Help Center/ Distributed Message Service for Kafka/ User Guide/ Managing Instances/ Viewing and Modifying Basic Information of a Kafka Instance
Updated on 2025-02-14 GMT+08:00
After creating a Kafka instance, you can view the details or modify some parameters of it on the console as required. These parameters include the instance name, description, security group, and capacity threshold policy.
Notes and Constraints
Single-node instances do not support reconfiguration of Smart Connect and private network access.
Prerequisite
You can modify basic information of a Kafka instance when the instance is in the Running state.
Viewing Kafka Instance Details
  1. Log in to the console.
  2. Click in the upper left corner to select the region where your instance is located.
  3. Click and choose Middleware > Distributed Message Service (for Kafka) to open the console of DMS for Kafka.
  4. In the navigation pane, choose Kafka Instances.
  5. You can filter Kafka instances by tag, status, name, version, flavor, used/available storage space, maximum partitions, billing mode, and enterprise project. Only enterprise users can filter instances by enterprise projects. For Kafka instance statuses, see Table 1.
    Table 1 Kafka instance status description
    Status
    Creating
    The instance is being created.
    Creation failed
    The instance failed to be created.
    Running
    The instance is running properly.
    Only instances in the Running state can provide services.
    Faulty
    The instance is not running properly.
    Starting
    The status between Frozen and Running.
    Restarting
    The instance is being restarted.
    Changing
    The instance specifications or public access configurations are being modified.
    Change failed
    The instance specifications or public access configurations failed to be modified.
    You cannot restart, delete, or modify an instance in the Change failed state. Contact customer service.
    Frozen
    The instance is frozen.
    Freezing
    The status between Running and Frozen.
    Upgrading
    The instance is being upgraded.
    Rolling back
    The instance is being rolled back.
    Binning
    The instance is being moved to the recycle bin.
    Binned
    The instance is in the recycle bin.
    Recovering
    The instance is being recovered from the recycle bin.
  6. Click the name of the desired Kafka instance and view detailed information about the instance on the Basic Information tab page.
    Table 2 and Table 3 describe the parameters for connecting to a Kafka instance. For details about other parameters, see the Basic Information tab page of the Kafka instance on the console.
    Table 2 Connection parameters (SASL_SSL cannot be changed)
    Section
    Connection
    Username
    Username for accessing the instance with SASL_SSL enabled.
    Kafka SASL_SSL
    Whether SASL_SSL is enabled.
    This function is unavailable for single-node instances.
    Security Protocol
    Security protocol used by the instance with SASL_SSL enabled.
    SASL Mechanism
    SASL mechanism used by the instance with SASL_SSL enabled.
    SSL Certificate
    Click Download to download the SSL certificate for accessing the instance.
    Instance Address (Private Network)
    Address for connecting to the instance when public access is disabled.
    The number of connection addresses is the same as that of brokers.
    Manager Address (Private Network)
    Address for connecting to Kafka Manager when public access is disabled.
    Instances created since May 17, 2023 do not have this address.
    Manager Username
    Username for connecting to Kafka Manager.
    Instances created since May 17, 2023 do not have this username.
    Public Access
    Indicates whether public access has been enabled for the instance.
    Instance Address (Public Network)
    Address for connecting to the instance when public access is enabled.
    This parameter is displayed only when public access is enabled.
    Manager Address (Public Network)
    Address for connecting to Kafka Manager when public access is enabled.
    Intra-VPC Plaintext Access
    Whether intra-VPC plaintext access is enabled.
    Table 3 Connection parameters (plaintext and ciphertext access)
    Section
    Sub-Parameter
    Connection
    Username
    Username for accessing the instance with ciphertext access enabled.
    Private Network Access
    Plaintext Access
    Indicates whether plaintext access is enabled.
    Address (Private Network, Plaintext)
    This parameter is displayed only after you enable Plaintext Access.
    Ciphertext Access
    Indicates whether ciphertext access is enabled.
    Address (Private Network, Ciphertext)
    This parameter is displayed only after you enable Ciphertext Access.
    Security Protocol
    Public Network Access
    Toggle switch
    Indicates whether public access has been enabled.
    Plaintext Access
    This parameter is displayed only when Public Access is enabled.
    Address (Public Network, Plaintext)
    Ciphertext Access
    Address (Public Network, Ciphertext)
    Security Protocol
    SASL Mechanism
    SSL Certificate
    This parameter is displayed only when SASL_SSL is enabled.
  5. Click the desired instance to go to the instance details page.
  6. Modify the following parameters if needed:
    Table 4 Modifiable Kafka parameters
    How to Modify
    Result
    Instance Name
    Click , enter a new name, and click .
    Naming rules: 4–64 characters; starts with a letter; can contain only letters, digits, hyphens (-), and underscores (_).
    The modification result is displayed in the upper right corner of the page.
    Smart Connect
    See Enabling Smart Connect and Disabling Smart Connect.
    To check the progress and result of the current task, go to the Background Tasks page.
    Click , enter a new description, and click .
    0 to 1024 characters.
    Enterprise Project
    Click , select a new enterprise project from the drop-down list, and click .
    Only for enterprise users. Modifying this parameter does not restart the instance.
    Security Group
    Click , select a new security group from the drop-down list, and click .
    See Configuring Plaintext or Ciphertext Access to Kafka Instances.
    You will be redirected to the Background Tasks page, which displays the modification progress and result.
    Public Access
    See Configuring Kafka Public Access.
    Capacity Threshold Policy
    Click the desired policy. In the displayed Confirm dialog box, click OK.
    When the policies are triggered, messages may be deleted or cannot be produced.
    Automatic Topic Creation
    Enable/Disable this Automatic Topic Creation. In the displayed Confirm dialog box, click OK.
    Changing this option may restart the instance.
    Cross-VPC Access
    See Accessing Kafka Using a VPC Endpoint Across VPCs and Accessing Kafka in a Public Network Using DNAT.
