Updated on 2025-08-25 GMT+08:00
Checking a Voice
After the algorithm training of the voice modeling task is complete, you can check the voice.
- Log in to the MetaStudio console and go to the Overview page.
- Click Go to MetaStudio Console to go to the MetaStudio console.
- In the navigation pane, choose Task Center.
- Select Voice Modeling and confirm that the training of the voice modeling task has been completed.
- In the navigation pane, choose Assets > My Models.
- Select the Voices tab, find the generated voice, and click the avatar in the voice card to preview the voice.
You can also perform the following operations:
- Click Create, select Video Production from the drop-down list, and create a video in which the virtual avatar speaks with the generated voice. For details, see Video Production.
- Click Create, select Livestreaming from the drop-down list, and create a livestream in which the virtual avatar speaks with the generated voice. For details, see Livestreams.
- Click Create, select Intelligent interaction from the drop-down list, and create an interactive dialog project in which the virtual avatar speaks with the generated voice. For details, see Intelligent Interaction.
Figure 1 Voice
Parent topic: Voice Modeling
