Installing the Agent in a Third-Party Public Network Cluster
Updated on 2025-01-22 GMT+08:00
Install the agent on a third-party cluster that can access the public network. After the configuration is complete, HSS automatically installs the agent on existing cluster nodes, installs the agent on new nodes when the cluster is scaled out, and uninstalls the agent from removed nodes when the cluster is scaled in.
Constraints and Limitations
  • Supported cluster orchestration platforms: Kubernetes 1.19 or later
  • Supported node OS: Linux
  • Node specifications: at least 2 vCPUs, 4 GiB memory, 40 GiB system disk, and 100 GiB data disk
  • The agent is incompatible with clusters of Galera 3.34, MySQL 5.6.51, or earlier versions.
Step 1: Create a VPC
  1. Log in to the console and go to the page for Creating a VPC.
  2. On the Create VPC page, set parameters for the VPC and subnets as prompted.
    You are advised to set some parameters by referring to Table 1 and retain the default values for other parameters. For details about how to create a VPC, see Creating a VPC.
    Table 1 Parameters for creating a VPC
    Example Value
    Region
    Select a region near you to ensure the lowest latency possible.
    CN-Hong Kong
    Name
    VPC name. The name:
    • Must contain 1 to 64 characters.
    • Can contain letters, numbers, underscores (_), hyphens (-), and periods (.).
    HSS-outside-anp-VPC
    Enterprise Project
    Enterprise project to which the VPC belongs.
    An enterprise project facilitates project-level management and grouping of cloud resources and users. The name of the default project is default.
    For details about creating and managing enterprise projects, see the Enterprise Management User Guide.
    default
    Subnet Name
    Subnet name. The name:
    HSS-outside-subnet
  3. Click Create Now. You can view the VPC after it is created.
Step 2: Create a Security Group
  1. In the navigation pane on the left, choose Access Control > Security Groups.
  2. Click Create Security Group in the upper right corner.
  3. Configure security group parameters as prompted.
    You are advised to configure some parameters by referring to Table 2 and configure other parameters based on site requirements. For details about how to create a security group, see Creating a Security Group.
    Table 2 Parameters for creating a security group
    Example Value
    Region
    CN-Hong Kong
    Name
    Specify the name of the security group. The name:
    HSS-outside-anp-secGroups
    Enterprise Project
    When creating a security group, you can add the security group to an enterprise project that has been enabled.
    An enterprise project facilitates project-level management and grouping of cloud resources and users. The default project is default.
    default
    Preset Rule
    Inbound and outbound rules are preset in security group rules. You can select a rule as needed to quickly create a security group.
    All ports open
  4. Click Create Now. You can view the security group after it is created.
Step 3: Create an ECS
  1. Click in the upper left corner and Compute > Elastic Cloud Server.
  2. In the upper right corner, click Buy ECS.
  3. Configure ECS parameters as prompted.
    You are advised to configure some parameters by referring to Table 3 and configure other parameters based on site requirements.
    Table 3 Parameters for purchasing an ECS
    Example Value
    Billing Mode
    ECS billing mode.
    • Yearly/Monthly: Prepaid mode. Yearly/monthly ECSs are billed by the purchased duration specified in the order.
    • Pay-per-use: Postpaid billing mode. You pay as you go and just pay for what you use. Pay-per-use ECSs are billed by the second and settled by the hour.
    • Spot price: Spot pricing is a postpaid billing mode. You pay as you go and just pay for what you use. In Spot pricing billing mode, your purchased ECS is billed at a lower price than that of a pay-per-use ECS with the same specifications. In Spot pricing billing mode, you can select Spot or Spot block for the Spot Type. Spot ECSs and Spot block ECSs are billed by the second and settled by the hour.
    Pay-per-use
    Region
    CN-Hong Kong
    CPU Architecture
    Select a CPU architecture. The value can be x86.
    x86
    Instance
    • Select vCPUs and memory, or enter a keyword to search for ECS specifications.
      You can search for ECS flavors when you select By Type.
    • Select ECS specifications by instance family and generation from the list.
    General computing, 2 vCPUs, 4 GiB
    An image is an ECS template that contains an OS. It may also contain proprietary software and application software. You can use images to create ECSs.
