File Integrity Monitoring Overview
What Is File Integrity Monitoring?
File integrity monitoring (FIM) monitors key files and directories on servers in real time; records file or directory creation, modification, deletion, and moving; and records and reports alarms on file or directory attribute modification, helping you detect suspicious changes in a timely manner.
File Integrity Monitoring Principles
HSS checks for suspicious changes by comparing the previous and current statuses of a file.
File Integrity Monitoring Scope
The monitored items and scope vary depending on the OS.
Linux file integrity monitoring checks:
- Important file integrity
Monitor and record important system files (such as ls, ps, login, and top) in real time, and generate alarms if these files are modified. For more information, see Table 1.
- Important file directory change
Monitor system files or directories; record file or directory creation, modification, deletion, and moving; and record and report file or directory attribute modification, helping you detect suspicious changes in a timely manner. For details about the default monitoring paths in conservative mode, see Table 2. For details about the default monitoring paths in sensitive mode, see Table 3.
To add or remove monitored files or directories, modify the settings of File Integrity and Important File Directory Change in the File Protection policy. For details, see Configuring Policies.
Type |
File Path |
bin |
usr |
File or Directory Path |
Alias |
Monitored Objects/Operations |
Subdirectory |
Creation |
Property Modification |
Deletion |
Moving |
Modification |
/etc/rc.d/rc.local |
rx-local |
/etc/crontab |
crontab |
/var/spool/cron/root |
spool-cron |
/var/spool/cron/crontabs/root |
spool-cron |
/etc/cron.allow |
cron-allow |
/etc/passwd |
passwd |
/etc/profile.d/zzz_euleros_history.sh |
zzz_euleros_history_sh |
/etc/profile |
profile |
/root/.bashrc |
bashrc |
/root/.bash_profile |
bash_profile |
/root/.cshrc |
cshrc |
/etc/ld.so.preload |
so_preload |
/etc/profile.d/sec_euleros_history.sh |
sec_euleros_history_sh |
/etc/shells |
shells |
/usr/sbin/adduser |
usr_sbin_adduser |
/usr/sbin/chkconfig |
usr_sbin_chkconfig |
/usr/sbin/chroot |
usr_sbin_chroot |
/usr/sbin/depmod |
usr_sbin_depmod |
/usr/sbin/fsck |
usr_sbin_fsck |
/usr/sbin/fuser |
usr_sbin_fuser |
/usr/sbin/groupadd |
usr_sbin_groupadd |
/usr/sbin/groupdel |
usr_sbin_groupdel |
/usr/sbin/groupmod |
usr_sbin_groupmod |
/usr/sbin/grpck |
usr_sbin_grpck |
/usr/sbin/ifconfig |
usr_sbin_ifconfig |
/usr/sbin/ifdown |
usr_sbin_ifdown |
/usr/sbin/ifup |
usr_sbin_ifup |
/usr/sbin/init |
usr_sbin_init |
/usr/sbin/insmod |
usr_sbin_insmod |
/usr/sbin/ip |
usr_sbin_ip |
/usr/sbin/lsmod |
usr_sbin_lsmod |
/usr/sbin/lsof |
usr_sbin_lsof |
/usr/sbin/modinfo |
usr_sbin_modinfo |
/usr/sbin/modprobe |
usr_sbin_modprobe |
/usr/sbin/nologin |
usr_sbin_nologin |
/usr/sbin/pwck |
usr_sbin_pwck |
/usr/sbin/rmmod |
usr_sbin_rmmod |
/usr/sbin/route |
usr_sbin_route |
/usr/sbin/rsyslogd |
usr_sbin_rsyslogd |
/usr/sbin/runlevel |
usr_sbin_runlevel |
/usr/sbin/sestatus |
