Updated on 2025-08-19 GMT+08:00
Creating an Executor Connection
Executors are used to obtain data for consistency verification from the source and the target.
You need to connect the source and target executors to MgC, so that they can receive and execute commands from MgC. The supported big data components include:
  • Hive Metastore
  • Delta Lake (with metadata)
  • Delta Lake (without metadata)
  • Hudi (with metadata)
  • Hudi (without metadata)
  • Ensure that CLI clients are installed on both the source and target executors.
  • You need to create connections to both the source and target executors.
  1. Sign in to the MgC console. In the navigation pane, under Project, select your big data migration project from the drop-down list.
  2. In the navigation pane, choose Migrate > Big Data Verification.
  3. In the Features area, click Migration Preparations.
  4. Choose Connection Management and click Create Connection.
    Figure 1 Creating a connection
  5. Select an executor, click Next, and set connection parameters based on Table 1.
    Table 1 Parameters for creating an executor connection
    Configuration
    Connection To
    Select an option as required.
    NOTICE:
    The CDH executor supports only the migration source. The MRS executor supports both the migration source and target.
    Connection Name
    The default name is Executor type-4 random characters (including letters and numbers). You can also customize a name.
    MgC Agent
    Select the MgC Agent installed in the source environment.
    Executor Credential
    Select the login credential of the executor. For details about how to add credentials, see "Big data - Executor" in Adding Resource Credentials.
    Executor IP Address
    Enter the IP address for connecting to the executor.
    Executor Port
    Enter the port for connecting to the executor. The default port is 22.
    Installation Directory
    Enter the installation directory of the MRS or CDH client. That is, the directory where ./install.sh is installed.
    SQL File Location
    Enter a directory for storing the SQL files generated for consistency verification. You must have the read and write permissions for the directory.
    NOTICE:
    After the verification is complete, you need to manually clear the folders generated at this location to release storage space.
  6. Click Test. MgC verifies whether the executor can be connected using the configuration information. If the test is successful, the executor can be connected.
  7. After the connection test is successful, click Confirm. The executor connection is created.
  8. On the Connection Management page, view the created connection and its basic information. In the Operation column, click Modify to modify the connection settings.
