Agent Overview
What Is an Agent?
The HSS agent is a piece of security software installed on cloud servers to exchange data between the servers and HSS, implementing security detection and protection for servers and containers. If no agent is installed, the HSS is unavailable.
Scans all servers at 00:00 every day; monitors the security and monitors status of servers; and reports the collected server and monitors information (including non-compliant configurations, insecure configurations, intrusion traces, software list, port list, and process list) to the cloud protection center. In addition, the agent blocks attacks targeted at servers and containers based on the security policies you configured.
Supported OSs
Currently, some mainstream OSs are supported. For details, see OS Restrictions. To obtain better HSS service experience, you are advised to install or upgrade to an OS version supported by the agent.
Processes When the Agent Is Running
- Linux
The account of the agent is root. Table 1 lists the running processes on a Linux server.
Table 1 Agent running process on a Linux server Agent Process Name
Function
Path
hostguard
Detects security issues, protects the system, and monitors the agent.
/usr/local/hostguard/bin/hostguard
hostwatch
Monitors the agent process.
/usr/local/hostguard/bin/hostwatch
upgrade
Upgrades the agent.
/usr/local/hostguard/bin/upgrade
- Windows
The account of the agent is system. Table 2 lists the running processes on a Windows server.
Table 2 Agent running process on a Windows server Agent Process Name
Function
Path
hostguard.exe
C:\Program Files\HostGuard\HostGuard.exe
hostwatch.exe
C:\Program Files\HostGuard\HostWatch.exe
upgrade.exe
Upgrades the agent.
C:\Program Files\HostGuard\upgrade.exe
