C# Demo
This section uses C# as an example to describe how to connect an MQTTS client to the platform and receive subscribed messages from the platform
Knowledge of basic C# syntax and how to configure .NET Framework development environments.
Development Environment
In this example, .NET Framework 4.6.2 and .NET SDK 6.0.421 are used. Download them from the .NET official website. After installation, run the following command to check the version:
dotnet -v
Dependency
In this example, MQTTnet and MQTTnet.Extension.ManagedClient (version 3.0.11) are used. You can search for MQTTnet in the NuGet manager and install the required version.
Sample Code
ClientConf.cs code:
using MQTTnet.Protocol;
namespace mqttcs
public class ClientConf
// MQTT subscription address
public string ServerUri { get; set; }
// MQTT subscription port number
public int Port { get; set; }
// MQTT access credential access_key
public string AccessKey { get; set; }
// MQTT access credential access_code
public string AccessCode { get; set; }
// MQTT client ID
public string ClientId { get; set; }
// Instance ID. This parameter is mandatory when multiple instances of the standard edition are purchased in the same region.
public string InstanceId { get; set; }
// MQTT subscription topic
public string Topic { get; set; }
// mqtt qos
public MqttQualityOfServiceLevel Qos { get; set; }
} MqttListener code:
using System;
using MQTTnet.Client.Connecting;
using MQTTnet.Client.Disconnecting;
using MQTTnet.Extensions.ManagedClient;
namespace mqttcs
public interface MqttListener
// Callback function when the MQTT client is disconnected from the server
void ConnectionLost(MqttClientDisconnectedEventArgs e);
// Callback function for successful connection establishment between the MQTT client and server
void ConnectComplete(MqttClientConnectResultCode resultCode, String reason);
// Callback function for consuming messages on the MQTT client
void OnMessageReceived(String message);
// Callback function when the MQTT client fails to establish a connection with the server
void ConnectFail(ManagedProcessFailedEventArgs e);
} MqttConnection.cs code:
using System;
using System.Text;
using System.Threading;
using MQTTnet;
using MQTTnet.Client.Options;
using MQTTnet.Client.Receiving;
using MQTTnet.Formatter;
namespace mqttcs
public class MqttConnection
private static IManagedMqttClient client = null;
private static ManualResetEvent mre = new ManualResetEvent(false);
private static readonly ushort DefaultKeepLive = 120;
private static int _retryTimes = 0;
private readonly int _retryTimeWait = 1000;
private readonly ClientConf _clientConf;
private MqttListener _listener;
public MqttConnection(ClientConf clientConf, MqttListener listener)
_clientConf = clientConf;
_listener = listener;
public int Connect()
client?.StopAsync();
// Backoff retry from 1s to 20s
var duration = 1000;
var maxDuration = 20 * 1000;
var rc = InternalConnect();
while (rc != 0)
Thread.Sleep((int)duration);
if (duration < maxDuration)
duration *= 2;
_retryTimes++;
Console.WriteLine("connect mqtt broker retry. times: " + _retryTimes);
return rc;
private int InternalConnect()
try
client = new MqttFactory().CreateManagedMqttClient();
client.ApplicationMessageReceivedHandler =
new MqttApplicationMessageReceivedHandlerDelegate(ApplicationMessageReceiveHandlerMethod);
client.ConnectedHandler = new MqttClientConnectedHandlerDelegate(OnMqttClientConnected);
client.DisconnectedHandler = new MqttClientDisconnectedHandlerDelegate(OnMqttClientDisconnected);
client.ConnectingFailedHandler = new ConnectingFailedHandlerDelegate(OnMqttClientConnectingFailed);
IManagedMqttClientOptions options = GetOptions();
// Connects to the platform.