usr_sbin_sestatus |
/usr/sbin/sshd |
usr_sbin_sshd |
/usr/sbin/sulogin |
usr_sbin_sulogin |
/usr/sbin/sysctl |
usr_sbin_sysctl |
/usr/sbin/useradd |
usr_sbin_useradd |
/usr/sbin/userdel |
usr_sbin_userdel |
/usr/sbin/usermod |
usr_sbin_usermod |
/usr/sbin/vipw |
usr_sbin_vipw |
/usr/bin/awk |
usr_bin_awk |
/usr/bin/basename |
usr_bin_basename |
/usr/bin/bash |
usr_bin_bash |
/usr/bin/cat |
usr_bin_cat |
/usr/bin/chattr |
usr_bin_chattr |
/usr/bin/chmod |
usr_bin_chmod |
/usr/bin/chown |
usr_bin_chown |
/usr/bin/cp |
usr_bin_cp |
/usr/bin/curl |
usr_bin_curl |
/usr/bin/cut |
usr_bin_cut |
/usr/bin/date |
usr_bin_date |
/usr/bin/df |
usr_bin_df |
/usr/bin/diff |
usr_bin_diff |
/usr/bin/dirname |
usr_bin_dirname |
/usr/bin/dmesg |
usr_bin_dmesg |
/usr/bin/du |
usr_bin_du |
/usr/bin/echo |
usr_bin_echo |
/usr/bin/ed |
usr_bin_ed |
/usr/bin/egrep |
usr_bin_egrep |
/usr/bin/env |
usr_bin_env |
/usr/bin/fgrep |
usr_bin_fgrep |
/usr/bin/file |
usr_bin_file |
/usr/bin/find |
usr_bin_find |
/usr/bin/grep |
usr_bin_grep |
/usr/bin/groups |
usr_bin_groups |
/usr/bin/head |
usr_bin_head |
/usr/bin/id |
usr_bin_id |
/usr/bin/ipcs |
usr_bin_ipcs |
/usr/bin/kill |
usr_bin_kill |
/usr/bin/killall |
usr_bin_killall |
/usr/bin/last |
usr_bin_last |
/usr/bin/lastlog |
usr_bin_lastlog |
/usr/bin/ldd |
usr_bin_ldd |
/usr/bin/less |
usr_bin_less |
/usr/bin/logger |
usr_bin_logger |
/usr/bin/login |
usr_bin_login |
/usr/bin/ls |
usr_bin_ls |
/usr/bin/lsattr |
usr_bin_lsattr |
/usr/bin/mail |
usr_bin_mail |
/usr/bin/md5sum |
usr_bin_md5sum |
/usr/bin/mktemp |
usr_bin_mktemp |
/usr/bin/more |
usr_bin_more |
/usr/bin/mount |
usr_bin_mount |
/usr/bin/mv |
usr_bin_mv |
/usr/bin/netstat |
usr_bin_netstat |
/usr/bin/newgrp |
usr_bin_newgrp |
/usr/bin/passwd |
usr_bin_passwd |
/usr/bin/perl |
usr_bin_perl |
/usr/bin/pgrep |
usr_bin_pgrep |
/usr/bin/ping |
usr_bin_ping |
/usr/bin/pkill |
usr_bin_pkill |
/usr/bin/ps |
usr_bin_ps |
/usr/bin/pstree |
usr_bin_pstree |
/usr/bin/pwd |
usr_bin_pwd |
/usr/bin/readlink |
usr_bin_readlink |
/usr/bin/rpm |
usr_bin_rpm |
/usr/bin/runcon |
usr_bin_runcon |
/usr/bin/sed |
usr_bin_sed |
/usr/bin/sh |
usr_bin_sh |
/usr/bin/sha1sum |
usr_bin_sha1sum |
/usr/bin/sha224sum |
usr_bin_sha224sum |
/usr/bin/sha256sum |
usr_bin_sha256sum |
/usr/bin/sha384sum |
usr_bin_sha384sum |
/usr/bin/sha512sum |
usr_bin_sha512sum |
/usr/bin/size |
usr_bin_size |
/usr/bin/sort |
usr_bin_sort |
/usr/bin/ssh |
usr_bin_ssh |
/usr/bin/stat |
usr_bin_stat |
/usr/bin/strace |
usr_bin_strace |
/usr/bin/strings |
usr_bin_strings |
/usr/bin/su |
usr_bin_su |
/usr/bin/sudo |
usr_bin_sudo |
/usr/bin/tail |
usr_bin_tail |
/usr/bin/test |
usr_bin_test |
/usr/bin/top |
usr_bin_top |
/usr/bin/touch |
usr_bin_touch |
/usr/bin/tr |
usr_bin_tr |
/usr/bin/uname |
usr_bin_uname |
/usr/bin/uniq |
usr_bin_uniq |
/usr/bin/users |
usr_bin_users |
/usr/bin/vmstat |
usr_bin_vmstat |
/usr/bin/w |
usr_bin_w |
/usr/bin/watch |
usr_bin_watch |
/usr/bin/wc |
usr_bin_wc |
/usr/bin/wget |
usr_bin_wget |
/usr/bin/whatis |
usr_bin_whatis |
/usr/bin/whereis |
usr_bin_whereis |
