Internal Functions
Huawei Cloud IoTDA provides multiple internal functions to use in templates. This section introduces these functions, including the input parameter type, parameter length, and return value type.
- The entire function must be in valid JSON format.
- In a function, the variable placeholders (${}) or the Ref function can be used to reference the value defined by the input parameter.
- The parameters used by the function must be declared in the template.
- A function with a single input parameter is followed by a parameter, for example, "Fn::Base64Decode": "${iotda::mqtt::username}".
- A function with multiple input parameters is followed by an array, for example, "Fn::HmacSHA256": ["${iotda::mqtt::username}", "${iotda::device::secret}"].
- Functions can be nested. That is, the parameter of a function can be another function. Note that the return value of a nested function must match its parameter type in the outer function, for example, {"Fn::HmacSHA256": ["${iotda::mqtt::username}", {"Fn::Base64Encode": "${iotda::device::secret}"}]}.
Fn::ArraySelect
The internal function Fn::ArraySelect returns a string element whose index is index in a string array.
JSON
{"Fn::ArraySelect": [index, [StringArray]]}
Parameter |
Type |
Description |
index |
int |
Index of an array element. The value is an integer and starts from 0. |
StringArray |
String[] |
String array element. |
Return values |
String |
Element whose index is index. |
Example:
{ "Fn::ArraySelect": [1, ["123", "456", "789"]] } return: "456"
Fn::Base64Decode
The internal function Fn::Base64Decode decodes a string into a byte array using Base64.
JSON
{ "Fn::Base64Decode" : "content" }
Parameter |
Type |
Description |
content |
String |
String to be decoded. |
Return Values |
byte[] |
Base64-decoded byte array. |
Example:
{ "Fn::Base64Decode": "123456"] } return: d76df8e7 // The value is converted into a hexadecimal string for display.
Fn::Base64Encode
The internal function Fn::Base64Encode encodes a string using Base64.
JSON
{"Fn::Base64Encode": "content"}
Parameter |
Type |
Description |
content |
String |
String to be encoded. |
Return Values |
String |
Base64-encoded string. |
Example:
{ "Fn::Base64Encode": "testvalue" } return: "dGVzdHZhbHVl"
Fn::GetBytes
The internal function Fn::GetBytes returns a byte array encoded from a string using UTF-8.
JSON
{"Fn::GetBytes": "content"}
Parameter |
Type |
Description |
content |
String |
Return Values |
byte[] |
Byte array converted from a string encoded using UTF-8. |
Example:
{ "Fn::GetBytes": "testvalue" } return: "7465737476616c7565" // The value is converted into a hexadecimal string for display.
Fn::HmacSHA256
The internal function Fn::HmacSHA256 encrypts a string using the HMACSHA256 algorithm based on a given secret.
JSON
{"Fn::HmacSHA256": ["content", "secret"]}
Parameter |
Type |
Description |
content |
String |
String to be encrypted. |
secret |
String or byte[] |
Secret key, which can be a string or byte array. |
Return Values |
String |
Value encrypted using the HMACSHA256 algorithm. |
Example:
{ "Fn::HmacSHA256": ["testvalue", "123456"] } return: "0f9fb47bd47449b6ffac1be951a5c18a7eff694940b1a075b973ff9054a08be3"
Fn::Join
The internal function Fn::Join can concatenate up to 10 strings into one string.
JSON
{"Fn::Join": ["element", "element"...]}
Parameter |
Type |
Description |
element |
String |
String to be concatenated. |
Return Values |
String |
String obtained by concatenating substrings. |
Example:
{ "Fn::Join": ["123", "456", "789"] } return: "123456789"
Fn::MathAdd
The internal function Fn::MathAdd performs mathematical addition on two integers.
JSON
{"Fn::MathAdd": [X, Y]}
Parameter |
Type |
Description |
X |
long |
Augend. |
Y |
long |
Addend. |
Return Values |
long |
Sum of X and Y. |
Example:
{ "Fn::MathAdd": [1, 1] } return: 2
Fn::MathDiv
The internal function Fn::MathDiv performs a mathematical division on two integers.
JSON
{"Fn::MathDiv": [X, Y]}
Parameter |
Type |
Description |
X |
long |
Dividend. |
Y |
long |
Divisor. |
Return Values |
long |
Value of X divided by Y. |
Example:
{ "Fn::MathDiv": [10, 2] } return: 5 { "Fn::MathDiv": [10, 3] } return: 3
Fn::MathMod
The internal function Fn::MathMod performs the mathematical modulo on two integers.