client.StartAsync(options);
mre.Reset();
mre.WaitOne();
if (!client.IsConnected)
return -1;
var mqttTopicFilter = new MqttTopicFilterBuilder().WithTopic(_clientConf.Topic).WithQualityOfServiceLevel(_clientConf.Qos).Build();
client.SubscribeAsync(mqttTopicFilter).Wait();
Console.WriteLine("subscribe topic success.");
return 0;
catch (Exception e)
Console.WriteLine("Connect to mqtt server failed. err: " + e);
return -1;
private void ApplicationMessageReceiveHandlerMethod(MqttApplicationMessageReceivedEventArgs e)
string payload = null;
if (e.ApplicationMessage.Payload != null)
payload = Encoding.UTF8.GetString(e.ApplicationMessage.Payload);
try
_listener?.OnMessageReceived(payload);
catch (Exception ex)
Console.WriteLine("Message received error, the message is " + payload);
private void OnMqttClientConnected(MqttClientConnectedEventArgs e)
try
_retryTimes = 0;
_listener?.ConnectComplete(e.AuthenticateResult.ResultCode, e.AuthenticateResult.ReasonString);
mre.Set();
catch (Exception exception)
Console.WriteLine("handle connect callback failed. e: " + exception.Message);
private void OnMqttClientDisconnected(MqttClientDisconnectedEventArgs e)
try
_listener?.ConnectionLost(e);
Console.WriteLine("handle disConnect callback failed. e: " + exception.Message);
private void OnMqttClientConnectingFailed(ManagedProcessFailedEventArgs e)
try
if (_listener != null)
_listener.ConnectFail(e);
Thread.Sleep(_retryTimeWait);
Connect();
Console.WriteLine("handle connect failed callback failed. e: " + exception.Message);
private IManagedMqttClientOptions GetOptions()
IManagedMqttClientOptions options = null;
long timestamp = new DateTimeOffset(DateTime.UtcNow).ToUnixTimeMilliseconds();
string userName = "accessKey=" + _clientConf.AccessKey + "|timestamp=" + timestamp + "|instanceId=" + _clientConf.InstanceId;
options = new ManagedMqttClientOptionsBuilder()
.WithClientOptions(new MqttClientOptionsBuilder()
.WithTcpServer(_clientConf.ServerUri, _clientConf.Port)
.WithCredentials(userName, _clientConf.AccessCode)
.WithClientId(_clientConf.ClientId)
.WithKeepAlivePeriod(TimeSpan.FromSeconds(DefaultKeepLive))
.WithTls(new MqttClientOptionsBuilderTlsParameters()
AllowUntrustedCertificates = true,
UseTls = true,
CertificateValidationHandler = delegate { return true; },
IgnoreCertificateChainErrors = false,
IgnoreCertificateRevocationErrors = false,
SslProtocol = System.Security.Authentication.SslProtocols.Tls12,
.WithProtocolVersion(MqttProtocolVersion.V500)
.Build())
.Build();
return options;
} MqttClient.cs code:
using System;
using System.Threading.Tasks;
namespace mqttcs
class MqttClient: MqttListener
public static async Task Main(string[] args)
ClientConf clientConf = new ClientConf();
clientConf.ClientId = "your mqtt clientId";
clientConf.ServerUri = "your mqtt host";
clientConf.Port = 8883;
clientConf.AccessKey = Environment.GetEnvironmentVariable("MQTT_ACCESS_KEY");
clientConf.AccessCode = Environment.GetEnvironmentVariable("MQTT_ACCESS_CODE");
clientConf.InstanceId = "your instanceId";
clientConf.Topic = "your mqtt topic";
clientConf.Qos = MqttQualityOfServiceLevel.AtMostOnce;
MqttConnection connection = new MqttConnection(clientConf, new MqttClient());
var connect = connection.Connect();
if (connect == 0)
Console.WriteLine("success to init mqtt connection.");
mre.WaitOne();
public void ConnectionLost(MqttClientDisconnectedEventArgs e)
if (e?.Exception != null)
Console.WriteLine("connect was lost. exception: " + e.Exception.Message);
return;
Console.WriteLine("connect was lost");
public void ConnectComplete(MqttClientConnectResultCode resultCode, String reason)
Console.WriteLine("connect success. resultCode: " + resultCode + " reason: " + reason);
public void OnMessageReceived(string message)
Console.WriteLine("receive msg: " + message);
public void ConnectFail(ManagedProcessFailedEventArgs e)
Console.WriteLine("connect mqtt broker failed. e: " + e.Exception.Message);
} Success Example
After the access is successful, the following information is displayed on the client.
