Intranet Discovery
MgC enables you to discover resources running in on-premises IDCs and vCenters. Before getting started, you need to install the MgC Agent in the source intranet. Then you can discover servers by network range or VMware vCenter.
Precautions
- Only VMware vSphere 5.0 to 7.0 are supported.
- When the system scans for VMware VMs or scans for servers on specific network ranges, it uses the servers' private IP addresses and the ID of the used MgC Agent to identify discovered servers. If a server's private IP address changes after the server is discovered, the server will be identified as a new one during the next discovery, and the total number of discovered servers will increase. To avoid this, do not change private IP addresses for source servers before the migration is complete.
- Performance data of VMware VMs within a specified period can be collected during the automatic scan. Discovered VMs do not require separate performance collection.
- The performance data collected during the VMware VM scanning comes from the historical data stored in the vCenter. The default data retention policy in the vCenter is as follows:
- One day: Data points are collected every 5 minutes.
- One week: Data points are collected every 30 minutes.
- One month: Data points are collected every two hours.
- If VMware Tools is not installed on the source VMs, their IP address information cannot be collected. For details about how to install VMware Tools, see How Do I Install VMware Tools on a VMware VM?
You have installed the MgC Agent in the source intranet environment and have connected the MgC Agent to MgC.
Creating an IDC Discovery Task
- Sign in to the MgC console. In the navigation pane, under Project, select your application migration project from the drop-down list.
- In the navigation pane, click Resource Survey.
- On the Intranet Discovery tab, click the IDC Discovery card. Figure 1 IDC discovery
- Configure the parameters based on Table 1.
Table 1 Parameters for configuring an IDC discovery task Area
MgC Agent
MgC Agent
Select the MgC Agent installed in the source intranet environment.
NOTE:Ensure that the MgC Agent is always online.
Scan Network Range
Protocol
Only TCP is available.
Network Range
Enter an IP address range within:
- 10.0.0.0 – 10.255.255.255
- 172.16.0.0 – 172.31.255.255
- 192.168.0.0 – 192.168.255.255
Linux
Enter the port for scanning for Linux servers. If you do not need to scan for Linux servers, set the port to 0.
Windows
Enter the port for scanning Windows servers. If you do not need to scan for Windows servers, set the port to 0.
Basic Settings
Task Name
The default name format is <task type>-<current-time>. You can also specify a name.
Task Description (Optional)
Describe the task.
Application (Optional)
Select an application to group the discovered resources. This is recommended for the assessment and migration of a small number of resources. If no applications are available, perform the following steps to create one:
- Click Create Application. Enter an application name and description.
- Configure Business Scenario and Environment, and set Region to the region that you want to migrate to.
- Click OK.
- Click Confirm to complete creating the IDC discovery task. MgC starts discovering server resources.
- After the collection task is successful, check the resource list.
Creating a VMware Discovery Task
- On the Intranet Discovery tab, click the VMware Discovery card. Figure 2 VMware discovery
- Configure the parameters based on Table 2.
Table 2 Parameters for configuring a VMware discovery task Area
MgC Agent
MgC Agent
Scan VMware VMs
IP Address
Enter the IP address of the vCenter Server for discovering the managed VMs.
Port
Enter the port for accessing the vCenter Server.
Credential
Select the credential for accessing the vCenter Server. If the drop-down list is empty, go to the MgC Agent console and add the credential. Set the resource type to Private cloud and enter the username and password for logging in to the vCenter Server.
Performance History
Select the time range for collecting performance data.
Basic Settings
Task Name
Describe the task.
- Click OK.
- Click Confirm to complete creating the VMware discovery task. MgC starts discovering server resources.
