HarmonyOS Device Management
Overview
HarmonyOS distributed soft bus (DSoftBus) facilitates seamless intra-device and inter-device distributed communications by connecting various devices over a local area network (LAN). It ensures high throughput, reliability, and low latency. For nearby devices, DSoftBus offers device discovery and transport interfaces that streamline device connection, task distribution, and data transmission without the need for developers to manage networking modes or protocols.
The soft bus leverages the deviceauth component of the OpenHarmony security subsystem to create interfaces for efficiently establishing trusted authentication and connections between devices. To enhance the security and reliability of device relationships, IoTDA can be utilized to define and transmit the relationship network for seamless device authentication.
Device Requirements
- The device uses HarmonyOS.
- The device can communicate with the platform using MQTT.
Service Flow
- Creating a HarmonyOS group: You create a soft bus connection group on the IoTDA console to manage the device interconnection network.
- Authenticating the device: The device initiates MQTT/MQTTS device authentication.
- Reporting device information: The client goes online and reports device information, such as the software and hardware versions and device IP address.
- Delivering the group list from the cloud: After the authentication is successful, the platform delivers the corresponding group list and PIN.
- Responding: If the device receives the soft bus list, it needs to return a response. Otherwise, the cloud will deliver the list repeatedly.
- Obtaining the latest soft bus information: The device queries the soft bus information through the API.
- Returning the latest soft bus information: When 6 occurs, the platform returns the query result.
- Delivering the PIN data from the cloud to initialize the soft bus: The platform delivers the PIN data, including the device ID, IP address, and connection key.
- Verifying the client PIN: The connection key is verified to check whether the device has the connection permission, enhancing security within the HarmonyOS group.
- Returning the initialization result: The soft bus initialization result is returned.
Device Authentication and Information Reporting
- You need to register a device before using IoTDA.
- The client uses the MQTT protocol to authenticate the device. For details, see Using MQTT.fx to Send and Receive Messages.
- The device reports device information through the API for reporting device information.
HarmonyOS Group Creation
- Access the IoTDA service page and click Access Console. Click the target instance card.
- In the navigation pane, choose Devices > Groups. On the displayed page, select the resource space to which the registered device belongs, and click Add Root Group. In the displayed dialog box, select Static and click OK. Figure 3 Group - Adding a static group
- Click the name of the created group, click Bind, select the devices to be associated, and click OK. Figure 4 Group - Binding a device to a group
- After the binding is successful, click the button for creating a HarmonyOS soft bus, enter the soft bus name, and click OK. Figure 5 Group - Creating a HarmonyOS soft bus
- The soft bus synchronization status is displayed on the platform. The key of the soft bus is randomly generated by the platform. The settings are automatically delivered when devices in the group go online. You can also click the button for synchronization to manually deliver the settings. Figure 6 Group - Configuring the HarmonyOS soft bus
Soft Bus Group List and PIN Delivery from the Cloud
- The platform automatically delivers the soft bus group list. Example format:
Topic: $oc/devices/{device_id}/sys/properties/set/request_id={request_id} Data format: { "object_device_id": "{object_device_id} ", "services": [{ "service_id": "$oh_soft_bus", "properties": { "bus_id1": { "version": 1 }, "bus_id2": { "version": 2 } } }] }Table 1 Parameters for soft bus group list delivery from the cloud Parameter
Mandatory
Type
object_device_id
No
String
Explanation:
- For a gateway child device: The value is the child device ID in the topic.
- For a directly connected device: The value is the same that of device_id in the topic.
services
No
List<ServiceEvent>
Explanation:
List of services that an event is about.
Table 2 ServiceEvent definition Parameter
Mandatory
Type
service_id
Yes
String
Explanation:
System field.
Value range:
The value is fixed at $oh_soft_bus.
properties
Yes
String
Explanation:
Event parameters in JSON format.
Table 3 properties parameters Parameter
Mandatory
Type
bus_id
Yes
String
Explanation:
Soft bus ID.
version
Yes
Object
Explanation:
Version number. When a group is updated, the version number is increased by 1 and the initial version number is 0. If the group is deleted, the version number is -1.
- The device responds to the automatic delivery of the soft bus group list from the cloud.
Topic: $oc/devices/{device_id}/sys/properties/set/response/request_id={request_id} Data format: { "result_code": 0, "result_desc": "success" }Table 4 Response parameters Parameter
Mandatory
Type
result_code
No
Integer
Explanation:
Execution result. 0 indicates success, and other values indicate failure. If this parameter is not carried, the execution is considered successful.
result_desc
No
String
Explanation:
Response description, which is user-defined.
Device Obtaining the Latest Soft Bus Information
After a device goes online, it can obtain the data of the soft bus through the corresponding API.
- The device proactively obtains the latest soft bus information.
Topic: $oc/devices/{device_id}/sys/events/up Data format: { "object_device_id": "{object_device_id}", "services": [{ "service_id": "$oh_soft_bus", "event_type": "soft_bus_config_request", "event_time": "20151212T121212Z", "event_id": "40cc9ab1-3xxxxxxx-c18941c99eb4", "paras": { "bus_id":"04ed32xxxxxxxx3c01a27c2babc" } }] }Table 5 Parameters for the device to obtain the latest soft bus information Parameter
Mandatory
Type
object_device_id
No
String
Explanation:
- Mandatory when the child device reports data during the gateway device data reporting. Specify object_device_id as the child device ID of the device in the topic. Otherwise, the request fails.