JSON
{"Fn::MathMod": [X, Y]}
Parameter |
Type |
Description |
X |
long |
Dividend. |
Y |
long |
Divisor. |
Return Values |
long |
Residue of X modulo Y. |
Example:
{ "Fn::MathMod": [10, 3] } return: 1
Fn::MathMultiply
The internal function Fn::MathMultiply performs mathematical multiplication on two integers.
JSON
{"Fn::MathMultiply": [X, Y]}
Parameter |
Type |
Description |
X |
long |
Multiplicand. |
Y |
long |
Multiplier. |
Return Values |
long |
Value of X multiplied by Y. |
Example:
{ "Fn::MathMultiply": [3, 3] } return: 9
Fn::MathSub
The internal function Fn::MathSub performs mathematical subtraction on two integers.
JSON
{"Fn::MathSub": [X, Y]}
Parameter |
Type |
Description |
X |
long |
Minuend. |
Y |
long |
Subtrahend. |
Return Values |
long |
Value of X minus Y. |
Example:
{ "Fn::MathSub": [9, 3] } return: 6
Fn::ParseLong
The internal function Fn::ParseLong can convert a numeric string into an integer.
JSON
{"Fn::ParseLong": "String"}
Parameter |
Type |
Description |
String |
String |
String to be converted. |
Return Values |
long |
Value obtained after a string is converted into an integer. |
Example:
{ "Fn::ParseLong": "123" } return: 123
Fn::Split
The internal function Fn::Split splits a string into a string array based on the specified separator.
JSON
{ "Fn::Split" : ["String", "Separator"] }
Parameter |
Type |
Description |
String |
String |
String to be split. |
Separator |
String |
Separator. |
Return Values |
String[] |
String array obtained after String is split by Separator. |
Example:
{ "Fn::Split": ["a|b|c", "|"] } return: ["a", "b", "c"]
Fn::SplitSelect
The internal function Fn::SplitSelect splits a string into a string array based on the specified separator, and then returns the elements of the specified index in the array.
JSON
{ "Fn::SplitSelect" : ["String", "Separator", index] }
Parameter |
Type |
Description |
String |
String |
Separator |
String |
Separator. |
index |
int |
Index value of the target element in the array, starting from 0. |
Return Values |
String |
Substring of the specified index after a string is split by the specified separator. |
Example:
{ "Fn::SplitSelect": ["a|b|c", "|", 1] } return: "b"
Fn::Sub
The internal function Fn::Sub replaces variables in an input string with specified values. You can use this function in a template to construct a dynamic string.
JSON
{ "Fn::Sub" : [ "String", { "Var1Name": Var1Value, "Var2Name": Var2Value } ] }
Parameter |
Type |
Description |
String |
String |
A string that contains variables. Variables are defined using placeholders (${}). |
VarName |
String |
Variable name, which must be defined in the String parameter. |
VarValue |
String |
Variable value. Function nesting is supported. |
Return Values |
String |
Value of string after replacement in the original String parameter |
Example:
{ "Fn::Sub": ["${token};hmacsha256", { "token": { "Fn::HmacSHA256": ["${iotda::mqtt::username}", { "Fn::Base64Decode": "${iotda::mqtt::client_id}" }] } }] } If: ${iotda::mqtt::username}="test_device_username" ${iotda::device::client_id}="OozqTPlCWTTJjEH/5s+T6w==" return: "0773c4fd6c92902a1b2f4a45fdcdec416b6fc2bc6585200b496e460e2ef31c3d"
Fn::SubStringAfter
The internal function Fn::SubStringAfter truncates the substring after the specified separator in a string.
JSON
{ "Fn::SubStringAfter" : ["content", "separator"] }
Parameter |
Type |
Description |
content |
String |
String to be truncated. |
separator |
String |
Separator. |
Return Values |
String |
Substring after the specified separator that separates the string. |
Example:
{ "Fn::SubStringAfter": ["content:123456", ":"] ] return: "123456"
Fn::SubStringBefore
The internal function Fn::SubStringBefore truncates the substring before the specified separator in a string.
JSON
{ "Fn::SubStringBefore" : ["content", "separator"] }
Parameter |
Type |
Description |
content |
String |
separator |
String |
Separator. |
Return Values |
String |
Substring before the specified separator that separates the string. |
Example:
{ "Fn::SubStringBefore": ["content:123456", ":"] ] return: "content"
Ref
The internal function Ref returns the value of the specified referenced parameter. The referenced parameter must be declared in the template.
JSON
{ "Ref" : "paramName" }
Parameter |
Type |
Description |
paramName |
String |
Name of the referenced parameter. |
Return Values |
String |
Value of the referenced parameter. |
Example:
{ "Ref": "iotda::mqtt::username" } When iotda::mqtt::username="device_123" return: "device_123"
