Help Center/ Host Security Service/ User Guide/ Proactive Defense/ ServerWeb Tamper Protection/ Manually Enabling or Disabling Directory Protection
Updated on 2026-09-07 GMT+08:00
Once a directory is protected, all the files and folders in the directory will be set to read-only and cannot be modified. If anyone attempts to modify a file or website, the system will automatically restore it to the status before the modification.
If you need to update a web page immediately, and the scheduled protection and privileged processes cannot help, you can manually disable protection on the directory, update the web page, and enable protection again. For details about scheduled protection and privileged processes, see Enabling Server WTP.
Manually Suspending Directory Protection
  1. Log in to the HSS console.
  2. Click in the upper left corner and select a region or project.
  3. In the navigation pane, choose Prevention > Web Tamper Protection.
    Figure 1 Web tamper protection
  4. Click Server WTP, and click the Servers tab.
  5. In the Protected Directories column of a server, click the number to go to the details page.
    Figure 2 Number of protected directories
  6. In the Operation column of a protected directory, click Suspend Protection.
    To suspend protection for multiple directories, select all the directories and click Suspend Protection above the list.
    Figure 3 Suspending protection
  7. In the dialog box that is displayed, click OK.
    If the protection status of the directory is Unprotected, the protection has been suspended.
Manually Resuming Directory Protection
    Figure 4 Web tamper protection
    Figure 5 Number of protected directories
  6. In the Operation column of a protected directory, click Resume Protection.
    To resume protection for multiple directories, select all the directories and click Resume Protection above the list.
    Figure 6 Resuming protection
    If the protection status of the directory is Protected, the protection has been resumed.
