OTA Upgrade for NB-IoT Devices
Software Upgrade for Devices Using LwM2M over CoAP
The SOTA process for a device using LwM2M over CoAP is as follows:
1–2: A user uploads a software package on the IoTDA console and creates a software upgrade task on the console or an application.
3. A device reports data to the platform. The platform detects that the device is online and triggers the upgrade negotiation process. (The timeout interval is 24 hours.)
- If the returned software version is the same as the target version, no upgrade is required.
- If the returned software version is different from the target version, the platform continues the upgrade.
6. The platform subscribes to the software upgrade status from the device.
- If the query is successful, the platform calculates the number of concurrent upgrade tasks based on the RSRP and SINR ranges described in the figure below, and continues with step 10.
- RSRP and SINR in range 0: 50 devices in the cell can be upgraded simultaneously.
- RSRP in range 0 and SINR in range 1: 10 devices in the cell can be upgraded simultaneously.
RSRP in range 1 and SINR in range 2: Only one device in the cell can be upgraded at a time.
RSRP and SINR can be queried but are not within any of the three ranges: Only one device in the cell can be upgraded at a time.
If only a small number of devices can be upgraded simultaneously, you can contact the local carrier to see if coverage can be improved.
- If the query fails, the process continues with step 9.
10–12: The platform notifies the device of a new software package version. The device starts to download the software package. Software packages can be downloaded in segments, and resumable download is supported. The versionCheckCode field carried in a software package segment determines the software package to which the segment belongs. After the download is complete, the device notifies the platform. (The timeout interval for step 11 is 60 minutes.)
13–14: The platform delivers an upgrade command to the device, and the device performs the upgrade. After the upgrade is complete, the device notifies the platform. (The timeout interval for the device to report the upgrade result and status is 30 minutes.)
15. The platform notifies the IoTDA console or application of the upgrade result.
Firmware Upgrade for Devices Using LwM2M
The FOTA process for a device using LwM2M is as follows:
1–2: A user uploads a firmware package on the IoTDA console and creates a firmware upgrade task on the console or an application.
- If the returned firmware version is the same as the target version, no upgrade is required.
- If the returned firmware version is different from the target version, the platform continues the upgrade.
- If the query is successful, the platform calculates the number of concurrent upgrade tasks based on the RSRP and SINR ranges described in the figure below, and continues with step 9.
- If the query fails, the process continues with step 8.
9. The platform subscribes to the firmware upgrade status from the device.
10–11: The platform delivers the package download URL. The device downloads the firmware package from the URL. After the download is complete, the device notifies the platform. (Firmware packages can be downloaded in segments, and resumable download is supported.) (The timeout interval for step 11 is 60 minutes.)
12–13: The platform delivers an upgrade command to the device, and the device performs the upgrade. After the upgrade is complete, the device notifies the platform. (The timeout interval for the device to report the upgrade result and status is 30 minutes.)
14–16: The platform delivers a command to query the firmware upgrade result. After obtaining the result, the platform unsubscribes from the upgrade status and notifies the IoTDA console or application of the upgrade result.
The platform supports resumable download.
Firmware Upgrade Failure Causes
The following table lists the failure causes reported by the platform.
Error Message |
Description |
Solution |
Device Abnormal is not online |
The device is offline or abnormal. |
Check the device. |
Task Conflict |
A task conflict occurs. |
Check whether a software upgrade, firmware upgrade, log collection, or device restart task is in progress. |
Waiting for the device online timeout |
The device does not go online within the specified time. |
Check the device. |
Wait for the device to report upgrade result timeout |
The device does not report the upgrade result within the specified time. |
Check the device. |
Waiting for report device firmware version timeout |
The device does not report the firmware version within the specified time. |
Check the device. |
Waiting for report cellId timeout |
The device does not report the cell ID within the specified time. |
Check the device. |
Updating timeout and query device version for check timeout |
The device does not report the upgrade result or device version within the specified time. |
Check the device. |
Waiting for device downloaded package timeout |
The device does not finish downloading the firmware package within the specified time. |
Check the device. |
Waiting for device start to update timeout |
The device does not start the update within the specified time. |
Check the device. |
Waiting for device start download package timeout |
The device does not start to download the firmware package within the specified time. |
Check the device. |
The following table lists the failure causes reported by devices.
Error Message |
Description |
Solution |
Not enough storage for the new firmware package |
The storage space is insufficient for the firmware package. |
Check the storage space of the device. |
Out of memory during downloading process |
The memory was insufficient during the download. |
Check the device memory. |
Connection lost during downloading process |
The connection was interrupted during the download. |
Check the device connection status. |
Integrity check failure for new downloaded package |
The integrity check on the firmware package fails. |
Check whether the firmware package downloaded is complete. |
Unsupported package type |
The firmware package type is not supported. |
Check whether the device status and firmware package provided by the manufacturer are correct. |
Invalid URI |
The URI is invalid. |
Check whether the download address of the firmware package is correct. |
Firmware update failed |
The firmware fails to update. |
Check the device. |
FAQ