/usr/bin/which |
usr_bin_which |
/usr/bin/who |
usr_bin_who |
/usr/bin/whoami |
usr_bin_whoami |
/usr/bin/numfmt |
usr_bin_numfmt |
/usr/bin/kmod |
usr_bin_kmod |
/usr/bin/systemctl |
usr_bin_systemctl |
/usr/bin/gawk |
usr_bin_gawk |
/usr/bin/mailx |
usr_bin_mailx |
/usr/lib/systemd/systemd |
usr_lib_systemd_systemd |
/usr/bin/nmcli |
usr_bin_nmcli |
/usr/bin/scp |
usr_bin_scp |
/usr/bin/tar |
usr_bin_tar |
/usr/bin/chfn |
usr_bin_chfn |
/usr/bin/chsh |
usr_bin_chsh |
/usr/bin/crontab |
usr_bin_crontab |
/usr/sbin/pidof |
usr_sbin_pidof |
/usr/bin/slogin |
usr_bin_slogin |
/usr/sbin/sendmail |
usr_sbin_sendmail |
/usr/sbin/tcpdump |
usr_sbin_tcpdump |
/sbin/adduser |
sbin_adduser |
/sbin/chkconfig |
sbin_chkconfig |
/sbin/chroot |
sbin_chroot |
/sbin/depmod |
sbin_depmod |
/sbin/fsck |
sbin_fsck |
/sbin/fuser |
sbin_fuser |
/sbin/groupadd |
sbin_groupadd |
/sbin/groupdel |
sbin_groupdel |
/sbin/groupmod |
sbin_groupmod |
/sbin/grpck |
sbin_grpck |
/sbin/ifconfig |
sbin_ifconfig |
/sbin/ifdown |
sbin_ifdown |
/sbin/ifup |
sbin_ifup |
/sbin/init |
sbin_init |
/sbin/insmod |
sbin_insmod |
/sbin/ip |
sbin_ip |
/sbin/lsmod |
sbin_lsmod |
/sbin/lsof |
sbin_lsof |
/sbin/modinfo |
sbin_modinfo |
/sbin/modprobe |
sbin_modprobe |
/sbin/nologin |
sbin_nologin |
/sbin/pwck |
sbin_pwck |
/sbin/rmmod |
sbin_rmmod |
/sbin/route |
sbin_route |
/sbin/rsyslogd |
sbin_rsyslogd |
/sbin/runlevel |
sbin_runlevel |
/sbin/sestatus |
sbin_sestatus |
/sbin/sshd |
sbin_sshd |
/sbin/sulogin |
sbin_sulogin |
/sbin/sysctl |
sbin_sysctl |
/sbin/useradd |
sbin_useradd |
/sbin/userdel |
sbin_userdel |
/sbin/usermod |
sbin_usermod |
/sbin/vipw |
sbin_vipw |
/sbin/pidof |
sbin_pidof |
/sbin/sendmail |
sbin_sendmail |
/sbin/tcpdump |
sbin_tcpdump |
/usr/bin/vdir |
usr_bin_vdir |
/usr/bin/write |
usr_bin_write |
/bin/awk |
bin_awk |
/bin/basename |
bin_basename |
/bin/bash |
bin_bash |
/bin/cat |
bin_cat |
/bin/chattr |
bin_chattr |
/bin/chmod |
bin_chmod |
/bin/chown |
bin_chown |
/bin/cp |
bin_cp |
/bin/curl |
bin_curl |
/bin/cut |
bin_cut |
/bin/date |
bin_date |
/bin/df |
bin_df |
/bin/diff |
bin_diff |
/bin/dirname |
bin_dirname |
/bin/dmesg |
bin_dmesg |
/bin/du |
bin_du |
/bin/echo |
bin_echo |
/bin/ed |
bin_ed |
/bin/egrep |
bin_egrep |
/bin/env |
bin_env |
/bin/fgrep |
bin_fgrep |
/bin/file |
bin_file |
/bin/find |
bin_find |
/bin/grep |
bin_grep |
/bin/groups |
bin_groups |
/bin/head |
bin_head |
/bin/id |
bin_id |
/bin/ipcs |
bin_ipcs |
/bin/kill |
bin_kill |
/bin/killall |
bin_killall |
/bin/last |
bin_last |
/bin/lastlog |
bin_lastlog |
/bin/ldd |
bin_ldd |
/bin/less |
bin_less |
/bin/logger |
bin_logger |
/bin/login |
bin_login |
/bin/ls |
bin_ls |
/bin/lsattr |
bin_lsattr |
/bin/mail |
bin_mail |
/bin/md5sum |
bin_md5sum |
/bin/mktemp |
bin_mktemp |
/bin/more |
bin_more |
/bin/mount |
bin_mount |
/bin/mv |
bin_mv |
/bin/netstat |
bin_netstat |
/bin/newgrp |
bin_newgrp |
/bin/passwd |
bin_passwd |
/bin/perl |
bin_perl |
/bin/pgrep |
bin_pgrep |
/bin/ping |
bin_ping |
/bin/pkill |
bin_pkill |
/bin/ps |
bin_ps |
/bin/pstree |
bin_pstree |
/bin/pwd |
bin_pwd |
