Updated on 2026-09-07 GMT+08:00
Viewing and Handling Local Image Scan Results
HSS can present image security statistics in the risk view and image view, helping you comprehensively learn, locate, and fix image risks.
  • Risk view: View all the scan results of a risk. Local image risks include system vulnerabilities, application vulnerabilities, and common weak passwords.
  • Image view: View the scan results of a single image. Local image scan results include system vulnerabilities, application vulnerabilities, software information, and common weak passwords.
You can view and handle local image scan results in Risk View or Image View.
Viewing and Handling Local Scan Results in the Risk View
  1. Log in to the HSS console.
  2. Click in the upper left corner and select a region or project.
  3. In the navigation pane on the left, choose Risk Management > Container Images.
  4. In Risk View, click System Vulnerabilities and Application Vulnerabilities. Filter Local images, and view and handle the scan results. For details, see Table 1.
    Figure 1 Local image risk view
    Table 1 Local image scan result parameters
    Risk Type
    OS vulnerability scan results. You can perform the following operations:
    • View vulnerability details
      Click a vulnerability notice name. On the vulnerability details page, view the vulnerability notice, CVE (for system vulnerabilities only), suggestions, affected images, and handling history.
    • Handle vulnerabilities
      • Ignore
        If a vulnerability does not need to be handled for now, you can ignore it. It will still be displayed in future scan results.
      • Add to whitelist
        If a vulnerability does not affect your services, you can add it to the whitelist.
      • Fix
        Fix the vulnerability by referring to the suggestions in the vulnerability details.
    Application software vulnerability scan results.
    Application vulnerability detection can automatically cross-reference the AI vulnerability database to detect vulnerabilities in images.
      Click a vulnerability notice name. On the vulnerability details page, view the vulnerability notice, suggestions, affected images, and handling history.
      • Ignore
      • Add to whitelist
      • Fix
Viewing and Handling Local Scan Results in the Image View
  4. Click the Image View tab.
    Figure 2 Image view
  5. Click the Local Images tab.
  6. In the Operation column of an image, click View Results to go to the image details page.
  7. View and handle risk scan results. For details, see Table 2.
    Figure 3 Local image scan details
    Table 2 Local image scan result parameters
    Risk Type
      Click a vulnerability name to go to its details page. View the vulnerability description, urgency, and affected images.
      • Ignore
      • Add to whitelist
      • Fix
        To fix a system vulnerability, upgrade the software affected by it. Click To upgrade the affected software to go to the security notice details page. View the affected components, CVE, and more information.
    Application vulnerabilities
      • Ignore
      • Add to whitelist
      • Fix
        To fix an application vulnerability, hover the cursor over the solution description of a vulnerability to view the solution. To install a patch, access the patch installation guide link provided in the solution, and install the patch accordingly.
    Software Information
    Statistical results of image software, including the software names, types, versions, and number of software vulnerabilities.
    Click next to a software name to view its vulnerability name, risk level, and solution.
    AI Components
    Generative AI components in the container environment, including AI applications and tools.
