- What's New
- Function Overview
- Getting Started
- User Guide
- Best Practices
- Developer Guide
API Reference
- Before You Start
- API Overview
- API Calling
API
Console
- Instance Management
- Job Management
Service Authorization Management
- Granting Permissions for Accessing Other Cloud Services
- Querying Cloud Service Access Permissions
- Registering a Tenant Agreement
- Querying whether a Tenant Has Registered an Agreement
- Deleting a Tenant Agreement
- Querying the Current System Agreement
- OBS Management
- Access Management
- Specification Management
- Quota Management Service
- Tag Management Service
- Agency Management
- Alarm Management
- Metadata Management
- Location
LakeCat
- Function Management
- Catalog Management
- Database Management
- Table Management
- Data Table Statistics
- Zone-based Management
- Partition Statistics
- Authorization Management
- User Group Management
- Metadata Statistics
Role Management
- Creating a Role
- Listing Roles on Different Pages by Condition
- Deleting a Role
- Obtaining a Role
- Modifying a Role
- Listing All Role Names
- Querying the Users or User groups Under a Role
- Adding One or More Users or User Groups to a Role
- Removing One or More Users or User Groups from a Role
- Updating the Entities in a Role
- Credential Management
- Configuration Management
- User
Console
- Application Examples
- Appendix
- FAQs
Show all
Managing Functions
You can manage metadata in the data catalog and create functions based on the service plan.
- A LakeFormation instance has been created and is running properly.
- A catalog and a database have been created.
- You have created an OBS parallel file system for storing functions by referring to Creating a Metadata Storage Path if a function location is added.
Creating a Function
- Log in to the LakeFormation console.
- In the upper left corner, click
and choose Analytics > LakeFormation to access the LakeFormation console.
- Select the target LakeFormation instance from the drop-down list box on the left and choose Metadata > Function. In the upper right corner, select the names of the target catalog and database from the Catalog and Database drop-down lists. You can view the functions contained in the selected database.
- Click Create and set related parameters.
- In the Basic Information area, set the related parameters.
Table 1 Parameter for creating a function Parameter
Function Name
Enter a metadata function name.
The value should contain 1 to 256 characters. Only letters, numbers, and underscores (_) are allowed.
Catalog
Catalog to which the function to be created belongs.
Database
Database to which the function to be created belongs.
Type
Type of the function to be created. Currently, JAVA is supported.
Class Name
Enter a function class name.
- (Optional) Click Add under Function Locations to add the function package type and location as required, and click OK. Multiple locations can be added.
- Selecting function package type and location is an optional operation.
- If a function storage path is added for the database to which the function belongs, the storage location must be the path specified by Select Location during database creation or its subpaths, or the function storage path or its subpaths.
- Click Submit.
- After the function is created, you can view the function name/ID, catalog, database, type, and class name on the Function page.
Click Modify in the Operation column to modify the configurations of a function.
Click More and then click Authorize in the Operation column to authorize a function.
You can click More to view the permissions on the current function.
- To delete a function, choose More > Delete, confirm the operation impact, and click OK.
If files are also deleted when metadata is deleted, the metadata is moved to the recycle bin (OBS path lake-formation-trash-dir/table_id) of the corresponding OBS bucket.
