Updated on 2026-09-20 GMT+08:00
Creating a Migration Cluster
A migration cluster is a core component for storage workflows. It allows you to create and manage migration nodes, list nodes, and deploy and upgrade migration plugins, ensuring smooth operations of storage workflows.
For clusters running version 25.2.1.2 or earlier, upgrades, deployments, or node additions are not supported. They also cannot be used for migration.
Precautions
  • A maximum of two migration clusters can be created in each region in an account.
  • If a migration cluster is idle for more than 30 days, its status will change to Discarded. The cluster will not be deleted but cannot be restored.
  • You can see the details about resources contained in a migration cluster and the security group settings of all cluster nodes in Migration Cluster Resources and Settings.
Billing
You are billed at standards rates for migration clusters and additional resources used during migrations.
  1. Sign in to the MgC console. In the navigation pane, under Project, select your application migration project from the drop-down list.
  2. In the navigation pane on the left, choose Other > Migration Clusters.
  3. Click Create Cluster in the upper right corner of the page.
    If this is your first time to create a migration cluster, you need to assign MgC the required permissions. Click to view the permissions to be assigned.
  4. Configure the parameters based on Table 1.
    Table 1 Parameters for creating a cluster
    Area
    Configuration
    Basic Settings
    Cluster Name
    User-defined
    The cluster name must be unique in the same account.
    Region
    Select the region to provision the cluster.
    The cluster must be provisioned in the target region you are migrating to.
    Cluster Type
    Select what the cluster will be used for.
    Currently, only storage migration is supported.
    Node Settings
    Key Pair
    It is used for identity authentication when you remotely log in to the nodes (ECSs) in the cluster. You need to create a key pair in advance. For details, see Creating a Key Pair.
    Enterprise Project
    This function is provided for enterprise users. You can add the ECS to an enterprise project. If no enterprise projects are available, the system creates the default enterprise project.
    An enterprise project facilitates project-level management and grouping of cloud resources and users. The default project is default.
    For details about how to create and manage enterprise projects, see Enterprise Management User Guide.
    Master Node Specifications
    It is used to manage migration nodes and list nodes.
    A cluster can only have one master node.
    Migration Node Specifications
    Migration nodes are used for executing migration and verification tasks. The recommended specifications are 8 vCPUs and 16 GB of memory.
    • The node specifications cannot be modified after the cluster is created.
    • The number of nodes must meet the following requirements:
      • Number of migration nodes + Number of list nodes + 1 ≤ 100
      • Number of migration nodes + Number of list nodes + 1 ≤ Number of unused IP addresses in the subnet
    List Node Specifications
    List nodes are used for listing tasks. The recommended specifications are 8 vCPUs and 16 GB of memory.
    Network Settings
    VPC
    Select a VPC from the drop-down list.
    Subnet
    Make sure that there are enough unused IP addresses for the migration and list nodes in this cluster.
    Number of unused IP addresses in the subnet ≥ Number of migration nodes + Number of list nodes + 1
    Network Type
    • Internet: You need to select a public NAT gateway. If there is no gateway available, choose Buy Gateway from the drop-down list and select the gateway specifications and EIPs you want to associate with the gateway. A maximum of 20 EIPs can be selected at a time.
    • Intranet: This option is suitable for data migration within a region.
    • Private line: Source data is directly accessed through the private line. For details about how to set up a Direct Connect connection, see Direct Connect Best Practices.
    Advanced Settings
    DNS Configuration (Optional)
    Enter the IP address of the DNS server to update the value of nameserver in the /etc/resolv.conf file. Use commas (,) to separate multiple DNS server addresses, for example, 192.0.2.1,192.0.2.2.
    A maximum of three DNS IP addresses can be specified.
    Domain Mapping (Optional)
    Add mappings between domain names and IP addresses to update the /etc/hosts file.
    A maximum of 500 mappings can be added.
    Limit Traffic
    Set the maximum bandwidth for the migration task during different periods.
    • If you do not select this option, migration traffic will not be limited.
    • Selected: Traffic is controlled by setting the start time, end time, and bandwidth limit.
      NOTICE:
      For example, if you set Start Time to 08:00, End Time to 12:00, and Maximum Bandwidth to 20 MB/s, the maximum migration speed is limited to 20 MB/s when the migration task is running in the period from 08:00 to 12:00. The migration speed is not limited beyond this period.
    • A maximum of five traffic limiting rules can be added.
    • The time is the local standard time of the region you are migrating to.
    Log Collection
    • If this option is enabled, storage migration logs will be collected for possible troubleshooting later.
    • If this option is disabled, storage migration logs will not be collected.
  5. Click Confirm. Then you can view the cluster in the list. For details about cluster statuses, see Cluster Statuses. If the cluster status is Creation failed, move the cursor to the status to view the failure cause. After the fault is rectified, choose More > Retry to create the cluster again.
  6. After the migration cluster is created, perform the following operations:
    • If the cluster status is Healthy or Subhealthy, click Create Workflow in the Operation column to .
    • Click Manage in the Operation column to add or delete nodes and traffic limiting rules for the cluster. For details, see Managing a Migration Cluster.
Upgrading Plug-ins
You can upgrade the migration plugin to the latest version for a cluster by choosing More > Upgrade Plugin in the Operation column.
Deleting a Migration Cluster
If a migration cluster is no longer needed after your data migration is complete, you can delete the cluster and the associated resources.
  1. In the cluster list, locate the cluster to be deleted and choose More > Delete in the Operation column.
  2. Select whether to delete associated resources and click OK.
Retrying to Create a Migration Cluster
If a migration cluster fails to be created, after you rectify the fault, you can try to create the cluster again by choosing More > Retry in the Operation column.
