Updated on 2026-09-30 GMT+08:00
Requirements
IoTDA provides device topic policies, with which you can authorize clients to publish or subscribe to messages through custom topics not starting with $oc, enhancing communications security. Device policies are mainly used for protocols used in data publishing and subscription mechanisms, for example, MQTT and MQTTS on the device side.
Policy Wildcards
You can use wildcards for policies. An asterisk (*) indicates any combination of characters, and a question mark (?) indicates a character of any kinds. Plus signs (+) and number signs (#) do not have special meanings.
Table 1 Policy wildcards
Wildcard
MQTT Wildcard
Applicable to Policy
Example MQTT Topic
Example MQTT Topic for Policy
Yes
No
test/#
Not applicable. The number sign (#) is regarded as a character without special meaning.
Yes
No
test/+/some
Not applicable. The plus sign (+) is regarded as a character without special meaning.
No
Yes
Not applicable. The asterisk (*) is regarded as a character without special meaning.
test/*
test/*/some
No
Yes
Not applicable. The question mark (?) is regarded as a character without special meaning.
test/????/some
test/set?????/some
Table 2 Example usage of wildcards in policies
Target Topic
Topic Definition
Example topics:
test/topic1/some
test/topic2/some
test/topic3/some
topic:test/topic?/some
Common points: test/topic + a character + /some. In the policy definition, a question mark (?) indicates a character. Therefore, the policy topic can be defined as topic:test/topic?/some.
Example topics:
test/topic1/pub/some
test/topic2/sub/some
test/topic3/some
topic:test/topic*/some
Common points: test/topic + one or more characters + /some. In policy definition, the asterisk (*) indicates multiple or one character. Therefore, the policy topic can be defined as topic:test/topic*/some.
Policy Variables
You can use a policy variable as a placeholder for resource or condition key to filter topics when defining policy resource. During MQTT topic verification, the system replaces the variable with the corresponding ID for matching.
Variables are prefixed with a dollar sign ($), followed by a pair of braces ({}), which contain the variable name in the request. The following table lists the supported variables. Assume that the client ID of an MQTT device is test_clientId, the product ID is test_productId, and the device ID is test_deviceId.
Table 3 Policy variables
Policy Variable
Example MQTT Topic
${devices.deviceId}
Device ID
test/test_deviceId/topic
test/${devices.deviceId}/topic
${devices.clientId}
Client ID
test/test_clientId/topic
test/${devices.clientId}/topic
${devices.productId}
Product ID
test/test_productId/topic
test/${devices.productId}/topic
Table 4 Example usage of variables in policies
Example Policy Topic Definition
Distinguishing topics by device
Devices can subscribe to or publish messages through topic test/${Device ID}/topic with their data isolated.
Distinguishing topics by device and time segment
Devices can subscribe to or publish messages through topic test/${Device client ID}/topic. Different from deviceId, clientId carries a timestamp to distinguish time segments.
Policy Priority
If multiple policies with different effects are bound to the same device, the policy with higher priority (Denied over Allowed) takes effect.
For example, a device has two policies: policy 1 and policy 2. Policy 1 denies subscription to topic A, and policy 2 allows subscription to topic A. When the device subscribes to topic A, the platform rejects the subscription request from the device.
Table 5 Policy priority
Topic
Policy 1
Policy 2
Effective Policy
test/topic
"effect": "ALLOW",
"resources": ["topic:test/topic" ]
"effect": "DENY",
Denied
Policy Topic Constraints
  1. Maximum length: 128 bytes.
  2. Unallowed wildcards for topic publishing: number signs (#) and plus signs (+).
  3. Consecutive slashes (/) are not allowed, for example, ////test/.
  4. Maximum slashes (/) in a topic: 7.
If the topic to be published or subscribed to does not meet the preceding requirements, the subscription or publishing request will be rejected. On the device details page, click the Message Trace tab. The error information is displayed.
Figure 1 Message tracing - Verifying a policy
