Modifying Kafka Topic Configurations
This section describes how to modify configurations in Table 1 of a Kafka topic on the console.
Modifying Synchronous Replication, Synchronous Flushing, Message Timestamp, Max. Message Size, or Description does not require an instance restart.
        Parameter  |
        Description  |
        Partitions  |
        Number of partitions in a topic. For details about how to change, see Changing Kafka Partition Quantity.  |
        Aging Time (h)  |
        Maximum message retention. For details about how to change, see Changing Kafka Message Retention Period.  |
        Replicas  |
        Number of replicas of each topic partition. To modify it, see Modifying Kafka Topic Replicas.  |
        Synchronous Replication  |
        A message is returned to the client only after the message creation request has been received and the message has been acknowledged by all replicas.  |
        Synchronous Flushing  |
        Message Timestamp  |
        Timestamp type of a message. Options:
        Max. Message Size  |
        Maximum size of messages to be processed in batches. If message compression is enabled, this parameter indicates the size after compression. If this value is increased and the consumer version is earlier than 0.10.2, the consumers' fetch size must also be increased so that they can obtain the latest value.  |
        Description  |
        Topic description.  |
Notes and Constraints
- If there is only one replica, Synchronous Replication cannot be enabled.
 - After enabling synchronous replication, set acks to all or –1 on the client. Otherwise, this function will not take effect.
 - A maximum of 50 topics can be modified in a batch at a time.
One or more topics can be modified on the Kafka console. To modify topics in batches, their descriptions cannot be modified.
- Log in to the Kafka console.
 - Click
 in the upper left corner to select the region where your instance is located. - Click the desired instance to go to the instance details page.
 - In the navigation pane, choose Instance > Topics.
 - In the row containing the desired topic, click Edit.
 - In the Edit Topic dialog box, change configurations and click OK.
View the reconfiguration on the Topics page.
 - Click
 - Select the desired topics and click Batch Edit Topic on the upper left.
 - In the Batch Operations area, select the items listed in Table 2. In the Preview Change area, view the unchanged and changed items. Click OK.
      Figure 1 Modifying topics in batches
      Table 2 Topic configuration parameters Parameter
Select it and enable or disable this function.
Message Timestamp
Select it and select CreateTime or LogAppendTime from the drop-down list box.
Max. Message Size (bytes)
Select it and enter a value.
Related Document
To modify topic configurations by calling an API, see Modifying Topics of a Kafka Instance.