/bin/readlink |
bin_readlink |
/bin/rpm |
bin_rpm |
/bin/runcon |
bin_runcon |
/bin/sed |
bin_sed |
/bin/sh |
bin_sh |
/bin/sha1sum |
bin_sha1sum |
/bin/sha224sum |
bin_sha224sum |
/bin/sha256sum |
bin_sha256sum |
/bin/sha384sum |
bin_sha384sum |
/bin/sha512sum |
bin_sha512sum |
/bin/size |
bin_size |
/bin/sort |
bin_sort |
/bin/ssh |
bin_ssh |
/bin/stat |
bin_stat |
/bin/strace |
bin_strace |
/bin/strings |
bin_strings |
/bin/su |
bin_su |
/bin/sudo |
bin_sudo |
/bin/tail |
bin_tail |
/bin/test |
bin_test |
/bin/top |
bin_top |
/bin/touch |
bin_touch |
/bin/tr |
bin_tr |
/bin/uname |
bin_uname |
/bin/uniq |
bin_uniq |
/bin/users |
bin_users |
/bin/vmstat |
bin_vmstat |
/bin/w |
bin_w |
/bin/watch |
bin_watch |
/bin/wc |
bin_wc |
/bin/wget |
bin_wget |
/bin/whatis |
bin_whatis |
/bin/whereis |
bin_whereis |
/bin/which |
bin_which |
/bin/who |
bin_who |
/bin/whoami |
bin_whoami |
/bin/numfmt |
bin_numfmt |
/bin/kmod |
bin_kmod |
/bin/systemctl |
bin_systemctl |
/bin/gawk |
bin_gawk |
/bin/mailx |
bin_mailx |
/bin/nmcli |
bin_nmcli |
/bin/scp |
bin_scp |
/bin/tar |
bin_tar |
/bin/chfn |
bin_chfn |
/bin/chsh |
bin_chsh |
/bin/crontab |
bin_crontab |
/bin/slogin |
bin_slogin |
/bin/vdir |
bin_vdir |
/bin/write |
bin_write |
Alias |
Subdirectory |
Creation |
Deletion |
Moving |
Modification |
/etc/init.d |
startup |
/etc/rc.d/init.d |
rc-startup |
rx-local |
/etc/systemd/system |
system |
/etc/systemd/user |
user |
/etc/crontab |
crontab |
/var/spool/cron |
spool-cron |
/etc/cron.daily |
cron-daily |
/etc/cron.hourly |
cron-hourly |
/etc/cron.monthly |
cron.monthly |
/etc/cron.weekly |
cron.weekly |
/etc/cron.allow |
cron.allow |
/etc/passwd |
passwd |
/etc/profile |
profile |
/root/.bashrc |
bashrc |
bash_profile |
/root/.cshrc |
cshrc |
so.preload |
/etc/shells |
shells |
/usr/bin |
bin |
/bin |
bin |
/usr/sbin |
sbin |
/sbin |
sbin |
/usr/lib |
lib |
/lib |
lib |
/usr/lib64 |
lib64 |
/lib64 |
lib64 |
Windows file integrity monitoring checks system files and directories; records file or directory creation, modification, deletion, and moving; and records and reports file or directory attribute changes, helping you detect suspicious changes in a timely manner. For more information, see Table 4.
You can modify the File Protection policy to add or delete monitored files or directories. For details, see Configuring Policies.
Alias |
Subdirectory |
File Name Extension |
Creation |
Deletion |
Moving |
Modification |
c:\Windows |
windows |
exe, dll, ocx, sys, cmd, com, vbs, bat |
C:\Windows\System32 |
system32 |
C:\Windows\SysWOW64 |
SysWOW64 |
C:\Windows\System32\drivers |
drivers |
sys |
C:\Windows\System32\drivers\etc |
etc |
None |
Notes and Constraints
File integrity management is available in HSS professional, enterprise, premium, WTP, and container editions. For details about how to purchase and upgrade HSS, see Purchasing an HSS Quota and Upgrading a Protection Quota.
References
After the file integrity monitoring scope is set, you can periodically check whether file change events are reported. For details, see Checking File Change Events.
