Updated on 2025-07-28 GMT+08:00
LTS Go SDK
This LTS SDK provides a series of methods for reporting logs in the Go language, enabling you to directly report logs to LTS in encoding mode.
Transport Protocol
HTTPS
Instructions
  • After a permission is modified, the new permission takes effect one day later.
  • When logs are reported to LTS via the Go SDK, the time difference between the log reporting time you set and the current time must not exceed two days. Otherwise, the reported logs will be deleted by LTS.
  • The Go SDK supports cross-cloud and local log reporting only in regions CN North-Beijing4, CN East-Shanghai1, and CN South-Guangzhou. It uses endpoint port 443.
Precautions
Hard-coded or plaintext AK and SK are risky. For security, encrypt your AK and SK, store them in the configuration file or as environment variables, and decrypt them during usage.
Installing the Go SDK
  1. Obtain the LTS Go SDK package.
    go get github.com/huaweicloud/huaweicloud-lts-sdk-go
  2. Import the LTS Go SDK package.
    import github.com/huaweicloud/huaweicloud-lts-sdk-go
  3. Compile the code for reporting logs.
    You can customize the callback methods for successful and failed log reporting. The implementation method is as follows: Define the structure of ErrorHandler and the Success and Fail methods, and use them directly when sending logs.
    SendLogWithCallBack(groupId, streamId string, log *Log, callback CallBack)
    Example code:
    package main
    import (
    "github.com/huaweicloud/huaweicloud-lts-sdk-go"
    "fmt"
    "sync"
    "time"
    var (
    ak        = ""
    sk        = ""
    pid       = ""
    groupId   = ""
    streamId1 = ""
    streamId2 = ""
    region    = ""
    endpoint  = ""
    func main() {
    // Obtain the default configuration.
    producerConfig := producer.GetConfig()
    // Log reporting address
    producerConfig.Endpoint = endpoint
    // accessKeyId: AK of the Huawei Cloud account. Hard-coded or plaintext AK is risky. For security, encrypt your AK, store it in the configuration file or as an environment variable, and decrypt it during usage.
    producerConfig.AccessKeyID = os.Getenv("accessKeyId")
    // accessKeySecret: SK of the Huawei Cloud account. Hard-coded or plaintext SK is risky. For security, encrypt your SK, store it in the configuration file or as an environment variable, and decrypt it during usage.
    producerConfig.AccessKeySecret = os.Getenv("accessKeySecret")
    // Region name
    producerConfig.RegionId = region
    // Account project ID
    producerConfig.ProjectId = pid
    // Initialize the producer instance.
    producerInstance := producer.InitProducer(producerConfig)
    // Start the producer.
    producerInstance.Start()
    wg := sync.WaitGroup{}
    for i := 0; i < 10; i++ {
    wg.Add(1)
    go func() {
    for j := 0; j < 1000; j++ {
    labels := make(map[string]string)
    labels["keyA"] = "valueA"
    labels["keyB"] = "valueB"
    labels["keyC"] = "valueC"
    logContent := fmt.Sprintf("content for this test %d", j)
    // Generate logs and fill in log content and labels.
    log := producer.GenerateLog([]string{logContent}, labels)
    // Send logs to log groups and log streams.
    err := producerInstance.SendLog(groupId, streamId1, log)
    err = producerInstance.SendLog(groupId, streamId2, log)
    if err != nil {
    fmt.Println(err)
    handle := ErrorHandle{}
    // Send logs using the method with CallBack. If the sending fails, the Fail method of ErrorHandler is called.
    err = producerInstance.SendLogWithCallBack("groupId", "streamId1", log, handle)
    if err != nil {
        fmt.Println(err)
    // Method for reporting structured logs
    var sLog producer.StructLog
    logContent := make(map[string]string)
    logContent["keyA"] = "valueA"
    logContent["keyB"] = "valueB"
    logContent1 := make(map[string]string)
    logContent1["keyA1"] = "valueA1"
    logContent1["keyB1"] = "valueB1"
    sLog.Contents = append(sLog.Contents, logContent)
    sLog.Contents = append(sLog.Contents, logContent1)
    sLog.Time = time.Now().UnixNano() / 1000 /1000
    // Send structured logs.
    err = producerInstance.SendLogStruct("groupId2", "streamId2", &sLog)
    if nil != err {
        continue
    // Send structured logs with CallBack. If the sending fails, the Fail method of ErrorHandler is called.
    var callback ErrorHandle
    err = producerInstance.SendLogStructWithCallBack("groupId2", "streamId2", &sLog, callback)
    if nil != err {
        continue
    time.Sleep(1 * time.Microsecond)
    wg.Done()
    fmt.Printf("test func finished\n")
    wg.Wait()
    fmt.Printf("send all complete ...")
