Updated on 2026-09-18 GMT+08:00
LTS Android SDK
If you need to collect and analyze user information on Android, such as browser, browsing behavior, device, device exception, and network usage records, you can use this SDK to report logs to LTS in Kotlin and Java.
This function is available for whitelisted users in regions CN North-Beijing4, CN East-Shanghai1, and CN South-Guangzhou. To use it, create a service ticket.
Transport Protocol
HTTPS
  • You have obtained the name of the region where LTS is deployed.
  • You have obtained a project ID of your Huawei Cloud account. For details, see API Credentials.
  • You have obtained the IDs of the target log group and log stream in LTS.
Version Updates
Table 1 Version updates
Version
Download Address
Verification File Download Address
System
1.0.31
Link
Link
Improved the stability of log reporting.
iOS 10 and Xcode 11 and later
1.0.28
Link
Link
Resolved the conflict caused by project configuration since version 1.0.26.
Android 7 or later
0.0.5
Maven Central
Retained the functions in version 1.0.28 and added support for Kotlin 1.3.x.
Android 4.3 or later
1.0.27
Link
Link
Optimized the cache efficiency.
0.0.4
Maven Central
Retained the functions in version 1.0.27 and added support for Kotlin 1.3.x.
Android 7 or later
1.0.26
Link
Link
Fixed the data exception issue caused by asynchronous modification of input parameters.
Android 7 or later
1.0.25
Link
Link
Enhanced code robustness and added parameter protection.
Android 7 or later
1.0.24
Link
Link
  • Added support for regions CN East-Shanghai1 and CN South-Guangzhou.
  • Modified the program directory to com.cloud.lts.*.
Android 7 or later
1.0.21
Link
Link
Discarded the setconfig method and replaced it with LTS SDK's construction method.
Android 7 or later
1.0.19
Link
Link
  • Modified the reporting interval threshold.
  • Fixed the issue that the cache cannot be obtained after the configuration information is modified.
Android 7 or later
1.0.18
Link
Link
  • Enhanced code robustness and fixed the crashing issue caused by multiple instances.
  • Fixed the issue that the minimum Android API version is incorrectly defined.
  • Added the API for setting the debug log level: setLogLevel.
  • Modified the type of the input parameter label for sending logs to support multi-layer nesting.
  • Added support for the array type of the input parameter content for sending logs.
  • Added support for the maximum number of cached storage records. If this is exceeded, cached records are discarded first before new records are stored.
  • Modified the control policy for request failures to support progressive waiting.
  • Optimized the output of local error logs.
Android 7 or later
1.0.17
Link
Link
This is the first release. Four interfaces are provided: init, config, report, and reportImmediately.
Android 7 or later
Installing the Android SDK
  1. Integrate the access SDK.
    1. Integration using the Maven repository
      1. Add dependencies to build.gradle.
        plugins {
            id 'org.jetbrains.kotlin.android' version 'KOTLIN_VERSION' apply false  //  Add Kotlin plug-in. 1.0.31 and later versions support 1.9.20 or later, versions earlier than 1.0.31 support 1.6.20 or later, and 0.0.x supports 1.3.61 or later.
      2. Add dependencies to app/build.gradle.
        dependencies {
            implementation 'io.github.lts-sdk:lts-sdk-android:1.0.31'
      3. Add the Maven repository to settings.gradle.
        pluginManagement{
            repositories {
                // Add the following content:
                mavenCentral()
        dependencyResolutionManagement {
            repositories {
                mavenCentral()
    2. Manual integration
      1. Download the LTS SDK package.
      2. Decompress the package to a specific directory.
      3. Add the decompressed AAR static library file to your project.
      4. Add dependencies to build.gradle.
        plugins {
            id 'org.jetbrains.kotlin.android' version 'KOTLIN_VERSION' apply false  // Add kotlin 1.6.20 or later for 1.x.x and 1.3.61 or later for 0.0.x.
