Updated on 2026-09-18 GMT+08:00
Managing Host Groups
A host group is a virtual group of hosts, allowing you to configure host log collection efficiently. You can add multiple hosts to a host group and associate the host group with log ingestion configurations. The ingestion configurations will then be applied to all the hosts in the host group. For details, see Figure 1.
  • When there is a new host, simply add it to a host group and the host will automatically inherit the log ingestion configurations associated with the host group.
  • You can also use host groups to modify the log collection paths for multiple hosts at one go.
Figure 1 Host groups
You can create host groups of the IP address or custom identifier type.
  • Creating a Host Group (IP Address): Select hosts of the IP address type and add them to the host group.
  • Creating a Host Group (Custom Identifier): You need to create identifiers for each host group and host. Hosts with an identifier will automatically be included in the corresponding host group sharing that identifier.
    Host groups with custom identifiers are suitable for the following scenarios:
    • In custom network environments like VPCs, potential IP address conflicts among hosts may impede ICAgent management in LTS. Using custom identifiers can resolve this issue.
    • Multiple servers using the same custom identifier enable auto scaling of host groups. Simply assign a custom identifier for a new host; LTS will then automatically identify the host and add it to corresponding host group with the same identifier.
LTS allows you to create host groups of the IP address or custom identifier type.
  1. Log in to the management console and choose Management & Deployment > Log Tank Service. The Log Management page is displayed by default.
  2. Choose Host Management > Host Groups in the navigation pane.
  3. Click Create Host Group.
  4. On the displayed page, set the parameters by referring to Table 1.
    Table 1 Creating a host group (IP)
    Example Value
    Host Group Name
    Enter a custom host group name. Only letters, digits, hyphens (-), underscores (_), and periods (.) are allowed. Do not start with a period or underscore, or end with a period.
    testECS
    Host Group Type
    Select IP to create a host group of the IP address type.
    About this group type: Servers are added to the group with their IP addresses, enabling the system to identify each server based on its IP address.
    IP
    Host OS
    Select Linux or Windows.
    Linux
    Remarks
    Enter a description for the host group. Up to 1,024 characters are allowed.
    Hosts
    In the host list, select one or more hosts with ICAgent installed. Ensure the selected hosts align with your site requirements.
    • You can filter hosts by host name, enterprise project, IPv4 address, or IPv6 address. You can also click Search by Host IP Address and enter multiple host IP addresses in the displayed search box to search for matches.
    • If your desired hosts are not in the list, click Install ICAgent. On the displayed page, install ICAgent on the hosts as prompted. For details, see Installing ICAgent (Intra-Region Hosts) or Installing ICAgent (Extra-Region Hosts).
    ECS-test-dqy
    Figure 2 Creating an IP address host group
  5. Click OK. The host group is created and displayed in the host group list.
    Figure 3 Host group information (for reference only)
To create a host group of the custom identifier type, you need to plan the hosts to be identified in advance and ensure that ICAgent has been installed on the hosts.
  1. Click Create Host Group.
  2. On the displayed page, set the parameters by referring to Table 2.
    Table 2 Creating a host group (custom identifier)
    Example Value
    Host Group Name
    testECS
    Host Group Type
    Select Custom Identifier to create a host group of the custom identifier type.
    About this group type: Define unique identifiers for both hosts and host groups. Any host assigned a specific identifier will be automatically enrolled in the host group that shares that same identifier.
    Custom identifier
    Host OS
    Linux
    Remarks
    Hosts
    ECS-test-dqy
    Figure 4 Creating a custom identifier host group
  3. Enter a custom identifier. You can also click Add to enter more.
    Up to 10 custom identifiers can be added.
  4. Click OK. The custom identifier host group is created and displayed in the host group list. Add the desired hosts to the host group by referring to 5.
    Figure 5 Custom identifier host group (for reference only)
  5. Perform the following operations to create the custom_tag file to save host tags:
    1. Log in to the host and run the following command to check for the /opt/cloud directory:
      cd /opt/cloud
      • If the /opt/cloud directory does not exist, run the following command to create it:
        mkdir /opt/cloud/
      • If the /opt/cloud directory already exists, navigate to it and run the following command to create the lts directory in it.
        mkdir lts
    2. Run the following command to change the permission on the lts directory:
      chmod 750 lts
    3. Run the following command in the lts directory to create the custom_tag file.
      cd lts
      touch custom_tag
    4. Run the following command to modify the custom_tag permission and open the file.
      chmod 640 custom_tag;vi custom_tag
    5. Press i to enter the insert mode, enter a custom identifier, press Esc, enter :wq!, save the modification, and exit.
      :wq!
    6. Use either of the following methods to add a host to the custom identifier host group.
      When adding a custom identifier to a host, ensure that the host's OS matches the host group type. Linux hosts can only join Linux host groups. Windows hosts can only join Windows host groups.
      Table 3 Methods
      Type
      Method 1 (Recommended)
      Method 2
      Linux host
      View the host's identifier in the custom_tag file of the /opt/cloud/lts directory on the host. Then, add the identifier to the host group to include the host within it. For example, if the custom_tag file in the /opt/cloud/lts directory shows the host's identifier as test1, simply add test1 to the group's custom identifiers.
      • Add the host group's custom identifier to the custom_tag file in the /opt/cloud/lts directory on the host to include the host within the host group. For example, if the group's custom identifier is test, enter test into the custom_tag file.
      • If the group has multiple custom identifiers, simply enter any one of them into the custom_tag file of the /opt/cloud/lts directory on the host.
