- What's New
- Getting Started
- User Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Instance Management
- Access Control Attribute Management
Permission Set Management
- Adding a System-defined Identity Policy
- Deleting a Permission Set
- Querying Permission Set Details
- Updating a Permission Set
- Deleting a System-defined Identity Policy
- Querying Details About a Custom Identity Policy
- Adding a Custom Identity Policy
- Deleting a Custom Identity Policy
- Listing Accounts Associated with a Permission Set
- Listing System-defined Identity Policies
- Listing Pre-provisioning Statuses of Permission Sets
- Listing Permission Sets
- Creating a Permission Set
- Listing Permission Sets Provisioned to an Account
- Pre-provisioning a Permission Set
- Querying Pre-attachment Status Details of a Permission Set
- Adding a System-defined Policy
- Deleting a System-defined Policy
- Listing System-defined Policies
Account Assignment Management
- Removing Account Assignments
- Querying Details about the Account Assignment Creation Status
- Listing Account Assignment Creation Statuses
- Listing Account Assignment Deletion Statuses
- Listing Users or Groups Associated with an Account and a Permission Set
- Creating Account Assignments
- Querying Details about the Account Assignment Deletion Status
- Tag Management
- User Management
- Group Management
- Group Membership Management
- SCIM User Management
- SCIM Group Management
- Service Provider (SP) Management
- Client Management
- Token Management
- Device Authorization Management
- Authorization Management
- Account Management
- Agency Management
- Credentials Management
- Appendixes
- Change History
Show all
A permission set is a template created and maintained by an administrator. It defines one or more IAM policies. Permission sets simplify the assignment of account access for users and groups in IAM Identity Center. With permission sets, you do not need to configure permissions for accounts individually.
Creating permission sets is mandatory. When logging in to the management console as an IAM Identity Center user to access resources of multiple accounts, you must associate the user with permission sets. Otherwise, the user cannot access any resources after login.
IAM provides system-defined policies to define common actions supported by cloud services. When creating a permission set, you can directly choose from these IAM system-defined policies. System-defined policies cannot be modified. You can create a custom identity policy or custom policy in IAM Identity Center to supplement system-defined policies. For details about system-defined policies for all cloud services, see System-defined Permissions.
A permission set can include a maximum of 18 system-defined policies, one custom identity policy, and one custom policy.
- Log in to the Huawei Cloud console.
- Click
in the upper left corner of the page and choose Management & Governance > IAM Identity Center.
- In the navigation pane, choose Multi-Account Permissions > Permission Sets.
- Click Create Permission Set in the upper right corner of the page.
Figure 1 Creating a permission set
- In the Set Permission Set Details step, configure details about the permission set and click Next.
Figure 2 Setting permission set details
Table 1 Permission set details Parameter
Name
Name of a permission set.
The value is user-defined and must be unique.
Session Duration
The length of time a user can be logged in to the console.
When the login time exceeds the configured session duration, the user is automatically logged out. To continue the access, the user needs to log in again.
Initial Access Page
Initial page that a user accesses after logging in to the console using the user portal URL.
For example, if you enter the IAM console URL, users will access the IAM console after login.
Description of a permission set.
- In the Set Policy step, configure system-defined policies, custom identity policies, and custom policies for the permission set and click Next.
If you enable Identity Policy, only system-defined policies and custom identity policies are displayed.
- System-defined policies: You can select system-defined policies preconfigured in IAM Identity Center, including policies and identity policies.
- Custom identity policies: You can create custom identity policies in visual editor or JSON view to supplement system-defined identity policies.
- Custom policies: You can create custom policies only in JSON view to supplement system-defined policies.
Figure 3 Setting policies - In the Confirm step, confirm the configuration and click OK in the lower right corner.
Figure 4 Confirming configurations
By default, newly created permission sets are not attached to any accounts. Their status will change to Attached after you attach them to accounts.