    Public image, EulerOS 2 5 64bit (40 GiB)
    System Disk
    A system disk stores the OS of an ECS, and is automatically created and initialized upon ECS creation.
    Ultra-high I/O
    Network
    VPC allows you to create logically isolated, configurable, and manageable virtual networks for VPCs. You can configure security groups, Virtual Private Network (VPNs), CIDR blocks, and bandwidths in your VPC. ECSs in different VPCs cannot communicate with each other by default.
    HSS-outside-anp-VPC
    (VPC created in Step 1: Create a VPC)
    Security Group
    Select an available security group from the drop-down list. You can select multiple security groups for an ECS (no more than five security groups are recommended). The access rules of all the selected security groups apply to the ECS.
    (Security group created in Step 2: Create a Security Group)
    EIP
    An EIP is a static public IP address bound to a cloud server in a VPC. Using the EIP, the cloud server provides services externally.
    Buy now, static BGP
    ECS Name
    This parameter will be set to the initial server name (hostname) in the ECS OS.
    The name can contain only letters, numbers, underscores (_), hyphens (-), and periods (.).
    HSS-outside-anp-ECS
    Enterprise Project
    When purchasing an ECS, you can add it to an enabled enterprise project.
    default
    Login Mode
    Method for logging in to an ECS.
    Password
  4. Click Create. In the displayed dialog box, click Agree and Create. After the payment is complete, the ECS will be automatically created and started by default.
Step 4: Set Up Nginx
  1. Log in to the server created in Step 3: Create an ECS.
  2. Go to the temp directory.
    cd /temp
  3. Run the following command to create the install_nginx.sh file:
    vi install_nginx.sh
  4. Press i to enter the editing mode and copy the following content to the install_nginx.sh file:
    #!/bin/bash
    yum -y install pcre-devel zlib-devel popt-devel openssl-devel openssl
    wget http://www.nginx.org/download/nginx-1.21.0.tar.gz
    tar zxf nginx-1.21.0.tar.gz -C /usr/src/
    cd /usr/src/nginx-1.21.0/
    useradd -M -s /sbin/nologin nginx
    ./configure \
    --prefix=/usr/local/nginx \
    --user=nginx \
    --group=nginx \
    --with-file-aio \
    --with-http_stub_status_module \
    --with-http_gzip_static_module \
    --with-http_flv_module \
    --with-http_ssl_module \
    --with-stream \
    --with-pcre && make && make install
    ln -s /usr/local/nginx/sbin/nginx /usr/local/sbin/
    nginx
  1. Enter ECS, run the following command, and press Enter to exit.
    :wq!
  2. Run the following command to install Nginx:
    bash /tmp/install_nginx.sh
  3. Run the following command to modify the Nginx configuration file:
    cat <<END >> /usr/local/nginx/conf/nginx.conf
    stream {
      upstream backend_hss_anp {
        server {{ANP_proxy_address}}:8091 weight=5 max_fails=3 fail_timeout=30s;
      server {
        listen 8091 so_keepalive=on;
        proxy_connect_timeout 10s;
        proxy_timeout 300s;
        proxy_pass backend_hss_anp ;
    END
    Replace {{ANP_proxy_address}} with the actual address and then run the command. For details, see Table 4.
    Table 4 ANP proxy address
    Region
    ANP proxy address
    Guiyang1, Bangkok, Shanghai2, Guangzhou, Beijing4, Beijing2, and Shanghai1
    hss-proxy.RegionCode.myhuaweicloud.com
    Other
    hss-anp.RegionCode.myhuaweicloud.com
    For details about region codes, see Regions and Endpoints.
  4. Run the following command to make the Nginx configuration take effect:
    nginx -s reload
  5. Run the following command to check whether port 8091 is listened on properly:
    netstat -anp | grep 8091
    If information similar to Figure 1 is displayed, the listening is normal.
    Figure 1 Listening on port 8091 is normal.
Step 5: Buy and Configure an ELB
  1. Log in to the console and go to the page for Buying ELB page.
  2. Set ELB parameters as prompted.
    You are advised to configure some parameters by referring to Table 5 and configure other parameters based on site requirements. For details about how to buy a load balancer, see Creating a Dedicated Load Balancer.