      5. Add dependencies to app/build.gradle.
        dependencies {
            implementation fileTree(dir: $dir, include: ['*.aar']) // Enter the folder where the .aar package is located, for example, libs.
            implementation 'org.jetbrains.kotlinx:kotlinx-coroutines-core:1.4.0' // 0.0.x depends on 1.3.3.
            implementation 'androidx.core:core-ktx:1.10.1'// 0.0.x depends on 1.2.0, and 1.0.28 and earlier versions depend on 1.7.0.
            implementation 'com.google.code.gson:gson:2.8.9'
            kapt 'androidx.room:room-compiler:2.6.1' // 0.0.x depends on 2.2.6, and 1.0.28 and earlier versions depend on 2.4.0.
            api 'androidx.room:room-runtime:2.6.1'      // 0.0.x depends on 2.2.6, and 1.0.28 and earlier versions depend on 2.4.0.
            api 'androidx.room:room-common:2.6.1'       // 0.0.x depends on 2.2.6, and 1.0.28 and earlier versions depend on 2.4.0.
      6. Add the Maven repository to settings.gradle.
        If your Gradle version is earlier than 7.0, add the Maven repository to the build.gradle file.
        pluginManagement{
            repositories {
                google()
                mavenCentral()
            repositories {
                google()
                mavenCentral()
  2. Perform initialization. For details about the parameters, see Table 4.
    1. Add dependencies.
      import com.cloud.lts.UserConfig
      import com.cloud.lts.LTSSDK
    2. Kotlin: example initialization code
      // Note: Hard-coded or plaintext AK and SK of the account for authentication are risky. For security, encrypt them. Decrypt them only when necessary.
      val ak: String = getData("HUAWEICLOUD_SDK_AK")
      val sk: String = getData("HUAWEICLOUD_SDK_SK")
      // LTS parameter configuration
      val userConfig = UserConfig.Builder()
      // Mandatory parameters
      .setRegion(USER_REGION) // Region of LTS
      .setProjectId(PROJECT_ID) // Project ID of the account
      .setGroupId(LOG_GROUP_ID) // LTS log group ID
      .setStreamId(LOG_STREAM_ID) // LTS log stream ID
      .setAccessKey(ak) // Access key
      .setSecretKey(sk) // Secret access key
      // Optional parameters
      .setUrlHost(url) // LTS public network domain name
      .setCacheThreshold(200)
      .setTimeInterval(60)
      .setIsReportBackground(true)
      .setIsReportLaunch(false)
      .build()
      // LTS initialization method
      ltssdk = LTSSDK( </* Application Instance */> , userConfig)
    3. Java: example initialization code. The LTS SDK supports multi-instance log reporting. Instances are created based on different configurations for reporting.
      String ak = getData("HUAWEICLOUD_SDK_AK")
      String sk = getData("HUAWEICLOUD_SDK_SK")
      UserConfig userConfig = new UserConfig.Builder()
      .build();
      ltssdk = new LTSSDK( </* Application Instance */> , userConfig);
  3. Report logs. LTS provides two log reporting methods.
    Table 2 Log reporting methods
    Method
    report(content, labels)
    LTS stores logs in the local database and reports them in real time based on the configured policy.
    reportImmediately(content, labels)
    Logs are reported immediately.
    Table 3 Parameters
    Name
    content
    Log content. The value can be a dictionary or dictionary array. A maximum of 300 key-value pairs are supported. The maximum length of the JSON string converted from content is 30 × 1024. If the length exceeds the limit, the excess part will be truncated.
    labels
    Log labels.
    • The value can be a dictionary or null.
    • Maximum number of outermost key-value pairs: 50.
    • Maximum length of the outermost key: 64.
    • The value can contain letters, digits, and underscores (_), and must start with a letter.
    • The maximum length of a dictionary converted to a JSON string is 30,720 characters. If the length exceeds 30,720 characters, the log cannot be reported.
