Operations of Livestreaming Materials
On the Virtual Avatar Livestreaming page, you can add livestreaming materials such as roles, backgrounds, stickers, videos, products, and text. This section describes the operation procedure of each material type.
Roles
Figure 1 shows the Roles area.
Table 1 describes the Roles area.
GUI Element |
Description |
Customizing virtual avatars |
Click Customize Virtual Avatar. The image creation page is displayed. See Creating a Virtual Avatar Customization Task. |
By default, two columns of virtual avatars are displayed in the Roles area. After you click |
Keyword search box. You can enter a virtual avatar name for precise search. Example: yun lan |
Icon of refreshing. If there are keywords, the virtual avatar display is refreshed based on the keywords. If no, the default settings will be used. |
Filter criteria |
You can filter and display virtual avatars by role, gender, posture, field, region, and resolution. |
List of virtual avatars |
By default, all virtual avatars are displayed. Click a virtual avatar image. The image will be automatically applied to all scenes in the livestream. In the livestream preview area, if there are multiple types of video materials, you can manage the virtual avatar layer by layer, for example, moving up ( |
If you move the pointer over an avatar, |
Backgrounds
Figure 2 shows the Backgrounds area.
Table 2 describes the Backgrounds area.
GUI Element |
Description |
Importing locally |
Click Import Locally to upload a PNG, JPG, or JPEG image with a resolution level of 4K or below. You can also drag an image from the PC to the image list area for upload. |
By default, two columns of images are displayed in the Backgrounds area. After you click |
Keyword search box. You can enter an image name for precise search. Example: Technology |
Filter criteria |
Images can be filtered and displayed by background, style, and layout. |
Image list |
By default, all images are displayed. Select a scene and click an image to replace the background of the scene. |
If you move the pointer over an image, |
Stickers
Figure 3 shows the Stickers area.
Table 3 describes the Stickers area.
GUI Element |
Description |
Importing locally |
Click Import Locally to upload a PNG, JPG, JPEG, or BMP image. You can also drag an image from the PC to the image list area for upload. |
By default, two columns of images are displayed in the Stickers area. After you click |
Keyword search box. You can enter an image name for precise search. Example: tips |
Filter criteria |
Images can be filtered and displayed by sticker. |
Image list |
By default, all images are displayed. |
Viewing stickers |
Inserting a sticker |
If you move the pointer over an image, In the livestream preview area, if there are multiple types of video materials, you can manage the sticker layer by layer, for example, moving up ( |
Videos
Figure 4 shows the Videos area.
Table 4 describes the Videos area.
GUI Element |
Description |
Importing locally |
Click Import Locally to upload an MOV, MP4, M4V, MKV, FLV, 3GP, WMV, or AVI video file from the PC. You can also drag a video from the PC to the video list area for upload. |
By default, two columns of videos are displayed in the Videos area. After you click |
Keyword search box. You can enter a video name for precise search. Example: marketing video |
Filter criteria |
Videos can be filtered and displayed by My or Preset. |
Video list |
By default, all videos are displayed. |
Watching a video |
If you move the pointer over a video, |
Inserting a video |
If you move the pointer over a video, An inserted video is played mutedly. In the livestream preview area, if there are multiple types of video materials, you can manage the video layer by layer, for example, moving up ( |
Products
Figure 5 shows the Products area.
Table 5 describes the Products area.
GUI Element |
Description |
Creating a product |
Click Add. In the Create Product dialog box displayed, specify product information by referring to Products. You can also add products by referring to Products. |
Clicking |
Product list |
By default, all products are displayed. |
Inserting materials |
Click Insert Material in the product. The existing stickers, videos, text, and audios of the product are displayed in the lower part. You need to select a material and click the + icon to add the material to the live video of the current scene. You can edit a product by:
In the livestream preview area, if there are multiple types of video materials, you can manage the material layer by layer, for example, moving up ( |
Text
Figure 6 shows the Text area.
Table 6 describes the Text area.
GUI Element |
Description |
By default, two columns of text are displayed in the Text area. After you click |
Text list |
Supported text fonts: HarmonyOS normal, HarmonyOS bold, HarmonyOS light, and HarmonyOS medium black. |
Inserting text |
If you move the pointer over a piece of text, In the Text Settings area, set Content and Font, as shown in Figure 7. In the livestream preview area, if there are multiple types of video materials, you can manage the text layer by layer, for example, moving up ( |