      Windows host
      View the host's identifier in the custom_tag file of the C:\opt\cloud\lts directory on the host. Then, add the identifier to the host group to include the host within it. For example, if the custom_tag file in the C:\opt\cloud\lts directory shows the host's identifier as test1, simply add test1 to the group's custom identifiers.
      • Add the host group's custom identifier to the custom_tag file in the C:\opt\cloud\lts directory on the host to include the host within the host group. For example, if the group's custom identifier is test, enter test into the custom_tag file.
      • If the group has multiple custom identifiers, simply enter any one of them into the custom_tag file of the C:\opt\cloud\lts directory on the host.
Modifying a Host Group
You can change the name of a host group, add hosts to or remove hosts from a host group, or associate a host group with log ingestion configurations. For details, see Table 4.
Table 4 Operations on host groups
Operation
Changing a host group name
  1. On the Host Groups list, click Modify in the Operation column of the target host group.
  2. On the displayed dialog box, modify the information such as the host group name and custom identifier.
  3. Click OK.
Adding hosts to a host group
Method 1:
  1. In the host group list, locate the host group whose host group type is IP and click next to the host group name.
  2. Click Add Host.
  3. In the displayed slide-out panel, all hosts that are not in the host group and run the selected OS type are displayed. Select the hosts to be added to the host group.
      If you change the VPC or primary NIC IP of an ECS, the ECS's IPv4 and IPv6 addresses will also change. This change usually takes about 30 minutes to synchronize and update. Updated IPv4 and IPv6 addresses will appear on the Hosts page of LTS.
    • If your desired hosts are not in the list, click Install ICAgent. On the displayed page, install ICAgent on the hosts as prompted. For details, see Installing ICAgent.
  4. Click OK.
Method 2:
  1. Choose Host Management > Hosts in the navigation pane.
  2. In the host list, select the target hosts and click Add to Host Group.
  3. In the displayed slide-out panel, select the target host group.
  4. Click OK.
Removing a host from a host group
  1. In the host group list, click in the row containing the target host group.
  2. In the host list, click Remove in the Operation column of the row containing the host to be removed.
  3. In the displayed dialog box, click OK. This operation is not supported for hosts in the custom identifier host group.
Uninstalling ICAgent from a host
  2. In the host list, click Uninstall ICAgent in the Operation column of the row containing the target host.
  3. In the displayed dialog box, click OK to uninstall ICAgent from the host and remove the host from the host group.
    • This operation is not supported for hosts in the custom identifier host group.
    • If the host has also been added to other host groups, it will be removed from those groups as well.
Removing hosts from a host group
  2. In the host list, select the target hosts and click the Remove button above the list.
  3. Click OK.
Associating a host group with an ingestion configuration
  2. The Hosts tab page is displayed by default. Click the Associated Ingestion Configurations tab.
  3. Click Associate.
  4. In the displayed slide-out panel, select the target ingestion configuration.
  5. Click OK. The associated ingestion configuration is displayed in the list.
Disassociating a host group from an ingestion configuration
  1. On the Associated Ingestion Configurations tab page, locate the target ingestion configuration, and then click Disassociate in the Operation column.
  2. Click OK.
Disassociating a host group from multiple ingestion configurations
  2. The Hosts tab page is displayed by default. Click the Associated Ingestion Configurations tab, select the target ingestion configurations, and then click Disassociate above the list.
  3. Click OK.
Copying a host group ID
Hover your cursor over a host group name to copy the host group ID.
Exporting host information
  1. On the Hosts page, switch to the Intra-Region Hosts, CCE Cluster, or Extra-Region Hosts tab and select the desired hosts.
  2. Click Export and choose Export all data to an XLSX file or Export selected data to an XLSX file to export the host information to your local PC.
Tagging a Host Group
You can add tags to existing host groups for easy identification, searching, and management. Each tag consists of a tag key and a tag value. Adding, changing, or removing tags of a host group does not affect other host groups.
  1. Choose Host Management > Host Groups in the navigation pane.
  2. Click Configure Tag in the Operation column of the desired host group.
  3. On the displayed page, click Add and enter a tag key and value. To add more tags, repeat this step. A maximum of 20 tags can be added.
    Figure 6 Editing host group tags
    Tag key restrictions:
    • A tag key can contain letters, digits, spaces, and special characters (_.:=+-@), but cannot start or end with a space or start with _sys_.
    • A tag key can contain up to 128 characters.
    • Each tag key must be unique.
    Tag value restrictions:
    • A tag value can contain letters, digits, spaces, and the following special characters: _.:=+-@
    • A tag value can contain up to 255 characters.
    Tag policies:
    If your organization has configured tag policies for LTS, follow the policies when adding tags to log groups, log streams, log ingestion configurations, and host groups. Non-compliant tags may cause the creation of these resources to fail. Contact your administrator to learn more about the tag policies. For details about tag policies, see Overview of a Tag Policy. For details about tag management, see Managing Tags.
    Deleting a tag:
    On the Configure Tag page, click Delete in the Operation column of the tag.
    If a tag is used by a transfer task, you need to modify the task configuration after deleting the tag.
  4. Click OK. On the Host Groups page, you can view the added tags in the Tags column of the host group.
Deleting Host Groups
You can delete a host group that is no longer needed.
Deleting a host group may lead to log ingestion exceptions. In addition, deleted host groups cannot be restored.
  2. Delete a host group:
    1. Click Delete in the Operation column of the target host group.
    2. In the displayed dialog box, click OK.
      The host group is successfully deleted once it no longer appears in the host group list.
  3. Delete host groups in batches:
    1. Select host groups to be deleted and click Delete above the list.
      The host groups are successfully deleted once they no longer appear in the host group list.
Helpful Links
You can call APIs to create, modify, and delete host groups. For details, see Host Group Management.
