Updated on 2026-09-18 GMT+08:00
LTS Python SDK
This LTS SDK provides a series of methods for reporting logs in the Python language, enabling you to directly report logs to LTS in encoding mode.
Transport Protocol
HTTPS
Instructions
After any permission is modified, the new permission takes effect one day later. When logs are reported to LTS via the SDK, the time difference between the log reporting time you set and the current time must not exceed two days. Otherwise, the reported logs will be deleted by LTS.
Precautions
Hard-coded or plaintext AK and SK are risky. For security, encrypt your AK and SK, store them in the configuration file or as environment variables, and decrypt them during usage.
Installing the Python SDK
  1. Obtain the source code of the LTS Python SDK.
    git clone https://gitee.com/lordstar-habile/huaweicloud-lts-python-sdk.git
  2. Install dependencies.
    pip3 install requests
    pip3 install loguru
    pip3 install six
  3. Compile the code for reporting logs.
    You can customize the callback methods for successful and failed log reporting. The implementation method is as follows: Create a CallBack object, implement the invoke_on_success and invoke_on_failed methods, and use them directly when sending logs.
    class CallBack(object):
        def invoke_on_success(self, result):
            pass
        def invoke_on_failed(self, result):
            pass
    Example:
    import random
    import time
    from concurrent.futures import ThreadPoolExecutor
    from loguru import logger
    from producer.core.producer import Producer
    from producer.callback.call_back import CallBack
    from producer.model import lts_store
    from producer.model.config import Config
    from producer.utils import common
    def generate_random_str(str_len=16):
        Generate a random string of a specified length.
        random_str = ''
        base_str = 'ABCDEFGHIGKLMNOPQRSTUVWXYZabcdefghigklmnopqrstuvwxyz0123456789'
        length = len(base_str) - 1
        for i in range(str_len):
            random_str += base_str[random.randint(0, length)]
        return random_str
    def send_log_single_producer():
        thread_num = 100
        threads = []
        begin_ms = common.current_time_ms()
        submit_send_log_thread_pool = ThreadPoolExecutor(max_workers=thread_num, thread_name_prefix="send_log_thread")
        config = Config()
        config.endpoint = ""
        config.access_key = ""
        config.access_secret = ""
        config.region_id = ""
        config.project_id = ""
        producer = Producer.init_producer(config)
        producer.start_producer()
        group_id = ""
        stream_id = ""
        log_content = generate_random_str(1024)
        log = [log_content]
        labels = {"keyA": "valueA"}
        log_p = lts_store.generate_log(log, labels)
        for i in range(thread_num):
            new_thread = submit_send_log_thread_pool.submit(send_log_function, producer, group_id, stream_id, log_p)
            threads.append(new_thread)
        for t in threads:
            t.result()
        end_ms = common.current_time_ms()
        logger.info("end send log, cost [{}]ms", end_ms - begin_ms)
    def send_log_function(one_producer, group_id, stream_id, log_p):
        for i in range(2000):
            one_producer.send_log_with_callback(group_id, stream_id, log_p)
    class MyCallBack(CallBack):
            logger.info("send log success")
            logger.error("send log success")
    if __name__ == '__main__':
        time.sleep(1000)
Parameters
  • Parameters for producer config
    Type
    Mandatory
    Default Value
    projectId
    Project ID of the Huawei Cloud account.
    String
    Yes
    ak
    AK of the Huawei Cloud account.
    String
    Yes
    sk
    SK of the Huawei Cloud account.
    String
    Yes
    region
    Region where LTS is deployed.
    String
    Yes
    endpoint
    Destination to which logs are reported.
    String
    Yes
    logGroup
    LTS log group ID.
    String
    Yes
    logStream
    LTS log stream ID.
    String
    Yes
  • Parameters of the GenerateLog method for generating logs The number of logs reported at a time is less than 4,096, and the size is less than 512 KB.
    Type
    Mandatory
    contents
    Content of a batch of logs.
    []string
    Yes
    labels
    Log label, in map format.
    map[string]string
    Yes
  • Parameters of the SendLog method for reporting logs
    Table 1 Parameters of the SendLog method
    Type
    Mandatory
    groupId
    Log group ID.
    String
    Yes
    streamId
    Log stream ID.
    String
    Yes
    log
    Log structure.
    class Log
    Yes
Obtaining Parameters
  • See the following region information for using Huawei Cloud hosts:
    Table 2 Regions
    Region Name
    Region
    Endpoint
    CN North-Beijing4
    cn-north-4
    https://lts-access.cn-north-4.myhuaweicloud.com:8102
    CN East-Shanghai1
    cn-east-3
    https://lts-access.cn-east-3.myhuaweicloud.com:8102
    CN South-Guangzhou
    cn-south-1
    https://lts-access.cn-south-1.myhuaweicloud.com:8102
    AP-Singapore
    ap-southeast-3
    https://lts-access.ap-southeast-3.myhuaweicloud.com:8102
    The SDK supports cross-cloud and local log reporting only in regions CN North-Beijing4, CN East-Shanghai1, and CN South-Guangzhou. It uses endpoint port 443.
  • To obtain a log group's ID, choose Log Management in the navigation pane of the LTS console and hover over the target log group's name.
  • To obtain a log stream's ID, click next to the corresponding log group and hover over the target log stream's name.
