Updated on 2025-08-21 GMT+08:00
Kafka Instance TPS
TPS tests can be performed in the following scenarios:
  • Scenario 1 (whether SASL is enabled): same topic, different SASL settings
  • Scenario 2 (synchronous or asynchronous replication): same instance, topics with different replication settings
  • Scenario 3 (synchronous or asynchronous flushing): same instance, topics with different flushing settings
  • Scenario 4 (disk type): same topic, instances with different disk types
  • Scenario 5 (number of partitions): same instance, topics with different number of partitions
Environment
Perform the following steps to set up the test environment.
  1. Purchase Kafka instances with parameters specified in Table 1. For more information, see Buying a Kafka Instance.
    Table 1 Instance parameters
    Instance Name
    Brokers
    Broker Flavor
    SASL
    Storage space per broker
    kafka-01
    3
    kafka.2u4g.cluster
    Yes
    Ultra-high I/O
    kafka-02
    3
    kafka.4u8g.cluster
    Yes
    Ultra-high I/O
    kafka-03
    3
    kafka.8u16g.cluster
    Yes
    Ultra-high I/O
    kafka-04
    3
    kafka.12u24g.cluster
    Yes
    Ultra-high I/O
    kafka-05
    3
    kafka.16u32g.cluster
    Yes
    Ultra-high I/O
    kafka-06
    3
    kafka.2u4g.cluster
    No
    Ultra-high I/O
    kafka-07
    3
    kafka.4u8g.cluster
    No
    Ultra-high I/O
    kafka-08
    3
    kafka.8u16g.cluster
    No
    Ultra-high I/O
    kafka-09
    3
    No
    Ultra-high I/O
    kafka-10
    3
    No
    Ultra-high I/O
    kafka-11
    3
    kafka.2u4g.cluster
    No
    High I/O
    kafka-12
    3
    kafka.4u8g.cluster
    No
    High I/O
    kafka-13
    3
    kafka.8u16g.cluster
    No
    High I/O
    kafka-14
    3
    No
    High I/O
    kafka-15
    3
    No
    High I/O
    After the purchase, obtain Address (Private Network, Plaintext) on the instance details page.
  2. Create topics with parameters specified in Table 2 for each instance purchased above. For details about how to create topics, see Creating a Kafka Topic.
    Table 2 Topic parameters
    Topic Name
    Synchronous Replication
    Synchronous Flushing
    Replicas
    Partitions
    topic-01
    No
    No
    3
    30
    topic-02
    Yes
    No
    3
    30
    topic-03
    No
    Yes
    3
    30
    topic-04
    No
    No
    3
    3
    topic-05
    No
    No
    3
    12
    topic-06
    No
    No
    3
    100
  3. Obtain the test tool.
    Obtain Kafka CLI v2.7.2.
  4. Purchase a server for the client.
    Buy a Linux ECS (with the same region, AZ, VPC, subnet, and security group as the Kafka instance). For details about how to purchase an ECS, see Purchasing an ECS.
    Perform the following operations on the ECSs:
    • Install Java JDK and configure the environment variables JAVA_HOME and PATH.
      export JAVA_HOME=/root/jdk1.8.0_231
      export PATH=$JAVA_HOME/bin:$PATH
    • Download Kafka CLI v2.7.2 and decompress it.
      tar -zxf kafka_2.12-2.7.2.tgz
Script
./kafka-producer-perf-test.sh --producer-props bootstrap.servers={Connection address} acks=1 batch.size=16384 linger.ms=10 --topic {Topic name} --num-records 10000000 --record-size 1024 --throughput -1 --producer.config ../config/producer.properties
Table 3 Script parameters
bootstrap.servers
Address of the Kafka instance obtained in 1.
acks
Message synchronization policy. acks=1 indicates asynchronous replication, and acks=-1 indicates synchronous replication.
batch.size
Size of messages sent in each batch, in bytes.
linger.ms
Interval between two batches.
topic
Topic name set in 2.
num-records
Total number of messages to be sent.
record-size
Size of each message.
throughput
Number of messages sent per second.
Result
The test results of the five test scenarios are as follows:
Test scenarios:
  • Scenario 1 (whether SASL is enabled): same topic (30 partitions, 3 replicas, asynchronous replication, and asynchronous flushing), instances with SASL enabled or disabled.
  • Scenario 2 (synchronous/asynchronous replication): same instance (ultra-high I/O, three brokers, SASL disabled), topics with different replication settings, and number of producer processes is three.
  • Scenario 3 (synchronous/asynchronous replication flushing): same instance (ultra-high I/O, three brokers, SASL disabled), topics with different flushing settings.
  • Scenario 4 (different disk types): same topic (30 partitions, 3 replicas, asynchronous replication, and asynchronous flushing) with different disk types.
  • Scenario 5 (different numbers of partitions): same instance (ultra-high I/O, three brokers, SASL disabled), topics with different number of partitions.
