Updated on 2025-12-26 GMT+08:00
Advanced Search
Overview
To quickly find the desired device, you can use advanced search to set flexible search criteria using SQL-like statements to search. For example, you can search for devices by prefix fuzzy match or by tag. This section guides you on using advanced search and SQL-like syntax.
  • This function is supported only by Standard and Enterprise editions, but not Basic edition.
  • The maximum TPS for an account to call this API is 1 (one request per second).
Device search: On the All Devices > Device List page, use SQL-like statements to search for specified devices for subsequent management operations.
Dynamic device grouping: Based on the rules of SQL-like statement, devices that meet the filter criteria are automatically added to the group for management.
  1. Access the IoTDA service page and click Access Console. Click the target instance card.
  2. In the navigation pane, choose Devices > All Devices. By default, all devices under your account are displayed in the device list.
  3. Click Advanced Search, enter an SQL-like statement, and click Search to display the target devices.
    Figure 1 Device - Advanced search
SQL-like Syntax
When using SQL-like statements on the console, omit the select, from, order by, and limit clauses. You only need to enter a where clause to edit user-defined conditions. The maximum length of a statement is 400 characters. The content in the clause is case sensitive, but keywords in SQL statements are case insensitive. On the console, data is sorted based on the marker field desc by default.
A where clause:
[condition1] AND [condition2]
Example:
product_id = 'testProductId'
Up to five conditions are supported. Conditions cannot be nested. For details about the parameters that support query, see Table 1 and Table 2.
AND and OR are supported. For details about the priority, see the standard SQL syntax. By default, the priority of AND is higher than that of OR.
Table 1 Query condition parameters
Type
Value Range
app_id
String
Resource space ID
The value can contain up to 36 characters. Only letters, digits, underscores (_), and hyphens (-) are allowed.
device_id
String
Device ID
The value can contain up to 128 characters. Only letters, digits, underscores (_), and hyphens (-) are allowed.
gateway_id
String
Gateway ID
product_id
String
ID of the product associated with the device
device_name
String
Device name
The value can contain up to 256 characters. Only letters, digits, and special characters (_?'#().,&%@!-) are allowed.
node_id
String
Node ID
The value can contain up to 64 characters. Only letters, digits, underscores (_), and hyphens (-) are allowed.
status
String
Device status
The value can be ONLINE, OFFLINE, ABNORMAL, INACTIVE, or FROZEN.
node_type
String
Device node type
The value can be GATEWAY (a directly connected device or gateway) and ENDPOINT (an indirectly connected device).
tag_key
String
Tag key
The value can contain up to 64 characters. Only letters, digits, underscores (_), periods (.), and hyphens (-) are allowed.
tag_value
String
Tag value
The value can contain up to 128 characters. Only letters, digits, underscores (_), periods (.), and hyphens (-) are allowed.
sw_version
String
Software version
The value can contain up to 64 characters. Only letters, digits, underscores (_), hyphens (-), and periods (.) are allowed.
fw_version
String
Firmware version
group_id
String
Group ID
The value can contain up to 36 characters, including hexadecimal strings and hyphens (-).
create_time
String
Device registration time
Format: yyyy-MM-dd'T'HH:mm:ss.SSS'Z', for example, 2015-06-06T12:10:10.000Z
marker
String
Result record ID
The value is a string of 24 hexadecimal characters, for example, ffffffffffffffffffffffff.
Table 2 Supported operators
Operator
Supported By
All parameters
All parameters
create_time and marker
like
device_name, node_id, tag_key, and tag_value
in
Parameters except tag_key and tag_value.
not in
SQL Restrictions
  • like: Only prefix match is supported. Suffix match or wildcard match is not supported. At least four characters must be contained for prefix match. Special characters cannot be contained. Only letters, digits, underscores (_), and hyphens (-) are allowed. The prefix must end with a percent sign (%).
  • Other SQL statements, such as nested SQL statements, union, join, and alias, are not supported.
  • The SQL statement can contain up to 400 characters. Up to five request conditions are supported.
  • The condition value cannot be null or an empty string.