    // Disable the sending instance.
    producerInstance.Close(60 * 1000)
    time.Sleep(10 * 60 * time.Second)
    // errorHandle can call the callback functions for successful and failed sending. This is useful for printing error logs and locating faults.
    type ErrorHandle struct{}
    // Callback method when the sending is successful.
    func (ErrorHandle) Success(result *producer.Result) {
        fmt.Printf("send log to lts success, success flag: %v\n", result.IsSuccessful())
    // Callback method when the sending fails. You can print the error information in result to facilitate fault locating.
    func (ErrorHandle) Fail(result *producer.Result) {
        fmt.Printf("send log to lts error, success flag: %v requestId: %s, httpcode: %d, errorCode: %s, errorMsg: %s\n",
           result.IsSuccessful(), result.GetRequestId(), result.GetHttpCode(), result.GetErrorCode(), result.GetErrorMessage())
Parameters
  • Parameters for producer config
    Table 1 Parameters for producer config
    Type
    Mandatory
    Default Value
    ProjectId
    Project ID of the Huawei Cloud account.
    String
    Yes
    AccessKeyId
    String
    Yes
    AccessKeySecret
    String
    Yes
    RegionName
    Region where LTS is deployed.
    String
    Yes
    Endpoint
    Domain name or IP address of the server to which logs are reported.
    String
    Yes
    TotalSizeInBytes
    Maximum size of logs that can be cached in a producer instance.
    int
    No
    104857600 (indicates 100 MB.)
    MaxBlockSec
    Maximum blocking time that the caller will wait on the send method when the producer's available space is insufficient. The default value is 60 seconds. The recommended value is 0 seconds.
    • If maxBlockMs is set to a value greater than or equal to 0, the blocking time is enforced. If the memory space is still insufficient after the blocking time expires, an error will be reported and the logs will be discarded.
    • If maxBlockMs is set to -1, the blocking continues until the logs are successfully sent to LTS and the logs will not be discarded.
    long
    No
    60s
    MaxIoWorkers
    Size of the task pool for executing log sending tasks.
    int
    No
    10 (default)
    MaxBatchSize
    Once the size of logs cached in a ProducerBatch reaches or exceeds the batchSizeThresholdInBytes value, this batch of logs will be sent to LTS.
    int
    No
    524288 (indicates 0.5 MB.)
    MaxBatchCount
    Once the number of logs cached in a ProducerBatch reaches or exceeds the batchCountThreshold value, this batch of logs will be sent to LTS.
    int
    No
    4096
    LingerMs
    Duration from the time when a ProducerBatch is created to the time when the logs can be sent.
    int
    No
    2s
    Retries
    Number of allowed retry attempts for a ProducerBatch when the first attempt to send the logs cached in the ProducerBatch fails. The recommended value is 3. If the value of retries is less than or equal to 0, the ProducerBatch will be added to the failure queue after the first sending attempt fails.
    int
    No
    10
    BaseRetryBackoffMs
    Backoff time for the first retry attempt.
    long
    No
    0.1s
    MaxRetryBackoffMs
    Maximum backoff time for retry attempts.
    long
    No
    50s
  • Parameters of the GenerateLog method for generating logs
    The number of logs reported at a time is less than 4,096, and the size is less than 512 KB.
    Table 2 Parameters of the GenerateLog method
    Type
    Mandatory
    contents
    Content of a batch of logs.
    []string
    Yes
    labels
    Log label, in map format.
    map[string]string
    Yes
  • Parameters of the SendLog method for reporting logs
    Table 3 Parameters of the SendLog method
    Type
    Mandatory
    groupId
    Log group ID.
    long
    Yes
    streamId
    Log stream ID.
    String
    Yes
    log
    Log structure.
    struct log
    Yes
  • Parameters of the StructLog method for reporting structured logs
    Table 4 Parameters of the StructLog method
    Type
    Mandatory
    Time
    Log reporting time.
    int64
    No
    Contents
    Log content.
    []map[string]string
    Yes
  • Parameters of the SendLogStruct method for reporting structured logs
    Table 5 Parameters of the SendLogStruct method
    Type
    Mandatory
    groupId
    Log group ID.
    String
    Yes
    streamId
    Log stream ID.
    String
    Yes
    log
    Log structure.
    Struct Logstruct
    Yes
Obtaining Parameters
  • See the following region information for using Huawei Cloud hosts:
    Table 6 Regions
    Region Name
    Region
    Endpoint
    CN North-Beijing4
    cn-north-4
    https://lts-access.cn-north-4.myhuaweicloud.com:8102
    CN East-Shanghai1
    cn-east-3
    https://lts-access.cn-east-3.myhuaweicloud.com:8102
    CN South-Guangzhou
    cn-south-1
    https://lts-access.cn-south-1.myhuaweicloud.com:8102
    AP-Singapore
    ap-southeast-3
    https://lts-access.ap-southeast-3.myhuaweicloud.com:8102
    The SDK supports cross-cloud and local log reporting only in regions CN North-Beijing4, CN East-Shanghai1, and CN South-Guangzhou. It uses endpoint port 443.
  • To obtain a log group's ID, choose Log Management in the navigation pane of the LTS console and hover over the target log group's name.
  • To obtain a log stream's ID, click next to the corresponding log group and hover over the target log stream's name.
