Updated on 2025-11-18 GMT+08:00
Ingesting VPC Logs to LTS
LTS can collect logs from VPC.
You have purchased and used a Huawei Cloud VPC.
For details about the supported ECSs, see VPC Flow Log Overview.
Configuring VPC Log Ingestion
Perform the following operations to configure VPC log ingestion:
  1. Log in to the LTS console.
  2. In the navigation pane, choose Log Ingestion > Ingestion Center. On the displayed page, select Cloud services under Types. Hover the cursor over the VPC card and click Ingest Log (LTS) to access the configuration page.
  3. Select a log stream.
    1. Select a log group from the Log Group drop-down list. If there are no desired log groups, click Create Log Group to create one.
    2. Select a log stream from the Log Stream drop-down list. If there are no desired log streams, click Create Log Stream to create one.
    3. Click Next: Configure VPC.
  4. Click Configure VPC. For details, see Creating a VPC Flow Log.
  5. Click Next: Configure Log Stream.
    Table 1 Log stream parameters
    Auto Structure and Index
    If this function is enabled, the structuring for the log stream is based on the VPC system template, and the indexing enables quick analysis for all parsed VPC fields. Enabling structuring and indexing is required for SQL analysis of VPC logs with visual charts.
    Auto Add Tag log_type=vpc_flow
    If this option is enabled, the tag log_type=vpc_flow is automatically added to the log stream, and the VPC dashboard template can then match this log stream.
    Auto Create Dashboard
    If this option is enabled, a VPC dashboard is automatically created for the log stream.
  6. Click Submit.
