Adding Departments to the New Organization
On the department management page, an administrator can add departments and sub-departments, and edit and delete departments to maintain the organizational structure.
- Log in to the KooPhone console. The KooPhone overview page is displayed.
- In the navigation pane, choose UNI Cloud Terminal > Organizations and Users.
- In the upper left corner of the page, select the organization whose department structure needs to be optimized.
- Choose Manage Dept > Add Dept.
- Set Dept Name, Upper-Level Dept, and (optional) Dept Code, and click OK.
Figure 1 Adding a department
After setting the department code, you can search for a department by code on the department management page.
Follow-Up Operations
After adding a department, you can perform the following operations.
Operation |
Procedure |
Editing a department |
Adding a sub-department |
Deleting a department |
