Using IAM Roles or Policies to Grant Access to DMS for Kafka
System-defined permissions in role/policy-based authorization provided by Identity and Access Management (IAM) let you control access to DMS for Kafka. With IAM, you can:
- Create IAM users for personnel based on your enterprise's organizational structure. Each IAM user has their own identity credentials for accessing DMS for Kafka resources.
- Grant users only the permissions required to perform a given task based on their job responsibilities.
- Entrust another HUAWEI ID or cloud service to perform efficient O&M on your DMS for Kafka resources.
If your HUAWEI ID meets your permissions requirements, you can skip this section.
Figure 1 shows the process flow of role/policy-based authorization.
Before assigning permissions to user groups, learn about system-defined permissions in role/policy-based authorization for DMS for Kafka. To grant permissions for other services, learn about all system-defined permissions supported by IAM.
DMS for Kafka permissions policies are based on DMS. Therefore, when assigning permissions for user groups, select DMS permissions policies.
Process Flow
For the following example, create a user group on the IAM console and assign the DMS ReadOnlyAccess policy to the group.
- Log in as the IAM user and verify permissions.
In the authorized region, perform the following operations:
- Choose Service List > Distributed Message Service (for Kafka). Then click Buy Instance on the console of DMS for Kafka. If a message appears indicating that you cannot perform the operation, the DMS ReadOnlyAccess policy is in effect.
- Choose Service List > Elastic Volume Service. If a message appears indicating that you have insufficient permissions, the DMS ReadOnlyAccess policy is in effect.
- Choose Service List > Distributed Message Service (for Kafka). If the Kafka instance list can be displayed, the DMS ReadOnlyAccess policy is in effect.
Example Custom Policies
You can create custom policies to supplement the system-defined policies of DMS for Kafka. For details about actions supported in custom policies, see Actions Supported by Policy-based Authorization.
To create a custom policy, choose either visual editor or JSON.
- Visual editor: Select cloud services, actions, resources, and request conditions. This does not require knowledge of policy syntax.
- JSON: Create a JSON policy or edit an existing one.
For details, see Creating a Custom Policy. The following lists examples of common DMS for Kafka custom policies.
- Example 1: Grant permission to delete and restart instances.
{ "Version": "1.1", "Statement": [ { "Effect": "Allow", "Action": [ "dms:instance:modifyStatus", "dms:instance:delete" ] } ] } - Example 2: Grant permission to deny instance deletion.
A policy with only "Deny" permissions must be used together with other policies. If the permissions granted to an IAM user contain both "Allow" and "Deny", the "Deny" permissions take precedence over the "Allow" permissions.
For example, if you want to assign all of the permissions of the DMS FullAccess policy to a user, except for deleting instances, you can create a custom policy to deny only instance deletion. When you apply both the DMS FullAccess policy and the custom policy denying instance deletion, since "Deny" always takes precedence over "Allow", the "Deny" will be applied for that one conflicting permission. The user will then be able to perform all operations on instances except deleting instances. The following is an example of a deny policy:
{ "Version": "1.1", "Statement": [ { "Effect": "Deny", "Action": [ "dms:instance:delete" ] } ] }
DMS for Kafka Resources
A resource is an object that exists within a service. DMS for Kafka resources include kafka. To select these resources, specify their paths.
Resource | Resource Name | Path |
kafka | Instance | [Format] DMS:*:*: kafka:instance ID [Notes] For instance resources, IAM automatically generates the prefix (DMS:*:*:kafka:) of the resource path. For the path of a specific resource, add the instance ID to the end. You can also use an asterisk * to indicate any resource. For example: DMS:*:*:kafka:* indicates any Kafka instance. |
topic | Topic | [Format] DMS:*:*:topic:instance ID/topic name [Notes] For topic resources, IAM automatically generates the prefix (DMS:*:*:topic:) of the resource path. For the path of a specific resource, add the instance ID/topic name to the end. You can also use an asterisk * to indicate any resource. For example: DMS:*:*:topic:* indicates any topic. |
consumerGroup | Consumer group | [Format] DMS:*:*:consumerGroup:instance ID/consumer group name [Notes] For instance resources, IAM automatically generates the prefix (DMS:*:*:consumerGroup:) of the resource path. For the path of a specific resource, add the instance ID/consumer group name to the end. You can also use an asterisk * to indicate any resource. For example: DMS:*:*:consumerGroup:* indicates any consumer group. |
DMS for Kafka Request Conditions
Request conditions are useful in determining when a custom policy is in effect. A request condition consists of condition keys and operators. Condition keys are either global or service-level and are used in the Condition element of a policy statement. Global condition keys (starting with g:) are available for operations of all services, while service-specific condition keys (starting with a service name such as dms:) are available only for operations of specific services. An operator must be used together with a condition key to form a complete condition statement.
DMS for Kafka has a group of predefined condition keys that can be used in IAM. For example, to define an "Allow" permission, use the condition dms:ssl to filter instances by SASL configurations. The following table lists the DMS for Kafka predefined condition keys.
Condition Key | Operator | Description |
dms:connector | Bool | Whether Smart Connect is enabled |
dms:publicIP | Bool | Whether public access is enabled |
dms:ssl | Bool | Whether SSL is enabled |
