(Optional) Running Sysprep
Running Sysprep ensures that an ECS has a unique SID after it is joined to a Windows domain. Sysprep is used to generalize images. It removes server-specific information, like the security identifier (SID), from an image so that cloud servers created from this image can have unique SIDs in a domain. SID conflicts will cause domain login failures. If your Windows cloud servers do not need to be joined to a domain, Sysprep is not required.
After installing Cloudbase-Init on an ECS, you need to decide whether the ECS needs to be added to a domain or whether it must have a unique SID. If yes, run Sysprep as instructed in this section.
- Run Sysprep as the administrator.
- For a newly activated Windows ECS, you can run Sysprep only once at a time.
- If an ECS is created from an image file, only Sysprep provided by the image file can be used. In addition, Sysprep must always reside in the %WINDIR%\system32\sysprep directory.
- Windows must be in the activated state, and the remaining Windows rearm count must be greater than or equal to 1. Otherwise, the Sysprep encapsulation cannot be executed.
Run the following command in the Windows command line and check how many times you can run Sysprep in the displayed Windows Script Host dialog box:
slmgr.vbs /dlv
If the value of Remaining Windows rearm count is 0, you cannot run Sysprep.
Figure 1 Windows Script Host
- Enter the Cloudbase-Init installation directory.
C:\Program Files\Cloudbase Solutions\ is used as an example of the Cloudbase-Init installation directory. Switch to the root directory of drive C and run the following command to enter the installation directory:
cd C:\Program Files\Cloudbase Solutions\Cloudbase-Init\conf
- Run the following command to encapsulate Windows:
C:\Windows\System32\sysprep\sysprep.exe /generalize /oobe /unattend:Unattend.xml
- During Sysprep execution, user configuration files of the built-in administrator account (C:/Users/Administrator) will be deleted, including the Desktop, Documents, and AppData folders. The files of a non-built-in administrator account (for example, a manually created local administrator) and Public Profile (C:/Users/Public) will not be deleted.
- Ensure that /unattend:Unattend.xml is contained in the preceding command. Otherwise, the username, password, and other important configuration information of the ECS will be reset, and you must configure the OS manually when you use ECSs created from the Windows private image.
- After this command is executed, the ECS will be automatically stopped. After the ECS is stopped, use the ECS to create an image. ECSs created using the image have unique SIDs. If you restart a Windows ECS on which Sysprep has been executed, Sysprep takes effect only for the current ECS. Before creating an image using the ECS, you must run Sysprep again.
- For Windows Server 2012 and Windows Server 2012 R2, the administrator password of the ECS will be deleted after Sysprep is executed on the ECS. You need to log in to the ECS and reset the administrator password. In this case, the administrator password set on the management console will be invalid. Keep the password you set secure.
- If a domain account is required for logins, run Sysprep on the ECS before using it to create a private image. For details about the impact of running Sysprep, see Why Is Sysprep Required for Creating Private Images Using a Windows ECS?
- The Cloudbase-Init account of a Windows ECS is an internal account of the Cloudbase-Init agent. This account is used for obtaining metadata and completing relevant configuration when the Windows ECS starts. If you modify or delete this account, or uninstall the Cloudbase-Init agent, you will be unable to inject initial custom information into an ECS created from a Windows private image. Therefore, you are not advised to modify or delete the Cloudbase-Init account.
Figure 2 Running Sysprep
Follow-up Procedure
- Use this ECS to create a private image. For details see Creating a System Disk Image from an ECS.
- Use the image to create ECSs. Each ECS will have a unique SID.
Run the following command to query the ECS SID:
whoami /user
Figure 3 ECS SID before Sysprep is executed
Figure 4 ECS SID after Sysprep is executed
