Managing Smart Connect Tasks
View, delete, start, pause, or restart a Smart Connect task.
Notes and Constraints
Unavailable for single-node instances.
Prerequisite
A Smart Connect task has been created.
Viewing Smart Connect Tasks
- Log in to the Kafka console.
- Click
in the upper left corner to select the region where your instance is located. - Click the desired instance to go to the instance details page.
- In the navigation pane, choose Smart Connect.
- Click a Smart Connect task name to go to the details page.
- View the basic information, source, and target of the Smart Connect task.
The source and target are displayed on the task details page only when they have been configured for the Smart Connect task.
Deleting a Smart Connect Task
- Click
- In the row containing the Smart Connect task to be deleted, click Delete.
- Click OK.
The task is deleted when it is no longer displayed in the Smart Connect task list.
Starting or Pausing a Smart Connect Task
After a task of a Kafka instance is paused, data of the instance will not be synchronized to another Kafka instance or other cloud services.
- Click
- Perform the required operation:
- To start a Smart Connect task, click Start in the row that contains the task.
- To pause a Smart Connect task, click Pause in the row containing the task, then click OK in the dialog box that is displayed.
The task is started or paused when it is in the Running or Paused state on the Smart Connect tasks page.
Restarting a Smart Connect Task
- Click
- In the row containing the desired Smart Connect task, click Restart.
Precautions:
- Modifying the source or target parameters after a Smart Connect task is created may cause the restart to fail.
- Restarting a Smart Connect task resets the synchronization progress and the synchronization task will be restarted.
- Click OK.
Once the task is restarted, a success message is displayed in the upper area of the page.
Related Documents
- To view Smart Connect task details by calling an API, see Querying Smart Connect Task Details.
- To delete a Smart Connect task by calling an API, see Deleting a Smart Connect Task.
- To pause a Smart Connect task by calling an API, see Pausing a Smart Connect Task.