    • Kotlin sample code:
      var ltssdk: LTSSDK
      val food = hashMapOf(Pair("food_1", "rice"), Pair("food_2", "wheat"), Pair("food_3", "egg"))
      val fruit = hashMapOf(Pair("fruit_1", "apple"), Pair("fruit_2", "pear"), Pair("fruit_3", "banana"))
      val label = hashMapOf( Pair("date","2023-10-01"))
      val contents = listOf(food, fruit).toTypedArray()
      ltssdk.report(food, label) // Cache and report a single record, with labels
      ltssdk.report<String, String>(food)    // Cache and report a single record, without labels
      ltssdk.reportImmediately(food, label)    // Immediately report a single record, with labels
      ltssdk.reportImmediately<String, String>(food)    // Immediately report a single record, without labels
      ltssdk.report(contents, label)    // Cache and report multiple records, with labels
      ltssdk.report<String, String>(contents)    // Cache and report multiple records, without labels
      ltssdk.reportImmediately(contents , label)    // Immediately report multiple records, with labels
      ltssdk.reportImmediately<String, String>(contents)    // Immediately report multiple records, without labels
    • Java sample code:
      LTSSDK ltssdk;
      HashMap fruit = new HashMap<String, String>(){{
          put("fruit_1", "apple");
          put("fruit_2", "pear");
          put("fruit_3", "banana");
      HashMap food = new HashMap<String, String>(){{
          put("food_1", "rice");
          put("food_2", "wheat");
          put("food_3", "egg");
      HashMap<String, String> labels = new HashMap(){{
          put("date","2023-10-01");
      HashMap[] contents = {food, fruit};
      ltssdk.report(food);  // Cache and report a single record, without labels
      ltssdk.report(food, labels);  // Cache and report a single record, with labels
      ltssdk.reportImmediately(food);  // Immediately report a single record, without labels
      ltssdk.reportImmediately(food, labels);  // Immediately report a single record, with labels
      ltssdk.report(contents); // Cache and report multiple records, without labels
      ltssdk.report(contents, labels); // Cache and report multiple records, with labels
      ltssdk.reportImmediately(contents);  // Immediately report multiple records, without labels
      ltssdk.reportImmediately(contents , labels);  // Immediately report multiple records, with labels
Parameters
Table 4 Initialization parameters
Type
Mandatory
Default Value
projectId
String
Yes
Project ID of the account.
accessKey
String
Yes
AK of the account.
secretKey
String
Yes
SK of the account. Note: Hard-coded or plaintext AK and SK of the Huawei Cloud account for authentication are risky. For security, encrypt them. Decrypt them only when necessary.
region
String
Yes
Service region of LTS.
groupId
String
Yes
LTS log group ID.
streamId
String
Yes
LTS log stream ID.
url
String
No
null
Public network domain name for reporting. If it is not set, a link is automatically generated based on the region. The format is as follows: https://lts-access.{region}.myhuaweicloud.com.
cacheThreshold
Long
No
200
When the number of logs stored in the local database reaches this threshold, an alarm is reported. Value range: 30 to 1000.
timeInterval
Long
No
3
Interval for triggering reporting. Value range: 1 to 1800, in seconds.
isReportBackground
Boolean
No
true
Whether to report logs when the app switches to running in the background.
isReportLaunch
Boolean
No
false
Whether to report logs upon app startups.
Log Reporting Policies
This SDK supports the following log reporting policies: threshold-based reporting, scheduled reporting, reporting when the app is switched to the background, and reporting upon startup. Set parameters such as cacheThreshold, timeInterval, isReportBackground, and isReportLaunch based on the scenario.
Configuring Permissions
This LTS SDK requires the network permission of Android. If this permission is not configured, add the following content to the Manifest.xml file of the app:
manifest xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:tools="http://schemas.android.com/tools">
<uses-permission android:name="android.permission.INTERNET" />
</manifest>
Obfuscation Configuration
To achieve code obfuscation, add the following code segment to the obfuscation configuration file:
-keep class com.cloud.**{*;}
Debugging
Enable debugging if needed. Then you can monitor log reporting in real time on the console, and make adjustments accordingly.
You need to invoke the static method of this LTS SDK to change the log level. The SDK supports five log levels: Debug, Info, Warning, Error, and Off (default). The five levels correspond to the following parameters: LogLevel.DEBUG, LogLevel.INFO, LogLevel.WARNING, LogLevel.ERROR, and LogLevel.OFF. The following is a code example:
LTSSDK.setLogLevel(LogLevel.DEBUG)
Obtaining Parameters
  • Regions
    Table 5 Regions
    Name
    Region
    CN North-Beijing4
    cn-north-4
    CN East-Shanghai1
    cn-east-3
    CN South-Guangzhou
    cn-south-1
  • To obtain a log group's ID, choose Log Management in the navigation pane of the LTS console and hover over the target log group's name.
  • To obtain a log stream's ID, click the down arrow on the left of the corresponding log group name to expand the log stream list, then hover over the target log stream's name.
