Updated on 2025-08-21 GMT+08:00
Exporting the Kafka Instance List
You can export a list of instances on the DMS for Kafka console.
  1. Log in to the Kafka console.
  2. Click in the upper left corner to select the region where your instance is located.
  3. Export the instance list in either of the following ways:
    • Select the desired instances and choose Export > Export selected data to an XLSX file to export specified instances.
    • Choose Export > Export all data to an XLSX file to export all instances.
