- What's New
- Getting Started
- User Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Instance Management
- Access Control Attribute Management
Permission Set Management
- Adding a System-defined Identity Policy
- Deleting a Permission Set
- Querying Permission Set Details
- Updating a Permission Set
- Deleting a System-defined Identity Policy
- Querying Details About a Custom Identity Policy
- Adding a Custom Identity Policy
- Deleting a Custom Identity Policy
- Listing Accounts Associated with a Permission Set
- Listing System-defined Identity Policies
- Listing Pre-provisioning Statuses of Permission Sets
- Listing Permission Sets
- Creating a Permission Set
- Listing Permission Sets Provisioned to an Account
- Pre-provisioning a Permission Set
- Querying Pre-attachment Status Details of a Permission Set
- Adding a System-defined Policy
- Deleting a System-defined Policy
- Listing System-defined Policies
Account Assignment Management
- Removing Account Assignments
- Querying Details about the Account Assignment Creation Status
- Listing Account Assignment Creation Statuses
- Listing Account Assignment Deletion Statuses
- Listing Users or Groups Associated with an Account and a Permission Set
- Creating Account Assignments
- Querying Details about the Account Assignment Deletion Status
- Tag Management
- User Management
- Group Management
- Group Membership Management
- SCIM User Management
- SCIM Group Management
- Service Provider (SP) Management
- Client Management
- Token Management
- Device Authorization Management
- Authorization Management
- Account Management
- Agency Management
- Credentials Management
- Appendixes
- Change History
On this page
Show all
Help Center/
IAM Identity Center/
User Guide/
Multi-Account Permissions Management/
Accounts/
Removing Access Permissions and Permission Sets
You can remove access permissions or permission sets from an associated account.
- Log in to the Huawei Cloud console.
- Click
in the upper left corner of the page and choose Management & Governance > IAM Identity Center.
- In the navigation pane, choose Multi-Account Permissions > Accounts.
By default, accounts are displayed in an organizational hierarchy structure. You can click
to switch to the list view.
Figure 1 Account view - In the account list, click the name of a target account.
- On the Users/Groups tab, select one or more users/groups and click Remove Access Permissions above the list. Alternatively, locate a target user/group and click Remove Access Permissions in the Operation column.
Figure 2 Removing access permissions
- On the Permission Sets tab, select one or more permission sets and click Remove above the list. Alternatively, locate a target permission set or click Remove in the Operation column.
Figure 3 Removing one or more permission sets
Parent topic: Accounts
