Updated on 2025-09-29 GMT+08:00
Exporting the Server List
This section describes how to export the server protection list to your local PC.
Exporting the Server List to the Local PC
  1. Log in to the HSS console.
  2. Click in the upper left corner and select a region or project.
  3. In the navigation pane on the left, choose Asset Management > Servers & Quota. The Servers tab is displayed.
  4. (Optional) If you have enabled the enterprise project function, select an enterprise project from the Enterprise Project drop-down list in the upper part of the page to view its data.
  5. In the upper right corner of the server list, click Export to export the server list details.
    You can also select specified servers in the server list and click Export. The details of up to 1000 servers can be exported at a time.