    Table 5 Parameters for buying an ELB
    Example Value
    Type
    Type of the shared load balancer. The type cannot be changed after the load balancer is created.
    Dedicated load balancers work well for heavy-traffic and high-concurrency workloads, such as large websites, cloud native applications, IoV, and multi-AZ disaster recovery applications.
    Dedicated
    Billing Mode
    Billing mode of a dedicated load balancer.
    • Yearly/Monthly: prepaid billing mode. You pay in advance for a subscription term, and in exchange, you get a discounted rate.
    • Pay-per-use: postpaid billing mode. You pay as you go and just pay for what you use. The load balancer usage is calculated by the second but billed every hour.
    Pay-per-use
    Region
    CN-Hong Kong
    Name
    Load balancer name. The name can contain:
    • 1 to 64 characters.
    • Letters, numbers, underscores (_), hyphens (-), and periods (.).
    HSS-outside-anp-ELB
    Enterprise Project
    When creating a load balancer, you can add it to an enabled enterprise project.
    default
    Specification Type
    Select Elastic or Fixed if pay-per-use is chosen as the billing mode.
    Specifications:
    • Elastic specifications work well for fluctuating traffic, and you will be charged for how many LCUs you use.
    • Fixed specifications are suitable for stable traffic, and you will be charged for the specifications you select.
    • Fixed
    • Network load balancing
    • Small
    Network Configuration
    • Network Type: You can select one or more network types.
      • Private IPv4 network: The load balancer routes IPv4 requests from the clients to backend servers in a VPC. If you want the load balancer to route IPv4 requests from the Internet, bind an EIP to the load balancer.
      • IPv6 network: An IPv6 address will be assigned to the load balancer to route requests from IPv6 clients.
    • VPC: VPC where the dedicated load balancer works. You cannot change the VPC after the load balancer is created. Plan the VPC as required.
      Select an existing VPC, or click View VPCs to create a desired one.
    • Frontend Subnet: Subnet where the dedicated load balancer is located. The system allocates an IP address from this subnet to the load balancer for external services.
      After a load balancer is created, you can unbind the IP address from it and assign an IP address from a new frontend subnet to the load balancer.
    • Backend Subnet: The load balancer uses IP addresses in the backend subnet to establish connections with backend servers.
    Elastic IPs
    EIP that will be bound to the load balancer for receiving and forwarding IPv4 requests over the Internet.
    • Auto assign
    • Dynamic BGP
    • Bandwidth
  3. After setting the parameters, click Next.
  4. On the ELB page, view the created ELB and record the public IPv4 address.
  5. In the row of a load balancer, click Add now in the Listener (Frontend Protocol/Port) column.
  6. Set the listener parameters as prompted.
    You are advised to configure some parameters by referring to Table 6 and configure other parameters based on site requirements. For details, see Adding a TCP Listener.
    Table 6 Parameters for adding a listener
    Example Value
    Configure Listener
    Name
    Listener name.
    HSS-outside-anp-Listener
    Protocol
    Protocol used by the client and listener to distribute traffic.
    TCP
    Frontend Port
    Port used by the client and listener to distribute traffic.
    8091
    Access Control
    Supports access control based on the whitelist and blacklist.
    All IP addresses
    Configure Routing Policy
    Backend Server Group
    A group of backend servers with the same features.
    • New
    • Use existing
    New
    Backend Server Group Name
    Name of the backend server group.
    HSS-outside-anp-server-group
    Backend Protocol
    Specifies the protocol that backend servers in the backend server group use to receive requests from the listeners. The protocol varies depending on the forwarding mode.
    TCP
    Load Balancing Algorithm
    Algorithm used by the load balancer.
    • Weighted round robin: Requests are routed to different servers based on their weights. Backend servers with higher weights receive proportionately more requests, whereas equal-weighted servers receive the same number of requests.
    • Weighted least connections: In addition to the number of connections, each server is assigned a weight based on its capacity. Requests are routed to the server with the lowest connections-to-weight ratio.
    • Source IP hash: Allows requests from different clients to be routed based on source IP addresses and ensures that requests from the same client are forwarded to the same server.
