Updated on 2025-11-27 GMT+08:00
Modifying SAML 2.0 Configuration
After the identity source is changed to an external identity provider, you can modify the SAML 2.0 configuration at any time, including modifying the provider information and modifying, activating, and deleting certificates.
Modifying SP Information
  1. Log in to the Huawei Cloud management console.
  2. Click in the upper left corner of the page and choose Management & Governance > IAM Identity Center.
  3. Choose Settings in the navigation pane.
  4. On the Identity Source tab, click Modify SAML 2.0 Configuration in the Authentication Method row.
  5. On the displayed page, you can download and view the certificates and generate, activate, or delete the certificates in the SP Certificate area.
    Figure 1 Modifying SP information
Modifying IdP Information
  5. On the displayed page, in the Identity Provider Details area, click Edit.
  6. Modify the identity provider login URL and identity provider issuer URL, and click Save.
  7. In the Identity Provider Certificates area, import or delete certificates by referring to Rotating Certificates.
    Figure 2 Modifying IdP information