- When a directly connected device reports data, the value of object_device_id must be the same as that of device_id in the topic.
- If this parameter is left blank, the value of this parameter is the same as that of device_id in the topic by default.
services
No
List<ServiceEvent>
Explanation:
Table 6 ServiceEvent definition Parameter
Mandatory
Type
service_id
Yes
String
Explanation:
System field.
Value range:
event_type
Yes
String
Explanation:
System field.
Value range:
The value is fixed at soft_bus_config_request.
event_time
No
String
Explanation:
Event time. UTC time format: yyyyMMdd'T'HHmmss'Z'.
If this parameter is not carried in the reported data or is in an incorrect format, the time when the platform receives the data is used.
event_id
No
String
Explanation:
Unique event ID. If this parameter is not carried, an event ID will be generated by the platform. An event ID is a random string of 36 characters consisting of letters, numbers, and hyphens (-).
paras
Yes
Object
Explanation:
Table 7 paras parameters Parameter
Mandatory
Type
bus_id
No
String
Explanation:
Soft bus ID. If this parameter is not carried, all soft bus information of the device is returned.
- The platform returns the latest soft bus information. Normal query example:
Topic: $oc/devices/{device_id}/sys/events/down Data format: { "object_device_id": "{object_device_id}", "services": [{ "service_id": "$oh_soft_bus", "event_type": "soft_bus_config_response", "event_time": "20151212T121212Z", "event_id": "40cc9ab1-3579-488c-95c6-c18941c99eb4", "paras": { "bus_infos": [{ "bus_id": "04ed32dc1b0025b52fe3c01a27c2babc", "version": 2, "bus_name": "GroupA", "bus_key": "Y9BZ8fvnY9BZ8fvn1111", "devices_info": [{ "device_id": "device_id1", "device_ip": "127.0.0.1" }, { "device_id": "device_id2", "device_ip": "127.0.0.2" }], "device_count": 2 }], "bus_count": 1 } }] }Abnormal query example:
{ "object_device_id": "{object_device_id}", "services": [{ "service_id": "$oh_soft_bus", "event_type": "soft_bus_config_response", "event_time": "20151212T121212Z", "event_id": "40cc9ab1-3579-488c-95c6-c18941c99eb4", "paras": { "bus_infos": [], "bus_count": 0, "error_info":{ "error_code": "IOTDA.003002", "error_msg":"The soft bus group does not exist." } } }] }Table 8 Parameters for the platform to return the latest soft bus information Parameter
Mandatory
Type
object_device_id
No
String
Explanation:
services
No
List<ServiceEvent>
Explanation:
Table 9 ServiceEvent definition Parameter
Mandatory
Type
service_id
Yes
String
Explanation:
System field.
Value range:
event_type
Yes
String
Explanation:
System field.
Value range:
The value is fixed at soft_bus_config_response.
event_time
No
String
Explanation:
event_id
No
String
Explanation:
paras
Yes
Object
Explanation:
Table 10 paras parameters Parameter
Mandatory
Type
bus_infos
Yes
Object
Explanation:
JSON list of soft bus information.
bus_count
Yes
Integer
Explanation:
Number of JSON lists for soft bus information.
error_info
No
Object
Explanation:
JSON list of error information. This field is delivered when the query fails.
Table 11 bus_infos parameters Parameter
Mandatory
Type
bus_id
Yes
String
Explanation:
version
Yes
String
Explanation:
bus_name
Yes
String
Explanation:
Soft bus name.
bus_key
Yes
String
Explanation:
Key.
devices_info
Yes
Object
Explanation:
JSON list of group device information.
device_count
Yes
Integer
Explanation:
Number of devices in a group.
Value range:
0 to 100.
Table 12 devices_info parameters Parameter
Mandatory
Type
device_id
Yes
String
Explanation:
Device ID.
device_ip
Yes
String
Explanation:
Device IP address.
Table 13 error_info parameters Parameter
Mandatory
Type
error_code
Yes
String
Explanation:
Error code.
error_msg
Yes
String
Explanation:
Error description.
Device-side SDK Usage
HarmonyOS SDKs provide soft bus code demos (OpenHarmony-sdk-c).
Directory: src/softBus_demo. The following table lists the main APIs.
| Subfunction Name | Description |
| IOTA_ReportDeviceInfo | Reports device information, including the device IP address, software version, and hardware version. |
| IOTA_SetEventCallback | Configures the callback function for event delivery. |
| IOTA_PropertiesSetResponse | Responds to the soft bus data delivered by the platform. |
| IOTA_GetLatestSoftBusInfo | (Device) Obtains the latest soft bus information. |
| getSoftBusTotal | Obtains the latest soft bus information of the platform after parsing. Structure data obtained after the IOTA_GetLatestSoftBusInfo function is executed and the platform returns a value. |
SDK Suite Usage
HarmonyOS provides local interconnection capability of DSoftBus. By calling the initialization API through the Huawei Cloud SDK, you can obtain connection information and use it for initialization.