    Add Backend Server
    Backend Servers
    When you use ELB to route requests, ensure that at least one backend server is running properly and can receive requests routed by the load balancer.
    Click Add Backend Server.
    HSS-outside-anp-ECS
    Set the service port to 8091.
    (Server created in Step 3: Create an ECS)
  7. On the Confirm page, check parameter settings.
  8. Click Submit complete the configuration.
Step 6: Modify a Security Group
  1. Click in the upper left corner of the management console and choose Network > Virtual Private Cloud.
  2. In the navigation tree on the left, choose Security Groups.
  3. Locate the security group created in Step 2: Create a Security Group and click Manage Rules.
  4. Delete the IPv6 full passing rule, as shown in Figure 2.
    Figure 2 Deleting the IPv6 full passing rule
  5. Modify the IPv4 full bypass rule, as shown in Figure 3.
    1. Change the value of Protocol & Port from Protocols > All to Protocols / TCP (Custom ports) and set the port number to 8091.
    2. Click OK.
    Figure 3 Modifying the IPv4 full passing rule
Step 7: Prepare the kubeconfig File
The kubeconfig file specifies the cluster permissions assigned to HSS. The kubeconfig file configured using method 1 contains the cluster administrator permissions, whereas the file generated using method 2 contains only the permissions required by HSS. If you want to minimize HSS permissions, prepare the file using method 2.
  • Method 1: configuring the default kubeconfig file
    The default kubeconfig file is in the $HOME/.kube/config directory. Perform the following operations to create a dedicated namespace for HSS:]
    1. Log in to a cluster node.
    2. Create the hss.yaml file and copy the following content to the file:
      {"metadata":{"name":"hss"},"apiVersion":"v1","kind":"Namespace"}
    3. Run the following command to create a namespace:
      kubectl apply -f hss.yaml
  • Method 2: generating a kubeconfig file dedicated to HSS
    1. Create a dedicated namespace and an account for HSS.
      2. Create the hss-account.yaml file and copy the following content to the file:
        {"metadata":{"name":"hss"},"apiVersion":"v1","kind":"Namespace"}{"metadata":{"name":"hss-user","namespace":"hss"},"apiVersion":"v1","kind":"ServiceAccount"}{"metadata":{"name":"hss-user-token","namespace":"hss","annotations":{"kubernetes.io/service-account.name":"hss-user"}},"apiVersion":"v1","kind":"Secret","type":"kubernetes.io/service-account-token"}
      3. Run the following command to create a namespace and an account:
        kubectl apply -f hss-account.yaml
    2. Generate the kubeconfig file.
      1. Create the gen_kubeconfig.sh file and copy the following content to the file:
        #!/bin/bash
        KUBE_APISERVER=`kubectl config view  --output=jsonpath='{.clusters[].cluster.server}' | head -n1 `
        CLUSTER_NAME=`kubectl config view -o jsonpath='{.clusters[0].name}'`
        kubectl get secret hss-user-token -n hss -o yaml |grep ca.crt: | awk '{print $2}' |base64 -d >hss_ca_crt
        kubectl config set-cluster ${CLUSTER_NAME} --server=${KUBE_APISERVER}  --certificate-authority=hss_ca_crt  --embed-certs=true --kubeconfig=hss_kubeconfig.yaml
        kubectl config set-credentials hss-user --token=$(kubectl describe secret hss-user-token -n hss | awk '/token:/{print $2}') --kubeconfig=hss_kubeconfig.yaml
        kubectl config set-context hss-user@kubernetes --cluster=${CLUSTER_NAME} --user=hss-user --kubeconfig=hss_kubeconfig.yaml
        kubectl config use-context hss-user@kubernetes --kubeconfig=hss_kubeconfig.yaml
      2. Run the following command to generate the kubeconfig file named hss_kubeconfig.yaml:
        bash gen_kubeconfig.sh
Step 8: Install the Agent for a Third-Party Public Network Cluster
The image repositories used by a cluster are classified into public and private image repositories.
  • Public network image repository: An image repository that can be accessed as long as it can connect to the Internet. It is usually provided by a third party and paid by enterprises.
  • Private image repository: an image repository deployed and maintained by an enterprise. Only authorized users can access the image repository.
Install the agent for the cluster based on the image repository type.
