for sending messages.
    Limit Traffic
    Set the maximum bandwidth for the migration task during different periods.
    • If you do not select this option, migration traffic will not be limited.
    • If you select this option, limit the migration traffic by setting Start Time, End Time, and Bandwidth Limit.
      For example, if you set Start Time to 08:00, End Time to 12:00, and Bandwidth Limit to 20 MB/s, the maximum migration speed is limited to 20 MB/s from 08:00 to 12:00. The migration speed is not limited beyond this period.
      • The bandwidth limit ranges from 1 MB/s to 1,048,576 MB/s.
      • A maximum of five rules can be added.
      • The time is the local standard time of the region you are migrating to.
  10. Click Next: Confirm.
  11. Confirm the workflow settings and click Confirm. The Run Workflow dialog box is displayed, which indicates that the workflow has been created.
    • If you want to start the migration immediately, click Confirm to run the workflow.
    • If you want to add a stage or step to the workflow, click Cancel. The workflow enters a Waiting state, and the migration has not started yet. To start the migration, click Run in the Operation column.
  12. In the workflow list, click the workflow name to go to its details page. You can view the configuration information and migration progress of the workflow. You can also perform the operations below.
    • Move the cursor to the migration progress bar of a resource. In the displayed window, view the migration details about the resource.
    • When a migration reaches a step that requires manual confirmation, place the cursor on the progress bar and click Confirm next to the step status in the displayed window. The migration can continue only after you confirm.
    • In the Basic Information area, click Manage next to the cluster name. The cluster details page is displayed on the right. On the displayed page, you can:
      • Add, edit, or delete traffic limiting rules to control cluster traffic based on your requirements.
      • Add or delete migration nodes or list nodes, or upgrade plug-ins for existing nodes as required.
