- What's New
- Function Overview
- Getting Started
- User Guide
- Best Practices
- Developer Guide
API Reference
- Before You Start
- API Overview
- API Calling
API
Console
- Instance Management
- Job Management
Service Authorization Management
- Granting Permissions for Accessing Other Cloud Services
- Querying Cloud Service Access Permissions
- Registering a Tenant Agreement
- Querying whether a Tenant Has Registered an Agreement
- Deleting a Tenant Agreement
- Querying the Current System Agreement
- OBS Management
- Access Management
- Specification Management
- Quota Management Service
- Tag Management Service
- Agency Management
- Alarm Management
- Metadata Management
- Location
LakeCat
- Function Management
- Catalog Management
- Database Management
- Table Management
- Data Table Statistics
- Zone-based Management
- Partition Statistics
- Authorization Management
- User Group Management
- Metadata Statistics
Role Management
- Creating a Role
- Listing Roles on Different Pages by Condition
- Deleting a Role
- Obtaining a Role
- Modifying a Role
- Listing All Role Names
- Querying the Users or User groups Under a Role
- Adding One or More Users or User Groups to a Role
- Removing One or More Users or User Groups from a Role
- Updating the Entities in a Role
- Credential Management
- Configuration Management
- User
Console
- Application Examples
- Appendix
- FAQs
Show all
Managing Catalogs
A data catalog is a metadata management object that can contain multiple databases.
Multiple catalogs can be created and managed in LakeFormation to isolate metadata of different external clusters.
- A LakeFormation instance has been created and is running properly.
- Catalog data is stored in OBS and the permission to perform operations on OBS is obtained.
- You have created an OBS parallel file system for storing catalog data by referring to Creating a Metadata Storage Path.
Managing Catalogs
- Log in to the LakeFormation console.
- In the upper left corner, click
and choose Analytics > LakeFormation to access the LakeFormation console.
- Select the LakeFormation instance to be operated from the drop-down list on the left and choose Metadata > Catalog in the navigation pane.
- Click Create and set the parameters.
- In the Basic Information area, set the related parameters.
Table 1 Parameters for creating a catalog Parameter
Catalog Name
Enter a catalog name.
The value should contain 1 to 256 characters. Only letters, numbers, and underscores (_) are allowed.
Catalog Type
The options are as follows:
- DEFAULT
- CLICKHOUSE
Select Location
Select a location where catalog data is stored in the OBS parallel file system. (Optional)
Click
, select a location, and click OK.
- The selected location must start with obs:// and must contain one storage object. For example, select obs://lakeformation-test/catalog1. If no suitable parallel file system is available, click go to OBS and create one.
- You are advised to select a folder that is not selected by other catalogs.
Enter a description of the created catalog.
The content length must be between 0 and 4000 bytes (3 bytes per Chinese character).
- (Optional) Click Add under Database Storage Locations. On the Add Database Storage Location page, click
to manually select a database storage path as required, and click OK. Multiple paths can be added.
Selecting database storage path is an optional operation. If a database storage path is added, the databases in this catalog must be stored in the subpath of the database storage path or that of the selected catalog location path.
- Click Submit.
- After the catalog is created, you can view the catalog information on the Catalog page.
- Click Modify in the Operation column to modify the configurations of a catalog.
- Click Database in the Operation column to view the databases in a catalog.
- You can click More to authorize the current catalog or view its permissions.
- To delete a catalog, choose More > Delete, confirm the operation impact, and click OK.
Before deleting a catalog, you need to delete the databases under the catalog.
If files are also deleted when metadata is deleted, the metadata is moved to the recycle bin (OBS path lake-formation-trash-dir/table_id) of the corresponding OBS bucket.
