Help Center/
Log Tank Service/
User Guide/
Log Search and Analysis (SQL Analysis Offline Soon)/
Saving Search and Analysis Statements
Updated on 2025-09-26 GMT+08:00
To repeatedly use a search and analysis statement, you can set and save it as a quick search statement for faster log searching and analysis.
Creating a Quick Search
- Log in to the LTS console. The Log Management page is displayed by default.
- Click the target log group or stream to access the log details page.
- Click
on the Log Search tab page. Enter a name and statement for quick search. By default, quick search and quick search (local cache) are enabled.
Figure 1 Creating a quick search- A quick search name is used to distinguish multiple quick search statements. The name can be customized and must meet the following requirements:
- Can contain only letters, digits, hyphens (-), underscores (_), and periods (.).
- Cannot start with a period (.) or underscore (_) or end with a period (.).
- Can contain 1 to 64 characters.
- A quick search statement is used to repeatedly search for logs, for example, error*.
- Click OK. On the Quick Search tab page in the left navigation pane, you can view the statements that are successfully saved.
- To view the log search result of a quick search statement, click its name.
- To modify a quick search statement, move the cursor to the statement and click
next to it. On the Edit Quick Search dialog box displayed, modify the statement and click OK.
Figure 2 Editing a quick search - To delete a quick search statement, move the cursor to the statement and click
next to it. On the Delete Quick Search dialog box displayed, click OK. Quick search cannot be performed with a deleted statement. Exercise caution when performing this operation.
Parent topic: Log Search and Analysis (SQL Analysis Offline Soon)
