Updated on 2025-08-26 GMT+08:00
Managing Application Protection Policies
Application protection policies can be added, edited, and deleted in the following scenarios:
  • Addition: HSS provides a default policy, which contains all the detection rules for application protection. For details, see Detection Capabilities. If you need to customize the policy for a server, you can add a protection policy and customize the detection rules and configurations in the policy.
  • Editing: You can edit a custom protection policy.
  • Deletion: You can delete a custom protection policy that is not associated with any server.
Adding a Protection Policy
  2. In the upper left corner of the page, select a region, click , and choose Security & Compliance > Host Security Service.
  3. Choose Server Protection > Application Protection and click Protection Policies. For more information, see Table 1.
    Table 1 Protection policy parameters
    Policy Name
    Protection policy name
    Detection Rule
    Detection rules supported by a policy.
    Associated Servers
    Number of servers bound to a policy.
  4. (Optional) If you have enabled the enterprise project function, select an enterprise project from the Enterprise Project drop-down list in the upper part of the page to view its data.
  5. Click Add Policy. In the dialog box that is displayed, configure the parameters by referring to Table 2.
    Figure 1 Adding a protection policy
    Table 2 Application protection policy parameters
    OS
    OS of the servers that the protection policy applies to.
    Policy Name
    User-defined policy name
    Detection Rule ID
    Unique ID of a detection rule. To enable a detection rule, select the check box next to the ID.
    Action
    Protection action of a detection rule.
    • Detect: Detects objects based on the target rule and reports alarms for detected risk events.
    • Detect and block: Detects objects based on the target rule, reports alarms for detected risk events, and directly blocks or intercepts detected risk items.
      WARNING:
      Blocking or interception may interrupt services. Exercise caution when enabling this function.
    Description about the detected object and behavior of the target protection policy.
  6. Click Configure in the Operation column of a detection rule to modify the rule content. Table 3 describes the supported detection rules.
    Table 3 Detection rules that can be configured only
    Rule
    Example
    XXE
    User-defined XXE blacklist protocol
    .xml;.dtd;
    XSS
    User-defined XSS shielding rules
    xml;doctype;xmlns;import;entity
    WebShellUpload
    User-defined suffix of files in the blacklist.
    .jspx;.jsp;.jar;.phtml;.asp;.php;.ascx;.ashx;.cer
    FileDirAccess
    User-defined path of files in the blacklist.
    /etc/passwd;/etc/shadow;/etc/gshadow;
  7. Confirm the configured policy and selected detection rules, and click OK. You can check whether the rule is added on the Protection Policy tab page.
Editing a Protection Policy
  1. Log in to the management console and go to the HSS page.
  2. Choose Server Protection > Application Protection and click Protection Policies. For more information, see Table 4.
    Table 4 Protection policy parameters
    Policy Name
    Detection Rule
    Associated Servers
  3. (Optional) If you have enabled the enterprise project function, select an enterprise project from the Enterprise Project drop-down list in the upper part of the page to view its data.
  4. Click Edit in the Operation column of a policy to configure the policy name, supported detection rules, and rule content.
    Table 5 Application protection policy parameters
    Policy Name
    Detection Rule ID
    Action
      NOTICE:
  5. Confirm the configured rule and selected detection items and click OK. You can check whether the target policy is modified on the Protection Policy tab page.
Deleting a Policy
  2. Choose Server Protection > Application Protection and click Protection Policies. For more information, see Table 6.
    Table 6 Protection policy parameters
    Policy Name
    Detection Rule
    Associated Servers
  4. Click Delete in the Operation column of the target policy. In the dialog box that is displayed, confirm the policy information and click OK.
    Only the policies that are not associated with any server can be deleted.
